[Folding@Home] hitparade van week 4 Vorige deel Overzicht Volgende deel Laatste deel
  • smoking2000
  • Laatst online: 03-11 04:52
smoking2000
DPC-Crew
dpkg-reconfigure reality
Mede-auteurs:
  • Bubbles
  • Laatst online: 27-11 13:06
Bubbles
  • Wiethoofd
  • Laatst online: 30-09 23:41
Wiethoofd
  • Rubeo38
  • Laatst online: 19-10 11:57
Rubeo38
  • R0SSI
  • Laatst online: 27-09 14:42
R0SSI
| [Folding@Home] Announce: Client monitor voor Linux (fci) | fci-1.8.4 | Fatal Error Group |
  • smoking2000
smoking2000
DPC-Crew
Een nieuwe week, met nieuwe stats, en project nieuws:
Points system for SMP2 work units
by kasson on Sun Jan 24, 2010 7:03 pm
The SMP2 Core A3 work units mark the debut of a new points system. We have been testing the key element of this system--early completion bonuses--in the bigadv work unit program. Please refer to this document with for a more detailed explanation of the points system. We are also changing our benchmark system over to a Core i5. Points have been calibrated against previous benchmarking setups, as described below.
Introduction
Points are a key aspect of distributed computing, such as Folding@home (FAH), as it both works to indicate to donors how much they have contributed, as well as foster friendly competition between donors that has always been an essential part of distributed computing. Folding@home’s point system is based on the concept of a benchmark machine, i.e. a particular class of hardware which we use as a standard to define how many points a given calculation should get. The choice of this benchmark machine can have implications for points for donors. Moreover, how we use this benchmark is important.
Our benchmarking philosophy tries to balance two elements: keeping a system reasonably simple (both for donors and for the FAH team to calculate) as well as keeping points in alignment with scientific value of a given calculation. Indeed, donors will optimize their machines (eg choice of hardware, choice of clients, etc) based on points, so it is important that points awarded be reflective of the scientific gain.
While our basic benchmark idea is pretty simple, this document is fairly long in order to give donors full details about how we have chosen the benchmark machine as well as giving detailed information of this machine and how this could impact points for donors.
Benchmark philosophy
Our philosophy is pretty simple: we would like to standardize benchmarks to a single machine and standardize and simplify the bonus schemes now employed. Bonuses have played a key role in aligning points with science and we will continue to use them. For example, returning work units (WUs) promptly can be very important for the science we’re doing, so we provide bonuses for this, especially with the high performance clients.
Machines used in comparison
We chose a 2.2 GHz E6600 as the prototype dual-core machine and a Q6600 at either 2.4 GHz or 3.2 GHz as the prototype quad-core.
The new benchmark machine is a Core i5-750 with Turbo Mode off. We compare single-core performance to the old benchmark machine, a 2.8 GHz Pentium 4.
FAH Projects used in the comparison
We base comparisons to the single-core benchmark machine on projects 4442 and 6315, comparing single-core speed on the 2.8 Ghz Pentium 4 to ideal quad-core speed on the 2.6 Ghz Core i5 machine.
We base comparisons to quad-core machines on project 2671.
We base comparisons to dual-core machines on project 6012.
Results.
Machine: Performance relative to Core i5:
P4 2.8 0.098 (on project 4442)
P4 2.8 0.12 (on project 6315)
E6600 0.30
Q6600-3.2 1.1
Q6600-2.4 0.82
Based on these multiplicative speed factors, we can project ppd output based on either the A1 or the A2 benchmarking standards.
Machine: A1 ppd: A2 ppd:
E6600 521 1663
Q6600-3.2 1933 6172
Q6600-2.4 1450 4629
Bonus point formula
Briefly summarizing our bonus formula, the bonus is applied for users who have a passkey, have successfully returned at least 10 bonus-eligible WU's, successfully return >=80% of assigned WU's, and return the WU before the preferred deadline. Bonus points do not apply to partial returns.
Our bonus formula calculates final points as follows:
final_points = base_points * max(1,sqrt(k*deadline_length/elapsed_time))
Note that the max(1,...) ensures that final_points are never lower than base_points.
We can convert this formula to points per day as follows:
ppd = base_ppd * speed_ratio * max(1,sqrt(x*speed_ratio)),
where speed_ratio is the machine speed relative to the Core i5, and x = k * deadline_length.
Parameter determination
If we set the new quad-core base ppd to 1024 and the parameter x to 30, we get the following results:
Machine: projected ppd:
E6600 903 (greater than A1, less than A2)
Q6600-3.2 6456 (greater than A2)
Q6600-2.4 4628 (approximately equal to A2)
P4 171 (on project 4442)
P4 228 (on project 6315)
Explanation of x parameter
We may vary the deadline length between projects (some projects require fast completion and thus have short deadlines). Each project has an associated k parameter that controls the bonus points yield. We standardize k as follows:
x * speed_ratio = k * deadline_length / elapsed_time
since we can express speed_ratio as Core_i5_time / elapsed_time:
x * Core_i5_time / elapsed time = k * deadline_length / elapsed_time
therefore:
x *Core_i5_time = k * deadline_length
solving for k, we obtain:
k = x * Core_i5_time / deadline_length
and since x is set to 30,
k = 30 * Core_i5_time / deadline_length, where Core_i5_time is the time to complete a work unit on our Core i5 benchmark machine.
Summary
According to our projections, this new benchmarking standard will result in points yield for a 2.8 GHz P4 that is slightly above the typical uniprocessor values, points yield for a 2.2 GHz E6600 that is greater than typical A1 core yields but less than typical A2 core yields, points yield for a 3.2 GHz Q6600 that is greater than typical A2 yields, and additional points yield rewards for faster systems. The crossover point between A3 and A2 ppd in speed falls approximately at a 2.4 GHz Q6600.
PS some users report substantially better points yield for certain dual-core machines on the first round of SMP2 projects. These are user data rather than what we use in our benchmarking calculations, but I have included them here because they may be of interest to many:
Core 2 Duo T9300 (45nm) 2.5Ghz: 2000 PPD on projects 6012, 6014, 6015
Core 2 Duo Xeon 3075 (65nm) 2.67 Ghz: 1950 PPD on projects 6012, 6014, 6015
DPC Folding@Home hitparade van 24 januari 2010
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 93 / 3.781 (2,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)55.131[DPC]_Team_ColdFusion24.673.097(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)41.501chelloo.com33.620.466(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)22.703Blord13.975.895(5)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)22.024[DPC]NGS14.206.340(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)21.737[DPC]_Fatal_Error_Group21.198.175(3)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)16.697Z4nd3r3.011.505(18)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)9.278ziggo-gebruikers.nl3.578.249(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)8.715Oever771.658.543(30)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)7.938Schapie6.639.377(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.762R0SSI860.924(49)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)7.681Bogaarts6.193.455(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.567DeApen7.801.450(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)5.142Hog555595.941(64)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)4.339KroontjesPen1.336.646(39)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.876DPC_Division_Brabant3.297.930(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.840[NL]hmmr69.822(342)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)3.840roen2000309.711(107)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif37)3.802qu8ne.be7.256(1100)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)3.525empy906.619(46)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif39)3.495TEAM_JOE_BAR11.121.637(6)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.331DPC_Los_Alcoholicos2.196.242(25)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)3.328Caseman-nl1.350.817(38)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.051Djenz15301.709(112)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)2.958gowron5.424.935(11)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.939jeroenathome305.192(110)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.921DinKeyToy13.477(837)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)2.191Pietertje1.921.636(27)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)2.174Empie771.320(57)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.165Big_Basje2.929.870(20)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)2.118Banaan87188.788(169)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.620.466chelloo.com41.501(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.673.097[DPC]_Team_ColdFusion55.131(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.198.175[DPC]_Fatal_Error_Group21.737(5)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.206.340[DPC]NGS22.024(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.975.895Blord22.703(3)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.121.637TEAM_JOE_BAR3.495(20)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.801.450DeApen5.567(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.022.703Team4Fun.nl0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.639.377Schapie7.938(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.193.455Bogaarts7.681(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.424.935gowron2.958(24)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.643.995Team_Pastis_51895(57)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.982.096Pulp_Fiction0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.745.393Team_Elteor_Borislavj0(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.578.249ziggo-gebruikers.nl9.278(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.297.930DPC_Division_Brabant3.876(15)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.064.820Holy_Cow!897(56)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.011.505Z4nd3r16.697(6)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.948.443[DPC]Clan_Delft1.680(35)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.929.870Big_Basje2.165(29)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.868.664BPE0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.500.679Wiethoofd0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.231.183DPC_Team_Switch0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.213.450[DPC]Jaac0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.196.242DPC_Los_Alcoholicos3.331(21)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.164.699PeaceNlove1.392(40)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.921.636Pietertje2.191(27)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.814.323www.onweer-online.nl0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.785.993PS3251(82)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.658.543Oever778.715(8)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.640.680folding@evga1.904.464.261(2)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)401.566Ukraine263.849.091(35)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)392.298Fórum PCs Brasil217.810.728(45)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)381.147China Folding@Home Power176.716.931(52)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)358.595Overclockers Club243.217.275(39)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)357.437PC Perspective Folding Frogs (734)430.087.926(18)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)353.822whoopass324.420.222(29)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)353.185bitGAMER + Underground Gamer Folding116.218.190(79)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)338.307Dutch Power Cows313.146.513(33)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)334.869DSL Reports Team Helix323.579.190(30)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif15)326.968Calguns37.693.105(164)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)313.547Vietnam Global Team196.704.636(50)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)278.908TeamUbuntu132.521.305(67)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)276.967Team Icrontic.com332.792.511(28)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)272.894AMD Zone110.743.228(83)
52.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)270.724CHIP Indonesia Folding Fellow140.875.036(65)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.036.107.554Maximum PC Magazine2.938.101(3)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.032.845Hardware.no752.231(17)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.142.026Team 2ch656.006(20)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)332.792.511Team Icrontic.com276.967(50)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.420.222whoopass353.822(43)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.579.190DSL Reports Team Helix334.869(46)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.116.653Team RSF544.206(27)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.828.876Team Engadget191.331(67)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.146.513Dutch Power Cows338.307(45)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)303.876.558fold4life.com565.255(25)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.849.091Ukraine401.566(38)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.723.416OcUK466.450(32)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)257.171.251ABXZone.com160.174(81)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)257.102.657The Folding Wolves434.497(35)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.217.275Overclockers Club358.595(41)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)236.851.866Hardware Canucks Forum1.126.828(11)
More...
Megaflush Top 5
posTeamFlushDate
1.Team4Fun.nl202.70005-12-2005
2.chelloo.com172.70222-11-2009
3.markvanmook116.99631-10-2006
4.Blord91.06724-06-2009
5.[DPC]_Team_ColdFusion89.74927-01-2008
More...
Mijlpalen
DeApen7.800.000
Z4nd3r3.000.000
Djenz15300.000
oehoe5.000
qu8ne.be5.000
Folding@Home Links
Folding@Home webpage
Folding@Home forum
DPCH Suggestiepagina
DPC FAQ
Bron
[ Voor 13% gewijzigd door smoking2000 op 25-01-2010 06:58 . Reden: Nieuws ]
  • iisschots
  • Laatst online: 31-10 18:21
Is het al weer week 4. Het gaat maar weer snel :)
*titelfix ;)
Hackerspace in Friesland | www.frack.nl | Bezig met opzetten, help mee!
  • Rubeo38
bedankt voor de stats smoking :)
deze week ga ik eens een klein aanvalletje doen op de top30, het moet er nu toch maar eens van komen,
en als ik het deze week niet red eet ik met schoen op! :P
vanmiddag als ik thuiskom gaat mijn pc aan, en gaat vrijdagochtend ofzo pas weer uit, even kijken wat mijn videokaart nu echt kan doen!
oja, mijn doel is om tot ongeveer 35000 punten te komen (sta nu op ruim 19.000) :D
[ Voor 11% gewijzigd door Rubeo38 op 25-01-2010 09:18 ]
  • smoking2000
smoking2000
DPC-Crew
  • Wiethoofd
Wiethoofd
Broadcast TOM
* Wiethoofd komt even de 7.8M mijlpaal voor DeApen ophalen. Bijna 6k daily met een enkele 8800GTS 512MB is zeker niet verkeerd :>
  • Rubeo38
vandaag weer een nieuwe dag voor verse stats!
ik zit helaas ziek thuis, begon vannacht over te geven :( maarja het gaat nu een stuk beter ik eet alweer en ga als het zo door gaat morgen weer gewoon werken!
wat valt er over de stats van vandaag te zeggen?
dat Coldfusion nog een tandje bijzet op weg naar de 75.000 per dag, strakke output mensen!
FvdD is kluis! met maar liefst 53 plaatsen winst.
ook in de daily stijgen we weer een paar plekjes, volhouden en doorgaan mannen!
ook vandaag weer een paar prachtige mijlpalen!
ik hou er zelf 1 hier om in de achtertuin te zetten :)
Bogaarts 6.200.000
DPC_Division_Brabant 3.300.000
rduppen 800.000
Hog555 600.000
Koe-tsie 300.000
Rubeo 20.000
Rant64 500
en ons nieuwe lid Rant64 pak ook gelijk een mijlpaal en dus een heel hartelijk welkom Rant! *O*
DPC Folding@Home hitparade van 25 januari 2010
Daily Top 30
Flushers: 105 / 3.782 (2,8 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)73.899[DPC]_Team_ColdFusion24.746.996(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)38.644chelloo.com33.659.110(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)27.258[DPC]_Fatal_Error_Group21.225.433(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)24.544Blord14.000.439(5)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)20.978[DPC]NGS14.227.318(4)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)16.076ziggo-gebruikers.nl3.594.325(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)14.076Z4nd3r3.025.581(18)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.465Oever771.669.008(30)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)10.312R0SSI871.236(49)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)9.513Schapie6.648.890(9)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.279Bogaarts6.201.734(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)7.104silentsnake1.358.381(37)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)6.321KroontjesPen1.342.967(39)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)5.125BGB4rn471.933(73)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.929DPC_Division_Brabant3.302.859(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.704Hog555600.645(63)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.155DeApen7.805.605(7)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.840HerrBohm1.582.926(32)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)3.840rduppen800.640(53)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.840roen2000313.551(106)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif53)3.744Kluis991.539(44)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.425gowron5.428.360(11)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.883Pietertje1.924.519(27)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)2.881-Niels-217.907(148)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.547Caseman-nl1.353.364(38)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.272DPC_Los_Alcoholicos2.198.514(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)2.262Kawarez17.313(734)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)2.195marcelvanwensveen35.115(528)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)2.195qu8ne.be9.451(988)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif44)2.137----=Mr.D=----15.660(776)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.659.110chelloo.com38.644(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.746.996[DPC]_Team_ColdFusion73.899(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.225.433[DPC]_Fatal_Error_Group27.258(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.227.318[DPC]NGS20.978(5)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.000.439Blord24.544(4)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.123.209TEAM_JOE_BAR1.572(43)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.805.605DeApen4.155(17)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.648.890Schapie9.513(10)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.201.734Bogaarts8.279(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.428.360gowron3.425(22)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.644.742Team_Pastis_51747(60)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.594.325ziggo-gebruikers.nl16.076(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.302.859DPC_Division_Brabant4.929(15)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.065.156Holy_Cow!336(81)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.025.581Z4nd3r14.076(7)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.950.237[DPC]Clan_Delft1.794(40)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.931.790Big_Basje1.920(32)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.198.514DPC_Los_Alcoholicos2.272(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.165.467PeaceNlove768(54)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.924.519Pietertje2.883(23)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.786.329PS3336(83)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.669.008Oever7710.465(8)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.534.371folding@evga1.911.998.632(2)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)470.467Richard Dawkins Foundation for Reason and Science40.188.879(154)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)455.686China Folding@Home Power177.172.617(52)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)451.955SAGoons476.899.726(16)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)443.627The Folding Wolves257.546.284(37)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)404.945PC Perspective Folding Frogs (734)430.492.871(18)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)401.213Ukraine264.250.304(35)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)395.559whoopass324.815.781(29)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)381.061Dutch Power Cows313.527.574(33)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)368.685Vietnam Global Team197.073.321(50)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)355.478AMD Zone111.098.706(83)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)354.150DSL Reports Team Helix323.933.340(30)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)338.867MozillaZine149.802.654(62)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)331.513bitGAMER + Underground Gamer Folding116.549.703(79)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)327.814OcUK264.051.230(36)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)320.890CHIP Indonesia Folding Fellow141.195.926(65)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.038.895.279Maximum PC Magazine2.787.725(3)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.897.833Hardware.no864.988(17)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.712.967Team 2ch570.941(28)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)333.101.626Team Icrontic.com309.115(50)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.815.781whoopass395.559(41)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.933.340DSL Reports Team Helix354.150(45)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.700.518Team RSF583.865(26)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.084.793Team Engadget255.917(63)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.527.574Dutch Power Cows381.061(42)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)304.532.572fold4life.com656.014(23)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.250.304Ukraine401.213(40)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.051.230OcUK327.814(48)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)257.546.284The Folding Wolves443.627(38)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)257.357.026ABXZone.com185.775(73)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.722.584Overclockers Club505.309(31)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)237.904.102Hardware Canucks Forum1.052.236(12)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Bogaarts6.200.000
DPC_Division_Brabant3.300.000
rduppen800.000
Hog555600.000
Koe-tsie300.000
Rubeo20.000
Rant64500
Nieuwe Leden
Rant64384
Folding@Home Links
Folding@Home forum
DPC FAQ
Bron
  • Bubbles
Bubbles
DPC-Crew
2 the resQ
Hey, nog geen stats! Let's fix that. :)
Opvallende dingen? empy dendert met 81 plaatsen winst de daily top30 in. En er zijn nog een stel mijlpalen te verdelen. De volgende poster mag daar de honeurs voor waarnemen . :P
:w
DPC Folding@Home hitparade van 26 januari 2010
Daily Top 30
Flushers: 93 / 3.782 (2,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)61.175[DPC]_Team_ColdFusion24.808.171(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)35.901chelloo.com33.695.011(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)26.023[DPC]_Fatal_Error_Group21.251.456(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)22.211Blord14.022.650(5)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.712[DPC]NGS14.246.030(4)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)11.055Z4nd3r3.036.636(18)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)10.551ziggo-gebruikers.nl3.604.876(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)10.473Bogaarts6.212.207(10)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)8.427Schapie6.657.317(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)8.268Oever771.677.276(30)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)7.127silentsnake1.365.508(37)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)5.690DeApen7.811.295(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)5.345Pietertje1.929.864(27)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.509R0SSI875.745(49)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)4.287gowron5.432.647(11)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)4.176HerrBohm1.587.102(32)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.156DPC_Division_Brabant3.307.015(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.070KroontjesPen1.347.037(39)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)3.840[NL]hmmr75.582(330)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)3.340Big_Basje2.935.130(20)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif81)3.172empy910.016(46)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)3.066Rubeo23.640(635)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.696Kluis994.235(44)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.594qu8ne.be12.045(889)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.589-Niels-220.496(148)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)2.435TEAM_JOE_BAR11.125.644(6)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.391DPC_Los_Alcoholicos2.200.905(25)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)2.308A_dJ154.046(198)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif37)2.174Geert_Zandman169.154(182)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.920Thaan113.974(252)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.695.011chelloo.com35.901(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.808.171[DPC]_Team_ColdFusion61.175(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.251.456[DPC]_Fatal_Error_Group26.023(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.246.030[DPC]NGS18.712(5)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.022.650Blord22.211(4)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.125.644TEAM_JOE_BAR2.435(26)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.811.295DeApen5.690(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.657.317Schapie8.427(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.212.207Bogaarts10.473(8)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.432.647gowron4.287(15)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.645.126Team_Pastis_51384(73)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.604.876ziggo-gebruikers.nl10.551(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.307.015DPC_Division_Brabant4.156(17)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.066.167Holy_Cow!1.011(43)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.036.636Z4nd3r11.055(6)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.951.480[DPC]Clan_Delft1.243(39)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.935.130Big_Basje3.340(20)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.215.240[DPC]Jaac1.790(33)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.200.905DPC_Los_Alcoholicos2.391(27)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.165.467PeaceNlove0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.929.864Pietertje5.345(13)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.786.554PS3225(88)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.677.276Oever778.268(10)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.800.270folding@evga1.916.798.902(2)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)350.229Ukraine264.600.533(35)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)344.887DSL Reports Team Helix324.278.227(30)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)344.280Calguns38.322.227(162)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)344.189The Folding Wolves257.890.473(37)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)343.445Team Rage3D544.665.140(13)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)338.844PC Perspective Folding Frogs (734)430.831.715(18)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)334.790Overclockers Club244.057.374(39)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)326.383Dutch Power Cows313.853.957(33)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)325.476OcUK264.376.706(36)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)312.887whoopass325.128.668(29)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)306.931Macrumors.com - Team Folding158.274.248(55)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)284.077DarkSwarm52.694.318(128)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)275.586TechIMO102.726.149(86)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif29)274.184Team Geekdo46.377.899(141)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)243.006CHIP Indonesia Folding Fellow141.438.932(65)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.041.490.093Maximum PC Magazine2.594.814(3)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)359.607.758Hardware.no709.925(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.308.205Team 2ch595.238(22)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)333.327.028Team Icrontic.com225.402(57)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.128.668whoopass312.887(46)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.278.227DSL Reports Team Helix344.887(38)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.174.710Team RSF474.192(26)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.273.571Team Engadget188.778(65)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.853.957Dutch Power Cows326.383(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.058.155fold4life.com525.583(23)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.600.533Ukraine350.229(37)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.376.706OcUK325.476(45)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)257.890.473The Folding Wolves344.189(40)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)257.522.857ABXZone.com165.831(71)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.057.374Overclockers Club334.790(43)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)238.867.240Hardware Canucks Forum963.138(12)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
ziggo-gebruikers.nl3.600.000
DPC_Los_Alcoholicos2.200.000
www.opmaatjes.nl50.000
qu8ne.be10.000
Rant641.000
Folding@Home Links
Folding@Home forum
DPC FAQ
Bron
Vouw mee bij Fatal Error Group! - F@H: #8
  • SandStar
  • Laatst online: 14:33
SandStar
DPC-Crew
Zandster
Volgens mij nog niet eerder gemeld maar met de komst van de nieuwe SMP2 client en A3 core is er geen voordeel meer om te kloten met linux vm's.
Er wordt zelf gezegd dat de windows A3 core momenteel ietsjes sneller is.
Probeer het uit zou ik zeggen :)
  • BGB4rn
  • Laatst online: 27-11 09:33
BGB4rn
ductape en tie-wraps FTW !
Het is misschien al een keer voorbij gekomen maar hoe komt dit probleem en hoe valt het op te lossen voor zo ver het een probleem is ?
Afbeeldingslocatie: http://tweakers.net/ext/f/XpxqTKuaKzCapkhpPMxdtkO5/full.png
In de grafiek is dus te zien dat de client hem niet 100% van de tijd gebruikt, mij lijkt dat erg raar gezien mijn 8800gts wel gewoon zonder spikes draait.
Signature
  • emphasis
  • Laatst online: 04-11 14:59
emphasis
Mooooohh!!!
Toevallig een cpu en gpu client naast elkaar draaien?
In dat geval kan de cpu in de weg zitten, waardoor de gpu niet van genoeg werk voorzien kan worden, iets dat je op kan lossen door de gpu een hoger prioriteit te geven (tijdens de config van de client prio op low zetten ipv idle).
Hopelijk heb je daar wat aan.
________________-=Team ColdFusion=-______________
  • BGB4rn
BGB4rn
Ok, ik zal eens kijken, wat ik nog steeds raar vind is dat de 8800gts die in het zelfde systeem zit wel gewoon full load draait.
Ik kijk wel of het uitmaakt.
Signature
  • R0SSI
Ik heb dit ook met 1 bepaald project, die projecten die 1888 aan punten opleveren hebben dat stuiter effect :S
Gamertag for Xbox: R0SSI
  • Rubeo38
precies hetzelfde als hierboven, alleen met de 1888 punten projecten
8800 GTS trouwens ;) in een eerder stadium had ik hier ook al wat over gevraagd :)
  • Bubbles
Bubbles
DPC-Crew
2 the resQ
SandStar schreef op woensdag 27 januari 2010 @ 16:53:
Ik draai momenteel een stel A3 core units met bonusmogelijkheden in 2 VM's op 1 bak. Puntentechnisch maakt het in mijn geval praktisch niets uit (als in, ik ga er niet op voor- of achteruit door die wu's te draaien), als ik het grof na tel. Hoe het op native windows presteert zou ik moeten proberen. Ik weet dat voorheen met 1 SMP client in windows, ik rond de 2000 PPD zat, terwijl ik met 2 Linux VM's op zo'n 3500PPD uitkwam.
  • jeroenathome
  • Laatst online: 14:17
jeroenathome
Een regel tekst
Ik was al gewend om bij Rosetta@home elke dag de stats te posten. Vandaag had ik onverwachts vrijaf bij Rosetta@home en dus kijk ik maar eens hier in de lijsten. Helaas was niemand tot nu toe instaat om de lijsten van gisteren even te plaatsen. Dit is toch gek want er is veel gebeurt als je de lijsten na kijkt.
Er is een nieuwe binnenkomer en dat is :w Turbo boy :w . Hij heeft al zo hard gewerkt voor ons dat hij zijn eerste mijlpaal al kan ophalen bij het centraal magazijn. In totaal zijn er 7 mijlpalen behaald en de grootste is 50.000 punten waard. Het is wel verwonderlijk dat een rampenmeester deze paal heeft gehaald, want je zou verwachten dat zijn PC crashed vlak voordat de mijlpaal gehaald zou worden. Ook voor de andere mijlpalen geven we een klein feestje *O* want elke paal is er een.
In de daily lijst is pas de eerste verandering te vinden op plek 4 en er zijn enkele grote stijgers te vinden in de top 30. De grootste stijger is Renkvs :Y . Die het voor elkaar krijgt om 60 plaatsen te stijgen. Kawarez, Hog555 en caseman volgen op enige afstand in de stijgers lijst. Een van deze 3 mag dan de Fotd award vandaag dragen. Ze vechten in de ring maar om wie het wordt. In de tussen tijd wel de PC aan laten anders wordt je een van de grootse dalers voor morgen.
Voor meer weetjes kijk hieronder.
DPC Folding@Home hitparade van 27 januari 2010
Daily Top 30
Flushers: 99 / 3.783 (2,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)74.224[DPC]_Team_ColdFusion24.882.395(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)42.232chelloo.com33.737.243(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)28.613[DPC]_Fatal_Error_Group21.280.069(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)24.685[DPC]NGS14.270.715(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)22.599Blord14.045.249(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.669Z4nd3r3.051.305(18)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.450ziggo-gebruikers.nl3.616.326(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)9.560Oever771.686.836(30)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.420Schapie6.666.737(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)8.976Bogaarts6.221.183(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.944silentsnake1.372.452(37)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.931DeApen7.817.226(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)5.653DPC_Division_Brabant3.312.668(16)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)5.593rduppen807.986(51)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)5.282KroontjesPen1.352.319(39)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)4.508Hog555606.054(63)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)4.125Rubeo27.765(587)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)4.006R0SSI879.751(49)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.840HerrBohm1.590.942(32)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)3.758Caseman-nl1.358.294(38)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)3.100-Niels-223.596(148)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)3.038[DPC]Jaac2.218.278(24)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.908DPC_Los_Alcoholicos2.203.813(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)2.715gowron5.435.362(11)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)2.424Pietertje1.932.288(27)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.361TEAM_JOE_BAR11.128.005(6)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)2.296Holy_Cow!3.068.463(17)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)2.271Kawarez20.132(691)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif60)2.096renkvs171.546(181)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)2.019[DPC]Clan_Delft2.953.499(19)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.737.243chelloo.com42.232(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.882.395[DPC]_Team_ColdFusion74.224(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.280.069[DPC]_Fatal_Error_Group28.613(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.270.715[DPC]NGS24.685(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.045.249Blord22.599(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.128.005TEAM_JOE_BAR2.361(26)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.817.226DeApen5.931(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.666.737Schapie9.420(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.221.183Bogaarts8.976(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.435.362gowron2.715(24)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.645.126Team_Pastis_510(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.616.326ziggo-gebruikers.nl11.450(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.312.668DPC_Division_Brabant5.653(13)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.068.463Holy_Cow!2.296(27)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.051.305Z4nd3r14.669(6)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.953.499[DPC]Clan_Delft2.019(30)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.937.050Big_Basje1.920(34)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.218.278[DPC]Jaac3.038(22)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.203.813DPC_Los_Alcoholicos2.908(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.167.084PeaceNlove1.617(38)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.932.288Pietertje2.424(25)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.814.548www.onweer-online.nl225(98)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.787.141PS3587(65)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.686.836Oever779.560(8)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.802.408folding@evga1.922.601.310(2)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)432.652Hewlett Packard156.614.432(57)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)418.024PC Perspective Folding Frogs (734)431.249.739(18)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)409.705whoopass325.538.373(29)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)405.164Team Rage3D545.070.304(13)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)404.039Calguns38.726.266(162)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)394.715Ukraine264.995.248(35)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)391.982SAGoons477.735.548(16)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)373.865Dutch Power Cows314.227.822(33)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)364.363SilentPCReview Folding@Home198.830.677(48)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)359.824AMD Zone111.665.654(83)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)348.753DSL Reports Team Helix324.626.980(30)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif15)329.327MozillaZine150.546.722(62)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)323.023Portugal@Folding198.079.213(49)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)314.813Richard Dawkins Foundation for Reason and Science40.917.089(153)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)308.508TeamUbuntu133.314.436(67)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.044.513.564Maximum PC Magazine3.023.471(4)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)360.418.784Hardware.no811.026(20)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.931.685Team 2ch623.480(25)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)333.614.822Team Icrontic.com287.794(53)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.538.373whoopass409.705(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.626.980DSL Reports Team Helix348.753(47)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.742.040Team RSF567.330(27)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.530.085Team Engadget256.514(59)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.227.822Dutch Power Cows373.865(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.681.644fold4life.com623.489(24)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.995.248Ukraine394.715(42)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.824.445OcUK447.739(35)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)258.339.643The Folding Wolves449.170(34)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)257.742.701ABXZone.com219.844(71)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.360.292Overclockers Club302.918(52)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)240.064.092Hardware Canucks Forum1.196.852(10)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Disaster_Master50.000
Kawarez20.000
abiesh2.000
Stef421.000
Turbo_boy1.000
nldijk881.000
Lmax500
Nieuwe Leden
Turbo_boy511
Folding@Home Links
Folding@Home forum
DPC FAQ
Bron
Ik rij voor mijn plezier en ben niet op de vlucht.
  • KaWaReZ
  • Laatst online: 16-10 11:51
jeuj 20k gepasseerd
  • Rubeo38
En vandaag weer eens vroege stats!
Zo,
Koffie... check
flesje water.... check
ik ben er weer helemaal klaar voor, een dagje werken.
nouja dagje, vanmiddag ook weer lekker vroeg naar huis :)
vandaag blijft de gehele top8 krampachtig staan waar ze gisteren ook stonden.
vandaag is ook de 3e achtereenvolgende dag dat ik in de daily top30 sta! ik ben zeer tevreden met mijn uitprobeerseltje om hem eens de hele dag te laten draaien, ook de verwarming hoefde ik niet zo hoog te zetten als normaal. helaas is het ook na vandaag afgelopen met mijn hoge productie ;)
Turbo_Boy doet zijn naam eer aan en krijgt de FvdD prijs vandaag :)
vandaag ook een paar hele mooie mijlpalen (ik dacht dat 30.000 ook een mijlpaal was? dan moet ik hem maar zelf in elkaar freubelen :P )
BananaTeam 1.400.000
heintjeput 300.000
JeffreyH 5.000
helaas geen nieuwe leden -O-
DPC Folding@Home hitparade van 28 januari 2010
Daily Top 30
Flushers: 98 / 3.783 (2,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)62.116[DPC]_Team_ColdFusion24.944.511(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)45.708chelloo.com33.782.951(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)26.116[DPC]_Fatal_Error_Group21.306.185(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.291[DPC]NGS14.295.006(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)20.062Blord14.065.311(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.465Z4nd3r3.066.770(18)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.920ziggo-gebruikers.nl3.628.246(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.836Oever771.696.672(30)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)9.083Bogaarts6.230.266(10)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)7.767R0SSI887.518(49)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.368silentsnake1.378.820(37)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.866DeApen7.823.092(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)5.069KroontjesPen1.357.388(39)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.808Schapie6.671.545(9)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)4.085Big_Basje2.941.135(20)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.064rduppen812.050(51)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.037Rubeo31.802(552)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.975gowron5.439.337(11)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.840HerrBohm1.594.782(32)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.779Caseman-nl1.362.073(38)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)3.680[NL]hmmr81.182(319)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)3.649BGB4rn478.567(73)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)3.292nitro4u1.497.659(34)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.221TEAM_JOE_BAR11.131.226(6)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)2.684DPC_Division_Brabant3.315.352(16)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.594Banaan87191.382(169)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)2.510Turbo_boy3.916(1401)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.436marcelvanwensveen37.551(511)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.392Pietertje1.934.680(27)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)2.253-Niels-225.849(146)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.782.951chelloo.com45.708(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.944.511[DPC]_Team_ColdFusion62.116(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.306.185[DPC]_Fatal_Error_Group26.116(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.295.006[DPC]NGS24.291(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.065.311Blord20.062(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.131.226TEAM_JOE_BAR3.221(24)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.823.092DeApen5.866(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.671.545Schapie4.808(14)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.230.266Bogaarts9.083(9)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.439.337gowron3.975(18)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.628.246ziggo-gebruikers.nl11.920(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.315.352DPC_Division_Brabant2.684(25)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.070.499Holy_Cow!2.036(31)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.066.770Z4nd3r15.465(6)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.954.732[DPC]Clan_Delft1.233(46)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.941.135Big_Basje4.085(15)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.219.941[DPC]Jaac1.663(38)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.205.302DPC_Los_Alcoholicos1.489(42)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.168.365PeaceNlove1.281(45)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.934.680Pietertje2.392(29)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.814.548www.onweer-online.nl0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.788.642PS31.501(41)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.696.672Oever779.836(8)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.075.857folding@evga1.928.677.167(2)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)423.369Team Rage3D545.493.673(13)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)422.482PC Perspective Folding Frogs (734)431.672.221(18)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)419.938Vietnam Global Team197.973.692(50)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)411.796Ukraine265.407.044(35)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)390.262Calguns39.116.528(159)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)385.680whoopass325.924.053(29)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)368.464MozillaZine150.915.186(62)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)360.914Dutch Power Cows314.588.736(33)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)353.337DSL Reports Team Helix324.980.317(30)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)350.476Hewlett Packard156.964.908(57)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)323.752OcUK265.148.197(36)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)291.627Team Icrontic.com333.906.449(28)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)288.185SilentPCReview Folding@Home199.118.862(48)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)283.242DarkSwarm53.187.683(126)
52.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)283.119Russia203.840.331(47)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.047.358.007Maximum PC Magazine2.844.443(4)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)361.200.207Hardware.no781.423(19)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.633.219Team 2ch701.534(21)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)333.906.449Team Icrontic.com291.627(49)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.924.053whoopass385.680(43)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.980.317DSL Reports Team Helix353.337(46)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.406.462Team RSF664.422(24)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.808.879Team Engadget278.794(53)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.588.736Dutch Power Cows360.914(45)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.276.230fold4life.com594.586(26)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)265.407.044Ukraine411.796(41)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)265.148.197OcUK323.752(48)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)258.814.628The Folding Wolves474.985(34)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)257.948.599ABXZone.com205.898(71)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.632.980Overclockers Club272.688(56)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)241.103.782Hardware Canucks Forum1.039.690(13)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
BananaTeam1.400.000
heintjeput300.000
JeffreyH5.000
Folding@Home Links
Folding@Home forum
DPC FAQ
Bron
  • smoking2000
smoking2000
DPC-Crew
Rubeo38 schreef op vrijdag 29 januari 2010 @ 05:46:
Dat is zeker vroeg, thanks! d:)b
  • smoking2000
smoking2000
DPC-Crew
In navolging van Rubeo38 weer vroege stats, maar dan van mijn hand. Want ik kan vieren dat ik eindelijk weer een nieuwe versie van mijn FAH client monitor FCI heb uitgebracht. *O*
*O* We doen meteen nog maar en dansje, en wel voor de konijnen van NGS die vandaag FEG van de #3 hebben verdreven -O- TCF en chelloo.com houden hun plaats nog vier vast.
Afbeeldingslocatie: http://linuxminded.nl/tmp/daily-top.png
renkvs is de grootste stijger en daarmee FvdD d:)b
Afbeeldingslocatie: http://linuxminded.nl/tmp/daily-top-delta.png
In de overall pakt Z4nd3r een plekje ten koste van Holy_Cow!
Afbeeldingslocatie: http://linuxminded.nl/tmp/overall-top-delta.png
Afbeeldingslocatie: http://linuxminded.nl/tmp/overall-top.png
Mijlpalen zijn er vandaag voor maarliefst 9 gelukkigen.
Op het ere podium, de XL palen:
Afbeeldingslocatie: http://linuxminded.nl/tmp/milstones-xl.png
En de nog altijd forse L palen:
Afbeeldingslocatie: http://linuxminded.nl/tmp/milstones-l.png
DPC Folding@Home hitparade van 29 januari 2010
Daily Top 30
Flushers: 105 / 3.783 (2,8 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)65.640[DPC]_Team_ColdFusion25.010.151(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)51.579chelloo.com33.834.530(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)37.863[DPC]NGS14.332.869(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)32.082[DPC]_Fatal_Error_Group21.338.267(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)27.030Blord14.092.341(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)17.702ziggo-gebruikers.nl3.645.948(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)13.140Schapie6.684.685(9)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)12.433Z4nd3r3.079.203(17)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.437Bogaarts6.241.703(10)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)10.114Oever771.706.786(30)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)8.016HerrBohm1.602.798(32)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)7.680rduppen819.730(50)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)6.005Big_Basje2.947.140(20)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)5.971Hog555613.790(63)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)5.971R0SSI893.489(49)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)5.880KroontjesPen1.363.268(39)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)5.590nitro4u1.503.249(33)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)5.093silentsnake1.383.913(37)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)5.023Pietertje1.939.703(27)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.514Caseman-nl1.366.587(38)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)4.359DPC_Los_Alcoholicos2.209.661(25)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)4.125qu8ne.be16.170(766)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.040Banaan87195.422(165)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.741-Niels-229.590(143)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)3.340roen2000318.811(104)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif32)3.292renkvs175.574(178)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.033DPC_Division_Brabant3.318.385(16)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.896BGB4rn481.463(72)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)2.790Kluis999.305(44)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)2.692Kawarez24.572(625)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.834.530chelloo.com51.579(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.010.151[DPC]_Team_ColdFusion65.640(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.338.267[DPC]_Fatal_Error_Group32.082(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.332.869[DPC]NGS37.863(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.092.341Blord27.030(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.132.576TEAM_JOE_BAR1.350(51)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.823.092DeApen0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.684.685Schapie13.140(7)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.241.703Bogaarts11.437(9)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.440.633gowron1.296(52)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.647.170Team_Pastis_512.044(36)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.645.948ziggo-gebruikers.nl17.702(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.318.385DPC_Division_Brabant3.033(27)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.079.203Z4nd3r12.433(8)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.072.179Holy_Cow!1.680(44)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.956.609[DPC]Clan_Delft1.877(40)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.947.140Big_Basje6.005(13)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.219.941[DPC]Jaac0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.209.661DPC_Los_Alcoholicos4.359(21)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.169.646PeaceNlove1.281(53)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.939.703Pietertje5.023(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.790.464PS31.822(41)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.706.786Oever7710.114(10)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.833.399folding@evga1.935.510.566(2)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)472.224Hewlett Packard157.437.132(57)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif20)467.183Poland219.903.800(46)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)460.083DSL Reports Team Helix325.440.400(30)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif36)457.053AMD Zone112.294.601(83)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)447.694MozillaZine151.362.880(62)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)442.297Ukraine265.849.341(35)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)441.412whoopass326.365.465(29)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)440.351Dutch Power Cows315.029.087(33)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)433.009bitGAMER + Underground Gamer Folding118.320.931(78)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)409.290Legit Reviews121.085.852(73)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)391.309Calguns39.507.837(157)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)382.255Portugal@Folding198.695.650(49)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)375.076TeamUbuntu133.959.882(67)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)368.512Team Icrontic.com334.274.961(28)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)360.530SilentPCReview Folding@Home199.479.392(48)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.050.791.311Maximum PC Magazine3.433.304(3)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)362.123.259Hardware.no923.052(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)359.324.593Team 2ch691.374(22)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)334.274.961Team Icrontic.com368.512(50)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.365.465whoopass441.412(43)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.440.400DSL Reports Team Helix460.083(39)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.049.801Team RSF643.339(25)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.098.128Team Engadget289.249(56)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.029.087Dutch Power Cows440.351(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.889.952fold4life.com613.722(28)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)265.849.341Ukraine442.297(42)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)265.646.075OcUK497.878(34)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)259.320.582The Folding Wolves505.954(33)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)258.203.906ABXZone.com255.307(69)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.910.267Overclockers Club277.287(60)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)242.476.257Hardware Canucks Forum1.372.475(10)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Oever771.700.000
HerrBohm1.600.000
nitro4u1.500.000
Energya20.000
JoTo10.000
Turbo_boy5.000
PhWolf2.000
Rant642.000
Folding@Home Links
Folding@Home forum
DPC FAQ
Bron
| [Folding@Home] Announce: Client monitor voor Linux (fci) | fci-1.8.4 | Fatal Error Group |
  • LXXI
En 25M is geen mijlpaal :? Mooi is dat :P
Maar tnx voor de vroege stats :)
  • Bubbles
  • Laatst online: 27-11 13:06
Bubbles
DPC-Crew
2 the resQ
Helaas worden er na de 10M geen palen meer uitgedeeld
  • LXXI
Arme wij... want de oude zijn in deze winter allang opgestookt :+
  • Wiethoofd
  • Laatst online: 30-09 23:41
Wiethoofd
Broadcast TOM
Had ik helemaal besloten vroeg op te staan voor een hitparade en m'n verhaaltje in grote lijnen al uitgedacht is smoking me gewoon een ruime 8 uur voor, ach, morgen weer een kans :>
  • MetalfanBlackness
MetalfanBlackness
♥ PV & SB ♥
Laatste stats van deze week, ik hoop dat jullie er veel plezier aan zullen beleven.
FotD is Legolas.
DPC Folding@Home hitparade van 30 januari 2010
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 100 / 3.785 (2,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)58.570[DPC]_Team_ColdFusion25.068.721(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)45.305chelloo.com33.879.835(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)34.123[DPC]NGS14.366.992(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)29.427[DPC]_Fatal_Error_Group21.367.694(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.056Blord14.115.397(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)14.283Schapie6.698.968(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)14.125Z4nd3r3.093.328(17)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)13.947ziggo-gebruikers.nl3.659.895(15)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)9.051Oever771.715.837(30)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)7.933silentsnake1.391.846(37)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)7.506Bogaarts6.249.209(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.580DeApen7.829.672(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)6.087nitro4u1.509.336(33)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)5.600[NL]hmmr88.702(299)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.104KroontjesPen1.368.372(39)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.313Hog555618.103(63)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)3.840Big_Basje2.950.980(20)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)3.840rduppen823.570(50)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif40)3.377Legolas364.416(89)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.143qu8ne.be19.313(701)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.020DPC_Division_Brabant3.321.405(16)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.020DPC_Los_Alcoholicos2.212.681(25)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.953-Niels-232.543(142)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.947Banaan87198.369(162)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.911Pietertje1.942.614(27)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.909Caseman-nl1.369.496(38)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)2.895gowron5.443.528(11)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)2.321TEAM_JOE_BAR11.134.897(6)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)2.301Empie779.629(55)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)2.267jeroenathome309.760(108)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.879.835chelloo.com45.305(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.068.721[DPC]_Team_ColdFusion58.570(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.367.694[DPC]_Fatal_Error_Group29.427(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.366.992[DPC]NGS34.123(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.115.397Blord23.056(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.134.897TEAM_JOE_BAR2.321(28)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.829.672DeApen6.580(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.022.703Team4Fun.nl0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.698.968Schapie14.283(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.249.209Bogaarts7.506(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.443.528gowron2.895(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.648.192Team_Pastis_511.022(44)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.982.096Pulp_Fiction0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.745.393Team_Elteor_Borislavj0(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.659.895ziggo-gebruikers.nl13.947(8)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.321.405DPC_Division_Brabant3.020(21)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.093.328Z4nd3r14.125(7)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.073.973Holy_Cow!1.794(35)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.957.284[DPC]Clan_Delft675(58)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.950.980Big_Basje3.840(17)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.868.664BPE0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.500.679Wiethoofd0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.231.183DPC_Team_Switch0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.212.681DPC_Los_Alcoholicos3.020(22)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.169.646PeaceNlove0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.942.614Pietertje2.911(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.791.468PS31.004(49)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.715.837Oever779.051(9)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.958.992folding@evga1.941.469.558(2)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)426.504The Folding Wolves259.747.086(37)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)424.328Calguns39.932.165(155)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)423.431OcUK266.069.506(36)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)409.876Team Rage3D546.380.833(13)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)401.103Ukraine266.250.444(35)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)388.846whoopass326.754.311(29)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)384.524DSL Reports Team Helix325.824.924(30)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)378.884Dutch Power Cows315.407.971(32)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)375.068Overclockers Club245.285.335(39)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)368.141Richard Dawkins Foundation for Reason and Science42.187.210(151)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.758TeamUbuntu134.287.640(67)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)326.555SilentPCReview Folding@Home199.805.947(48)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)307.408Macrumors.com - Team Folding159.337.610(55)
52.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)306.917Team Icrontic.com334.581.878(28)
53.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)306.587Portugal@Folding199.002.237(49)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.053.856.316Maximum PC Magazine3.065.005(3)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)364.810.539XCPUs.com1.028.783(14)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)362.928.835Hardware.no805.576(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)360.052.378Team 2ch727.785(21)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)334.581.878Team Icrontic.com306.917(52)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.754.311whoopass388.846(44)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.824.924DSL Reports Team Helix384.524(45)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.589.752Team RSF539.951(30)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)315.407.971Dutch Power Cows378.884(46)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)315.348.613Team Engadget250.485(63)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.463.513fold4life.com573.561(28)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)266.250.444Ukraine401.103(43)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)266.069.506OcUK423.431(41)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)259.747.086The Folding Wolves426.504(39)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)258.406.701ABXZone.com202.795(72)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.285.335Overclockers Club375.068(47)
More...
Megaflush Top 5
posTeamFlushDate
1.Team4Fun.nl202.70005-12-2005
2.chelloo.com172.70222-11-2009
3.markvanmook116.99631-10-2006
4.Blord91.06724-06-2009
5.[DPC]_Team_ColdFusion89.74927-01-2008
More...
Mijlpalen
Kluis1.000.000
Kluis1.000.000
Nieuwe Leden
Pa_Parkstad353
PizzaPete336
Folding@Home Links
Folding@Home webpage
Folding@Home forum
DPCH Suggestiepagina
DPC FAQ
Bron
Solarboiler: Top Senz 200 Nero-3 ⣿⣿ Photovoltaics: 9x LG 320N1K-A5, SE 3000H
  • Wiethoofd
Wiethoofd
Broadcast TOM
Vergeet je helemaal _onze_ plek winst in de overall stats te melden, dus doe ik het maar om m'n lack of statsposting deze week te compenseren 8)
En ook Kluis mag zich tot de miljonairsclub rekenen :> Gratz :9
  • MetalfanBlackness
MetalfanBlackness
♥ PV & SB ♥
Goed gezien, sorry had het helemaal gemist, maar ja, was in mijn weekelijkse catchup van het posten van DPCH's waar ik even snel doorheen ging.
Kun jij nog wel even de startpost aanpasen?
[ Voor 13% gewijzigd door MetalfanBlackness op 01-02-2010 00:12 ]
  • MetalfanBlackness
MetalfanBlackness
♥ PV & SB ♥
... should have been an edit ...
[ Voor 73% gewijzigd door MetalfanBlackness op 01-02-2010 00:11 . Reden: Vind de edit knop eens ]
  • Bubbles
Bubbles
DPC-Crew
2 the resQ
Thanx voor de stats. En. startpost is ook aangepast. :)
