Ik heb in m'n Gentoo machine een raidcontroller zitten (HighPoint RocketRaid 2310 4x sata), nu heb ik deze wel aan de praat met een simpele install, maar dat is natuurlijk niet handig.
Om dit alles te automatiseren ben ik een ebuild aan het schrijven.
ebuild:
# Copyright 1999-2010 Gentoo Foundation
# Distributed under the terms of the GNU General Public License v2
# $Header: $
inherit linux-mod
MY_PR="091022"
MY_PVR="${PV}-${MY_PR}"
DESCRIPTION="Kernel module for Highpoint RocketRaid 231x raid cards"
HOMEPAGE="http://www.highpoint-tech.com/USA/rr2310.htm"
SRC_URI="http://www.support-highpoint-tech.com/Main/${PN}_00/Linux/opensrc/${PN}_0x-linux-src-v${MY_PVR}-1618.tar.gz"
LICENSE="GPL"
SLOT="0"
KEYWORDS="~x86"
IUSE=""
DEPEND=""
RDEPEND=""
S="${WORKDIR}/${PN}_0x-linux-src-v${PV}"
BUILD_PARAMS="KERNELDIR=${KERNEL_DIR}"
BUILD_TARGETS=" "
MODULE_NAMES="rr2310_00(scsi:"${S}/product/rr2310pm/linux/":)"
Nu faalt emake (anders had ik natuurlijk niets gepost :) );
 * Preparing rr2310_00 module
make -j5 HOSTCC=i686-pc-linux-gnu-gcc CROSS_COMPILE=i686-pc-linux-gnu- LDFLAGS= KERNELDIR=/usr/src/linux
make[1]: Entering directory `/usr/src/linux-2.6.32-gentoo-r5'
Makefile:529: /usr/src/linux-2.6.32-gentoo-r5/arch/i686/Makefile: No such file or directory
make[1]: *** No rule to make target `/usr/src/linux-2.6.32-gentoo-r5/arch/i686/Makefile'.  Stop.
make[1]: Leaving directory `/usr/src/linux-2.6.32-gentoo-r5'
make: *** [rr2310_00.ko] Error 2
Maar als ik make run met dezelfde gaat het wel:
  CC [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/os_linux.o
  CC [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/osm_linux.o
  CC [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/div64.o
  CC [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/hptinfo.o
  CC [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/config.o
  LD [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/rr2310_00.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/rr2310_00.mod.o
  LD [M]  /var/tmp/portage/sys-block/rr231x-2.5-r091022/work/rr231x_0x-linux-src-v2.5/product/rr2310pm/linux/.build/rr2310_00.ko
iemand die hier de oplossing voor ziet?
  • _eXistenZ_
  • Laatst online: 14-11 10:05
Ik heb zelf een Gentoo NAS met een rr2320 er in, gebruik de officiele drivers van Highpoint, maar toen ik van 2.6.28 naar 2.6.30 ging wilde de zaak niet compileren, toen heb ik ze gemaild en hebben ze het gefixt... Maar volgens mij heeft dit weinig met jouw ding te maken :P Iig et zou geweldig zijn als er gewoon een ebuild voor kwam \o/ thanks alvast! /edit Misschien heeft het hier wel mee te maken, omdat je een nieuwe versie ophaalt die niet werkt? Ik kan geen enters doen in dit textfield daarom staat alles achter elkaar, firefox 3.6 :S
[ Voor 22% gewijzigd door _eXistenZ_ op 12-02-2010 20:29 ]
There is no replacement for displacement!
met de huidige kernel van Gentoo werkt alles wel, nouja.
readme volgen en "make KERNELDIR=/usr/src/linux/" uitvoeren.
via modprobe laadt de module niet, maar met insmod wel.
werkt prima hier :)
Alleen de ebuild werkt niet en ik heb geen idee.
  • H!GHGuY
H!GHGuY
Try and take over the world...
arch/i686 bestaat ook gewoon niet.
Je zal moeten uitzoeken hoe de mapping van i686 naar x86 gedaan wordt.
ASSUME makes an ASS out of U and ME
Als het goed is wordt het gedaan via uname.
uname -m geeft i686 als output, hoewel de kernel x86 als arch heeft.
Vroegah (niet zo lang terug) was dit altijd i686 als arch dacht ik, vandaar deze 'bug' denk ik zo?
Maar dit verklaart nog steeds niet waarom dit alleen niet goed gaat in de ebuild.
  • H!GHGuY
H!GHGuY
edit: Ik had even niet goed door dat je make manueel met dezelfde parameters aanriep en het daar toch fout liep.
Een van de veel voorkomende issues bij builds zijn de verschillende environment variabelen.
Je kan eens proberen je ebuild zo aan te passen dat hij alle environment variabelen print, ipv te builden.
Anderzijds kan je ook eens proberen om te builden vanuit een lege shell (env -i)
[ Voor 89% gewijzigd door H!GHGuY op 15-02-2010 12:48 ]
  • laurencevde
  • Laatst online: 02-10-2025
kan je "emerge --info" even posten?
Have a taste of freedom. It is sometimes a bitter pill. To me though, this is the sweetness of the GPL
Late reactie:
emerge --info:
29
30
31
32
33
34
35
36
37
38
39
40
41
Portage 2.1.7.17 (default/linux/x86/10.0/desktop, gcc-4.3.4, glibc-2.10.1-r1, 2.6.32-gentoo-r5 i686)
System uname: Linux-2.6.32-gentoo-r5-i686-AMD_Phenom-tm-_9650_Quad-Core_Processor-with-gentoo-2.0.1
Timestamp of tree: Sun, 21 Feb 2010 14:30:01 +0000
app-shells/bash:     4.0_p35
dev-java/java-config: 2.1.10
dev-lang/python:     2.6.4
dev-util/cmake:      2.6.4-r3
sys-apps/baselayout: 2.0.1
sys-apps/openrc:     0.6.0-r1
sys-apps/sandbox:    1.6-r2
sys-devel/autoconf:  2.13, 2.63-r1
sys-devel/automake:  1.8.5-r3, 1.9.6-r2, 1.10.2
sys-devel/binutils:  2.18-r3
sys-devel/gcc:       4.3.4
sys-devel/gcc-config: 1.4.1
sys-devel/libtool:   2.2.6b
virtual/os-headers:  2.6.32
ACCEPT_KEYWORDS="x86"
ACCEPT_LICENSE="* -@EULA"
CBUILD="i686-pc-linux-gnu"
CFLAGS="-O2 -march=i686 -pipe"
CHOST="i686-pc-linux-gnu"
CONFIG_PROTECT="/etc /usr/share/X11/xkb /usr/share/config /var/lib/hsqldb"
CONFIG_PROTECT_MASK="/etc/ca-certificates.conf /etc/env.d /etc/env.d/java/ /etc/fonts/fonts.conf /etc/gconf /etc/gentoo-release /etc/revdep-rebuild /etc/sandbox.d /etc/terminfo /etc/udev/rules.d"
CXXFLAGS="-O2 -march=i686 -pipe"
DISTDIR="/usr/portage/distfiles"
FEATURES="assume-digests distlocks fixpackages news parallel-fetch protect-owned sandbox sfperms strict unmerge-logs unmerge-orphans userfetch"
GENTOO_MIRRORS="ftp://gentoo.tiscali.nl/pub/mirror/gentoo/ "
LDFLAGS="-Wl,-O1"
LINGUAS="en nl"
MAKEOPTS="-j5"
PKGDIR="/usr/portage/packages"
PORTAGE_CONFIGROOT="/"
PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --compress --force --whole-file --delete --stats --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages"
PORTAGE_TMPDIR="/var/tmp"
PORTDIR="/usr/portage"
PORTDIR_OVERLAY="/usr/local/portage/layman/kde /usr/local/portage"
SYNC="rsync://rsync.gentoo.org/gentoo-portage"
USE="X a52 aac acl acpi alsa autotrace bash-completion berkdb branding bzip2 cairo cdr cli consolekit cracklib cups cxx dbus dri dts dvd dvdr emboss encode evo fam fat firefox flac fortran fuse gdbm gif gnutls gpm gstreamer gtk hal iconv imagemagick ipv6 java java6 jpeg jpeg2k kde ldap libnotify libssh2 lvm1 mad mikmod mng modules mp3 mp4 mpeg mudflap ncurses nls nptl nptlonly nsplugin ntfs ogg opengl openmp pam parcheck pcre pdf perl png ppds pppd python q32 qt3support qt4 quicktime readline reflection reiser4 reiserfs sdl session spell spl ssl startup-notification svg sysfs tcl tcpd templates thunar tiff truetype unicode usb vistafree vorbis win32codecs wmf x264 x86 xml xorg xpfast xpsmall xulrunner xv xvid zlib" ALSA_CARDS="ali5451 als4000 atiixp atiixp-modem bt87x ca0106 cmipci emu10k1 emu10k1x ens1370 ens1371 es1938 es1968 fm801 hda-intel intel8x0 intel8x0m maestro3 trident usb-audio via82xx via82xx-modem ymfpci" ALSA_PCM_PLUGINS="adpcm alaw asym copy dmix dshare dsnoop empty extplug file hooks iec958 ioplug ladspa lfloat linear meter mmap_emul mulaw multi null plug rate route share shm softvol" APACHE2_MODULES="actions alias auth_basic authn_alias authn_anon authn_dbm authn_default authn_file authz_dbm authz_default authz_groupfile authz_host authz_owner authz_user autoindex cache dav dav_fs dav_lock deflate dir disk_cache env expires ext_filter file_cache filter headers include info log_config logio mem_cache mime mime_magic negotiation rewrite setenvif speling status unique_id userdir usertrack vhost_alias" ELIBC="glibc" INPUT_DEVICES="keyboard mouse evdev" KERNEL="linux" LCD_DEVICES="bayrad cfontz cfontz633 glk hd44780 lb216 lcdm001 mtxorb ncurses text" LINGUAS="en nl" RUBY_TARGETS="ruby18" USERLAND="GNU" VIDEO_CARDS="nvidia"
Unset:  CPPFLAGS, CTARGET, EMERGE_DEFAULT_OPTS, FFLAGS, INSTALL_MASK, LANG, LC_ALL, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS
Ebuild heb ik al werkend overigens:
29
30
31
32
33
# $Header: $
inherit linux-mod
MY_PR="091022"
LICENSE="GPL"
SLOT="0"
KEYWORDS="~x86"
IUSE=""
DEPEND=""
RDEPEND=""
BUILD_PARAMS="KERNELDIR=${KERNEL_DIR} ARCH=x86"
BUILD_TARGETS=" "
MODULE_NAMES="rr2310_00(scsi:${S}/product/rr2310pm/linux/:)"
src_unpack() {
        unpack ${A}
        cd "${S}/lib/linux"
        mv "free-i686-regparm3" "free-x86-regparm3"
