[Samba] Authenticatie met ldap server mislukt
  • martdj
  • Laatst online: 19-10 16:52
Ik heb al verschillende HowTo's gevolgd zoals deze, maar ik loop elke keer weer vast bij de stap:
net getlocalsid.
Antwoord daarop:
[2010/01/26 13:07:09, 0] lib/smbldap.c:1052(smbldap_connect_system)
failed to bind to server ldap://localhost with dn="cn=directory manager" Error: Invalid credentials
(unknown)
SID for domain XXXX is: S-1-5-21-2325311484-1653177960-3101470362
Server OS: Fedora 12
Samba versie: 3.4.2
LDAP directory: 389-ds
De LDAP directory draait op dezelfde server als waar ik een PDC met Samba probeer op te zetten.
Mijn smb.conf:
[global]
workgroup = MyWorkgroup
netbios name = MyServerName
passdb backend = ldapsam:ldap://localhost
username map = /etc/samba/smbusers
printcap name = cups
add user script = /usr/local/sbin/smbldap-useradd -m '%u'
delete user script = /usr/local/sbin/smbldap-userdel %u
add group script = /usr/local/sbin/smbldap-groupadd -p '%g'
delete group script = /usr/local/sbin/smbldap-groupdel '%g'
add user to group script = /usr/local/sbin/smbldap-groupmod -m '%u' '%g'
delete user from group script = /usr/local/sbin/smbldap-groupmod -x '%u' '%g'
set primary group script = /usr/local/sbin/smbldap-usermod -g '%g' '%u'
add machine script = /usr/local/sbin/smbldap-useradd -w '%u'
logon script = scripts\logon.bat
logon path = \\%L\Profiles\%U
logon drive = U:
logon home = \\%L\%U
domain logons = Yes
os level = 35
preferred master = Yes
domain master = Yes
ldap suffix = dc=example,dc=org
ldap machine suffix = ou=Computers
ldap user suffix = ou=People
ldap group suffix = ou=Groups
ldap idmap suffix = ou=People
ldap admin dn = cn=directory manager
ldap ssl = no
ldap passwd sync = Yes
idmap uid = 15000-20000
idmap gid = 15000-20000
load printers = yes
cups options = raw
printing = cups
Als ik met een ldap browser (vanaf een andere computer) probeer om te connecten naar de ldap directory met user cn=directory manager en het juiste wachtwoord dan lukt dat zonder problemen
Het wachtwoord is met smbpasswd -w <password> in de secrets.tdb file gestored.
Iemand enig idee waarom samba niet kan authenticeren met de ldap dir?
  • ph0t0nix
  • Laatst online: 16:41
Toevallig een spatie in je wachtwoord, of andere tekens die op de command line tot problemen kunnen leiden? Dat gaf bij mij vreselijk veel problemen. Gebruik anders 'smbpasswd -W' (hoofletterW dus) eens, dan geef je nl. het password niet mee via de command line, maar vraagt 'ie er zelf om.
En ik zie dat in je config het volgende staat:
en in je tekst:
... connecten naar de ldap directory met user cn=directory administrator en het juiste wachtwoord ...
Dat zijn wel twee verschillende cn's.
[ Voor 32% gewijzigd door ph0t0nix op 26-01-2010 16:03 ]
  • martdj
Ik heb wel een "$" in mijn wachtwoord. Zou dat problemen geven?
Dat van die administrator en manager was een typo. Ik kan binden met cn=directory manager.
  • ph0t0nix
$ wordt door de bash shell geinterpreteerd gebruikt als begin van variabele namen, dus dat kan zeker het probleem zijn.
Doe bijvoorbeeld maar eens
mart="hallo daar"
echo $mart
echo Een zin met $mart
op de command line.
  • martdj
Net even een nieuwe user met admin rechten in de LDAP aangemaakt en die een wachtwoord van cijfers en letters gegeven en inderdaad werkt het nu. Vootraan maar geen $ gebruiken dus in een username/wachtwoord binnen Linux. Weer wat geleerd. Bedankt!
[ Voor 3% gewijzigd door martdj op 26-01-2010 23:23 ]
  • serkoon
serkoon
mekker.
Je kunt prima `$' gebruiken in wachtwoorden, maar als je die op de shell gaat ingeven zal dat even geescaped of gequote moeten worden, that's all :)
