WSUS: geen computers zichtbaar
Hallo allemaal
Ik heb een probleem met mn WSUS update server.
Test Situation:
WS2003 - IIS, en 'wsus sp2' installed. Op deze server kan ik tevens policies configureren in Edirectory. WSUS is confugured op port 80.
TestXP
Ik heb deze 'Step by step guide' gevolgd: http://technet.microsoft..../dd939822%28WS.10%29.aspx
Ik heb mijn 'WSUS servername' ingevoerd in the policy "Specify intranet Microsoft update service location"
Hier is mijn Windowsupdate.log of the XP machine:
2010-02-22 11:22:47:968 1048 770 AU #############
2010-02-22 11:22:47:968 1048 770 AU ## START ## AU: Search for updates
2010-02-22 11:22:47:968 1048 770 AU <<## SUBMITTED ## AU: Search for updates [CallId = {1D9B534E-D017-4B4C-B620-1B870DDF0CD4}]
2010-02-22 11:22:47:968 1048 87c Agent *************
2010-02-22 11:22:47:968 1048 87c Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-02-22 11:22:47:968 1048 87c Agent * Online = Yes; Ignore download priority = No
2010-02-22 11:22:47:968 1048 87c Agent * Criteria = "IsHidden=0 and IsInstalled=0 and DeploymentAction='Installation' and IsAssigned=1 or IsHidden=0 and IsPresent=1 and DeploymentAction='Uninstallation' and IsAssigned=1 or IsHidden=0 and IsInstalled=1 and DeploymentAction='Installation' and IsAssigned=1 and RebootRequired=1 or IsHidden=0 and IsInstalled=0 and DeploymentAction='Uninstallation' and IsAssigned=1 and RebootRequired=1"
2010-02-22 11:22:47:968 1048 87c Agent * ServiceID = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7} Managed
2010-02-22 11:22:47:968 1048 87c Agent * Search Scope = {Machine}
2010-02-22 11:22:47:968 1048 87c Misc WARNING: SendRequest failed with hr = 800710dd. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-22 11:22:47:968 1048 87c Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://servername/selfupdate/wuident.cab>. error 0x800710dd
2010-02-22 11:22:47:968 1048 87c Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x800710dd
2010-02-22 11:22:47:968 1048 87c Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x800710dd
2010-02-22 11:22:47:968 1048 87c Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x800710dd
2010-02-22 11:22:47:984 1048 87c Misc WARNING: SendRequest failed with hr = 800710dd. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-22 11:22:47:984 1048 87c Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://servername/selfupdate/wuident.cab>. error 0x800710dd
2010-02-22 11:22:47:984 1048 87c Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x800710dd
2010-02-22 11:22:47:984 1048 87c Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x800710dd
2010-02-22 11:22:47:984 1048 87c Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x800710dd
2010-02-22 11:22:47:984 1048 87c Misc WARNING: DownloadFileInternal failed for http://servername/selfupdate/wuident.cab: error 0x800710dd
2010-02-22 11:22:47:984 1048 87c Setup FATAL: IsUpdateRequired failed with error 0x800710dd
2010-02-22 11:22:47:984 1048 87c Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed: 0x800710dd
2010-02-22 11:22:47:984 1048 87c Setup WARNING: SelfUpdate: Default Service: IsUpdateRequired failed, error = 0x800710DD
2010-02-22 11:22:47:984 1048 87c Agent * WARNING: Skipping scan, self-update check returned 0x800710DD
2010-02-22 11:22:47:984 1048 87c Agent * WARNING: Exit code = 0x800710DD
2010-02-22 11:22:47:984 1048 87c Agent *********
2010-02-22 11:22:47:984 1048 87c Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-02-22 11:22:47:984 1048 87c Agent *************
Mijm probleem: De Wsus-Console laat geen computers zien.
Wie kan me helpen?
Thanx
BJ
Het lijkt erop dat je clients de WSUS omgeving niet kunnen bereiken.
Je hebt ook aangegeven dat je WSUS op poort 80 draait. Voor zover ik me kan herinneren was het niet mogelijk om de poorten van WSUS aan te passen.
Probeer in je policy de locatie te veranderen naar port 8530 (standaard poort wsus).
Beste Leon,
Bedankt voor je reactie. Ik heb tijdens de installatie WSUS geconfigureerd op poort 80 (IIS).
Als ik op mijn Client en/of Server in IE " http://10.10.19.100:80 " Invul krijg ik de melding: Under Construction.
Gr.
BJ
  • kulgan
  • Laatst online: 28-10 17:51
Kijkt je client naar de goede server ?
Te testen met :
Reg query "HKLM\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate" /s
Beste Kulgan,
Bedankt voor je reactie. Daar heb je een punt...
Normaal als ik via een Application Package een registerbestandje dump op mn clients krijg ik dit in het register:
"WUStatusServer"="http://10.13.24.211"
"WUServer"="http://10.13.24.211"
Maar nu heb ik het op Policy niveau gedaan dus in de policy "Specify intranet Microsoft update service location" invullen: http://10.13.24.211. En er staat idd geen servernaam in het register
Dus het betekend dat de policy niet goed word doorgvoerd. Dus heb ik het zojuist gecheckt op mn client, maar de client zegt gewoon dat hij de policy krijgt. Maar schrijft het dus niet weg in het register.
Hoe kan dit?
  • kulgan
Al een gpupdate /force op je client geprobeerd ? (Updaten policies)
kulgan schreef op dinsdag 23 februari 2010 @ 14:37:
Ja, maar er komt nix bij in het register :(
Ben nu aan het kijken of het met een registerfile dmv. Application Object wel weer wil.
Dit zegt mijn windowsupdate.log sinds dat mijn WSUS weer in het register is toegevoegd:
2010-02-23 14:50:29:468 1048 79c AU AU received policy change subscription event
2010-02-23 14:55:33:886 1048 6cc AU Triggering AU detection through DetectNow API
2010-02-23 14:55:33:886 1048 6cc AU Triggering Online detection (non-interactive)
2010-02-23 14:55:33:886 1048 79c AU #############
2010-02-23 14:55:33:886 1048 79c AU ## START ## AU: Search for updates
2010-02-23 14:55:33:886 1048 79c AU <<## SUBMITTED ## AU: Search for updates [CallId = {16D6EFDF-5F4D-49A4-8CE5-D1A29E23D930}]
2010-02-23 14:55:33:886 1048 e14 Agent *************
2010-02-23 14:55:33:886 1048 e14 Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2010-02-23 14:55:33:886 1048 e14 Agent * Online = Yes; Ignore download priority = No
2010-02-23 14:55:33:886 1048 e14 Agent * Criteria = "IsHidden=0 and IsInstalled=0 and DeploymentAction='Installation' and IsAssigned=1 or IsHidden=0 and IsPresent=1 and DeploymentAction='Uninstallation' and IsAssigned=1 or IsHidden=0 and IsInstalled=1 and DeploymentAction='Installation' and IsAssigned=1 and RebootRequired=1 or IsHidden=0 and IsInstalled=0 and DeploymentAction='Uninstallation' and IsAssigned=1 and RebootRequired=1"
2010-02-23 14:55:33:886 1048 e14 Agent * ServiceID = {9482F4B4-E343-43B6-B170-9A65BC822C77} Windows Update
2010-02-23 14:55:33:886 1048 e14 Agent * Search Scope = {Machine}
2010-02-23 14:55:45:605 1048 e14 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wuident.cab:
2010-02-23 14:55:45:621 1048 e14 Misc Microsoft signed: Yes
2010-02-23 14:55:45:730 1048 e14 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wsus3setup.cab:
2010-02-23 14:55:45:730 1048 e14 Misc Microsoft signed: Yes
2010-02-23 14:55:45:746 1048 e14 Setup *********** Setup: Checking whether self-update is required ***********
2010-02-23 14:55:45:746 1048 e14 Setup * Inf file: C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wsus3setup.inf
2010-02-23 14:55:45:777 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\cdm.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:793 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuapi.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuapi.dll.mui: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuauclt.exe: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuaucpl.cpl: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuaucpl.cpl.mui: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuaueng.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuaueng.dll.mui: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:808 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wucltui.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:824 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wucltui.dll.mui: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:824 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wups.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:824 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wups2.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:840 1048 e14 Setup Update NOT required for C:\WINDOWS\System32\wuweb.dll: target version = 7.4.7600.226, required version = 7.4.7600.226
2010-02-23 14:55:45:855 1048 e14 Setup * IsUpdateRequired = No
2010-02-23 14:55:47:699 1048 e14 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
2010-02-23 14:55:47:699 1048 e14 Misc Microsoft signed: Yes
2010-02-23 14:55:48:699 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:48:699 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:48:699 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:48:699 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:48:699 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:48:699 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:49:715 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:49:715 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:49:715 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:49:715 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:49:715 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:49:715 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:50:715 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:50:715 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:50:715 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:50:715 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:50:715 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:50:715 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:51:715 1048 e14 Misc WARNING: DownloadFileInternal failed for http://download.windowsup...te/redir/muv4wuredir.cab: error 0x80072efe
2010-02-23 14:55:51:715 1048 e14 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
2010-02-23 14:55:51:715 1048 e14 Misc Microsoft signed: Yes
2010-02-23 14:55:52:934 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:52:934 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:52:934 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:52:934 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:52:934 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:52:934 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:53:934 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:53:934 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:53:934 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:53:934 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:53:934 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:53:934 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:54:934 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:54:934 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:54:934 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:54:934 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:54:934 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:54:934 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:55:949 1048 e14 Misc WARNING: DownloadFileInternal failed for http://download.microsoft...te/redir/muv4wuredir.cab: error 0x80072efe
2010-02-23 14:55:55:949 1048 e14 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
2010-02-23 14:55:55:949 1048 e14 Misc Microsoft signed: Yes
2010-02-23 14:55:56:949 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:56:949 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:56:949 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://www.update.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:56:949 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:56:949 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:56:949 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:57:949 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:57:949 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:57:949 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://www.update.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:57:949 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:57:949 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:57:949 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:58:965 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:58:965 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:58:965 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://www.update.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:58:965 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:58:965 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:58:965 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: Send failed with hr = 80072efe.
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: SendRequest failed with hr = 80072efe. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://www.update.microsoft.com/v9/windowsupdate/redir/muv4wuredir.cab>. error 0x80072efe
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efe
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efe
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efe
2010-02-23 14:55:59:965 1048 e14 Misc WARNING: DownloadFileInternal failed for http://www.update.microso...te/redir/muv4wuredir.cab: error 0x80072efe
2010-02-23 14:55:59:965 1048 e14 PT WARNING: PTError: 0x80072efe
2010-02-23 14:55:59:965 1048 e14 PT WARNING: Initialization failed for Protocol Talker Context: 0x80072efe
2010-02-23 14:55:59:965 1048 e14 Agent * WARNING: Failed to synchronize, error = 0x80072EFE
2010-02-23 14:55:59:996 1048 e14 Agent * WARNING: Exit code = 0x80072EFE
2010-02-23 14:55:59:996 1048 e14 Agent *********
Maar nog geen Client te vinden in mijn WSUS console
  • alt-92
alt-92
ye olde farte
Verwijderd schreef op dinsdag 23 februari 2010 @ 11:53:
Gezien alle foutmeldingen en niet doorkomende GPO's heb je wel andere problemen dan alleen een WSUS console waar geen hosts in terug te vinden zijn.
alt-92 schreef op dinsdag 23 februari 2010 @ 15:14:
Hey,
En wat zou dat kunnen zijn? Er is voldaan aan alle software eisen, Firewalls in de testopstelling uitgezet. Verbindingen tussen TestXP en WSUS server zijn prima.
Gr. BJ
  • ITssME
  • Laatst online: 21-01 14:42
Heb je op de WSUS server bij Options-> computers; use group policy or registry settings for computers geselecteerd? Ik zie nl nergens in de log file je WSUS server naar voren komen.
ITssME schreef op dinsdag 23 februari 2010 @ 15:24:
ja heb ik idd ingesteld. maar ik zal zo even wat printscreens maken voor de duidelijkheid
Mijn policy instellingen. IP is hier fake.
http://img62.imageshack.us/i/policyinstellingen.png/
Mijn registerinstellingen op client
http://img691.imageshack.us/i/wsusl.png/
http://img96.imageshack.us/i/auoptions.png/
Uiteraard vertrouw ik jullie, maar ik loop stage, en dan mag je nou eenmaal geen ip's laten zien.
Hoop dat het iets duidelijker is.
[ Voor 17% gewijzigd door Verwijderd op 23-02-2010 15:45 ]
Het maakt überhaupt toch niet uit dat ik een IP gebruikt i.p.v. WSUS dns naam?
Moet een client kunnen pingen naar de WSUS selfupdate site?
  • Oid
Oid
Wanneer je iets anders in de policy veranderd, bijvoorbeeld dat Uitvoeren weg is uit het start menu, voert die dat dan wel door?
  • Yalopa
Yalopa
Less is more!
vraag eens een gpresult op bij een van de PC's waar je de setting verwacht, staat de policy daartussen?
You don't need eyes to see, you need vision
Dag mensen, bedankt allemaal, het is opgelost. De computers staan netjes in de WSUS console. Updaten is ook mogelijk.
Maar ik heb nog een vraag. Is het ook mogelijk om op de clients de updates automatisch te laten installeren(downloaden gebeurd al wel automatisch). Ik kan de clients wel automatisch de updates laten installeren, maar dit alleen op een vast tijdstip.
http://yfrog.com/espolicyinstellingen2p
Het moet wel kunnen, maar ik weet niet hoe, wie kan me helpen
[ Voor 4% gewijzigd door Verwijderd op 26-02-2010 12:52 ]
  • WPN
  • Laatst online: 26-09 00:48
WPN
zou fijn zijn als je ook vertelt hoe je probleem is opgelost........ :)
en of een van de bijdragen van de replyers het antwoord was ....
je kan in je policies instellen hoe de updates moeten verlopen sommige updates kunnen direct na downloaden automatisch geinstalleerd worden, sommige updates alleen op bepaalde tijden dat je specificeerd omdat daar mogelijk een reboot voor nodig (welke je kan onderdrukken).....
lees bij alle policy settings de uitleg eens die erbij staat dan heb je gelijk een idee wat de settings doen
Als ik denk zoals ik dacht, dan doe ik zoals ik deed, als ik doe zoals ik deed, dan denk ik zoals ik dacht! Cogito Ergo Sum
Peluso schreef op vrijdag 26 februari 2010 @ 13:00:
Hey, Het waren de gebruikersrechten die roet in het eten gooide.
hmmmm... Ja maar ik zie geen optie die het mogelijk maakt om op de clients de updates automatisch te laten installeren. dus als om er bijvoorbeeld om 8:30 of 9: 30een update naar de clients word getransporteerd, dan komt hij onderin de taakbalk te staan, en dan moet hij in mijn geval wachten tot 11:00
Hoe kan ik dit verrandren?
  • kulgan
Inderdaad zoals Peluso al zegt, i/h GPO kan je ook instellen op welke tijd de installatie plaats moet gaan vinden.
kulgan schreef op vrijdag 26 februari 2010 @ 14:45:
Inderdaad zoals Peluso al zegt, i/h GPO kan je ook instellen op welke tijd de installatie plaats moet gaan plaats vinden.
Hoi
Ja dat snap ik...
Dus als ik op een willekeurige tijd de update's verspreid naar mn clients moet ik elke keer de tijd in de policy handmatig aanpassen. Ik heb gehoord dat het anders moet kunnen
Gewenste situatie:
Bij het verspreiden van de updates op elk willekeurig tijdstip worden ze ook meteen geïnstalleerd.
Alvast bedankt
  • alt-92
alt-92
ye olde farte
Verwijderd schreef op vrijdag 26 februari 2010 @ 14:59:
Gewenste situatie:
SMS/SCCM.
  • WPN
WPN
omdat het een free tool is, is het een beetje beperkt in mogelijkheden zoals ALT-92 eigenlijk zegt..
sms/sccm zijn betaalde tools waarmee veel meer mogelijkheden zijn....
met wsus worden updates sowieso niet naar clients gepushed, deze worden klaar gezet voor detectie door de client en de client haalt de updates op en zet de updates klaar voor installatie volgens GPO.
ik zie zelf het volgende:
computer > AT > WU >
Allow Automatic Updates immediate installation
Specifies whether Automatic Updates should automatically install certain updates that neither interrupt Windows services nor restart Windows.
If the status is set to Enabled, Automatic Updates will immediately install these updates once they are downloaded and ready to install.
If the status is set to Disabled, such updates will not be installed immediately.
Note: If the "Configure Automatic Updates" policy is disabled, this policy has no effect.
houdt in dat alle updates die dus geen onderbrekingen van services or reboots veroorzaken direct geinstalleerd worden.....
  • Yalopa
Yalopa
Less is more!
om een GPO uitzonderlijk ASAP te verspreiden kan je ook deadlines gebruiken. Als je de deadline in het verleden zet dan wordt ie direct geupdate.
