"Het leven is als een neus, je moet er uit halen wat er in zit ... "
Start Nero
Choose the menu command "File"->"Burn CD image"
Choose as file type: all files (*.*)
Select the ISO image file
Now you will see a dialog, asking you, if you want to supply detailled
image parameters. This is necessary, since Nero needs to know
exactly, what format the image file has to be able to burn it correctly.
Enter the following parameters:
- Mode 1 (assuming, that you created a mode 1 image)
- 2048 bytes per sector (corresponds to a mode 1 sector)
- 0 bytes header and trailer (assuming, the image contains
only "pure" ISO data and no other special header
or trailer)
- no swapping or scrambling (assuming, that the file contains
bytes in the correct order to be written without word swapping)
Click on "burn" and (for safety considerations) use an empty cdr.
or trailer)
Nero openen, dan:
File->Burn Image
Vervolgens "Files of Type:" -> (*.*)All Files
ISOtje selecteren en branden maar
Jannes his answer is a bit more accurate:)
File->Burn Image
thnxz!
Erg veel dank voor de vlotte reacties...
