Folding client wil niet vouwen
Sinds enkele dagen heb ik last van een probleem, de client start en laat zien dat het een project start alleen hij begint niet. Ik denk zelf dat het komt door de regel "work type a1 not eligible for variable processors". Heb al gezocht maar kan niet vinden waar het aan ligt. Ik draai de fah6_alt versie 6.24beta omdat ik de melding "Could not CosmHTTPOpen" krijg. System draait op fedora 12 en is een standaard intel Q6600 met 4 gig geheugen. Ook de directory is volledig schijfbaar.
Hier het log:
--- Opening Log file [February 3 16:12:57 UTC]
# Linux SMP Console Edition ###################################################
Folding@Home Client Version 6.24beta
http://folding.stanford.edu
Launch directory: /home/nick/folding
Executable: ./fah6_alt
Arguments: -verbosity 9 -smp
[16:12:57] Configuring Folding@Home...
[16:13:43] - Ask before connecting: No
[16:13:43] - User name: HerrBohm (Team 92)
[16:13:43] - User ID not found locally
[16:13:43] + Requesting User ID from server
[16:13:43] - Getting ID from AS:
[16:13:43] Connecting to http://assign.stanford.edu:8080/
[16:13:44] Posted data.
[16:13:44] Initial: 0B56; - Received User ID = 560B918215B52E4F
[16:13:44] - Machine ID: 1
[16:13:44]
[16:13:44] Work directory not found. Creating...
[16:13:44] Could not open work queue, generating new queue...
[16:13:44] - Autosending finished units... [February 3 16:13:44 UTC]
[16:13:44] Trying to send all finished work units
[16:13:44] + No unsent completed units remaining.
[16:13:44] - Autosend completed
[16:13:44] - Preparing to get new work unit...
[16:13:44] + Attempting to get work packet
[16:13:44] - Will indicate memory of 3963 MB
[16:13:44] - Connecting to assignment server
[16:13:44] Connecting to http://assign.stanford.edu:8080/
[16:13:44] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[16:13:44] + News From Folding@Home: Welcome to Folding@Home
[16:13:45] Loaded queue successfully.
[16:13:45] Connecting to http://171.64.65.64:8080/
[16:13:51] Posted data.
[16:13:51] Initial: 0000; - Receiving payload (expected size: 4668935)
[16:13:58] - Downloaded at ~651 kB/s
[16:13:58] - Averaged speed for that direction ~651 kB/s
[16:13:58] + Received work.
[16:13:58] + Closed connections
[16:13:58]
[16:13:58] + Processing work unit
[16:13:58] Work type a1 not eligible for variable processors
[16:13:58] Core required: FahCore_a1.exe
[16:13:58] Core not found.
[16:13:58] - Core is not present or corrupted.
[16:13:58] - Attempting to download new core...
[16:13:58] + Downloading new core: FahCore_a1.exe
[16:13:58] Downloading core (/~pande/Linux/AMD64/Core_a1.fah from www.stanford.edu)
[16:13:59] Initial: AFDE; + 10240 bytes downloaded
[16:13:59] Initial: B54E; + 20480 bytes downloaded
[16:14:02] Initial: 8542; + 1474560 bytes downloaded
[16:14:02] Initial: 3A56; + 1484800 bytes downloaded
[16:14:02] Initial: D4FE; + 1490945 bytes downloaded
[16:14:02] Verifying core Core_a1.fah...
[16:14:02] Signature is VALID
[16:14:02]
[16:14:02] Trying to unzip core FahCore_a1.exe
[16:14:02] Decompressed FahCore_a1.exe (3625104 bytes) successfully
[16:14:02] + Core successfully engaged
[16:14:07]
[16:14:07] + Processing work unit
[16:14:07] Work type a1 not eligible for variable processors
[16:14:07] Core required: FahCore_a1.exe
[16:14:07] Core found.
[16:14:07] Working on queue slot 01 [February 3 16:14:07 UTC]
[16:14:07] + Working ...
[16:14:07] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 16185 -version 624'
[16:14:07]
[16:14:07] *------------------------------*
[16:14:07] Folding@Home Gromacs SMP Core
[16:14:07] Version 1.74 (November 27, 2006)
[16:14:07]
[16:14:07] Preparing to commence simulation
[16:14:07] - Ensuring status. Please wait.
[16:14:07] Created dyn
[16:14:07] - Files status OK
[16:14:08] - Expanded 4668423 -> 24111057 (decompressed 516.4 percent)
[16:14:08] - Starting from initial work packet
[16:14:08]
[16:14:08] Project: 2665 (Run 1, Clone 621, Gen 180)
[16:14:08]
[16:14:08] Assembly optimizations on if available.
[16:14:08] Entering M.D.
[16:14:25] l work pa- Starting from initial work packet
[16:14:25]
[16:14:25] Project: 2665 (Run 1, Clone 621, Gen 180)
[16:14:25]
[16:14:25] Entering M.D.
In de console zie ik na "Entering M.D." ook het volgende nog staan:
NNODES=4, MYRANK=1, HOSTNAME=nick-boven
NNODES=4, MYRANK=2, HOSTNAME=nick-boven
NNODES=4, MYRANK=0, HOSTNAME=nick-boven
NNODES=4, MYRANK=3, HOSTNAME=nick-boven
En verder gebeurd er niks.
  • Xaverius
  • Laatst online: 05-09 22:53
Heb je hier iets aan?
http://foldingforum.org/v...&t=13064&start=15#p127746
Dan zou je de 6.29 kunnen draaien. Ik zoek alleen op jouw trefwoorden aangezien ik geen folding- en ook geen linux-kennis heb. :)
Doet wat met CLP, loopt niet meer hard 😢
Kijk, nu doet de normale client het :). Hopen dat ze nu wel weer goed doorlopen. Bedankt!
