Wat is dit kastje
  • WoBBeL
  • Laatst online: 29-10 08:03
Vandaag kwam ik dit leuke kastje tegen, maar ik heb geen FLAUW benul wat het is en wat het doet ;)
Afbeeldingslocatie: http://wobbel.nl/omgwtfbbq/DSCN0147_thumb.jpg
Klik voor een vergroting...
Op de achterkant staat het volgende:
ic485lp-1
Interface powered
RS232-RS422/485
[ Voor 22% gewijzigd door WoBBeL op 12-02-2010 16:32 ]
  • Notna
  • Laatst online: 13:36
Notna
Where are you?®
Interface converter
http://www.roalan.com/RS2...d%20RS485%20Converter.htm
The SER-485 Lite is a cost effective adapter to convert bidirectional signals from RS232 to RS422 and RS485. In RS485 mode the data direction is managed by the bitrate adaptive function of ART (Automatic Receive Transmit control). ART analyzes the data in real-time, and adapts to the setup of the RS232 port.
With SER-485 Lite standard operation modes are selected by simple DIP switches. The full versatility is controlled by a built-in software configuration menu, which is accessed via terminal programs. The behaviour of RS422 and various options of RS485 are selected by an easy-to-use menu structure.
The internal termination and BIAS (polarization) resistors allow to prepare the RS485 signals for connection to customers networks.
en
http://www.rs485.com/rs485spec.html
Line drivers and receivers are commonly used to exchange data between two or more points (nodes) on a network. Reliable data communications can be difficult in the presence of induced noise, ground level differences, impedance mismatches, failure to effectively bias for idle line conditions, and other hazards associated with installation of a network.
The connection between two or more elements (drivers and receivers) should be considered a transmission line if the rise and/or fall time is less than half the time for the signal to travel from the transmitter to the receiver.
Standards have been developed to insure compatibility between units provided by different manufacturers, and to allow for reasonable success in transferring data over specified distances and/or data rates. The Electronics Industry Association (EIA) has produced standards for RS485, RS422, RS232, and RS423 that deal with data communications. Suggestions are often made to deal with practical problems that might be encountered in a typical network. EIA standards where previously marked with the prefix "RS" to indicate recommended standard; however, the standards are now generally indicated as "EIA" standards to identify the standards organization. While the standards bring uniformity to data communications, many areas are not specifically covered and remain as "gray areas" for the user to discover (usually during installation) on his own.
simpel te vinden middels Google+td+rd+converter OF gewoon dat serienummer aan de achterkant erin plempen :P :)
[ Voor 132% gewijzigd door Notna op 12-02-2010 16:35 ]
Xbox Live ID:Notna8310
  • WoBBeL
Bedankt :D nog nooit gebruikt en zal het ook nooit gaan gebruiken.
Iemand interesse? :P
  • u_nix_we_all
xost schreef op vrijdag 12 februari 2010 @ 16:37:
Wat Google ? Kan het toch aanraden hoor :+ >:)
You don't need a parachute to go skydiving. You need a parachute to go skydiving twice.
