NFS mount MAC --> Linux
  • MacLinux
  • Laatst online: 27-03-2024
Help..
Computer 1: Slackware fileserver:
Slackware 13
Kernel 2.6.29.6-smp
nfs v3
/etc/exports# See exports(5) for a description.
# This file contains a list of all directories exported to other computers.
# It is used by rpc.nfsd and rpc.mountd.
/home/jeannette 192.168.0.0/255.255.0.0(rw,no_subtree_check)
/home/marcel 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
/home/eline 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
/media/muziek/mp3 192.168.0.0/255.255.0.0(rw,no_subtree_check)
/home/partimag 192.168.0.0/255.255.0.0(rw,no_subtree_check)
/home/arnout 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
/etc/hosts.allow
# hosts.allow   This file describes the names of the hosts which are
#               allowed to use the local INET services, as decided by
#               the '/usr/sbin/tcpd' server.
# Version:      @(#)/etc/hosts.allow    1.00    05/28/93
# Author:       Fred N. van Kempen, <waltje@uwalt.nl.mugnet.org
portmap: 192.168.0.0/255.255.0.0
lockd:ALL
mountd:ALL
rquotad:ALL
statd:ALL
# End of hosts.allow.
/etc/hosts.deny
# hosts.deny    This file describes the names of the hosts which are
#               *not* allowed to use the local INET services, as decided
#               by the '/usr/sbin/tcpd' server.
# Version:      @(#)/etc/hosts.deny     1.00    05/28/93
# End of hosts.deny.
ls -l /home
root@vlinder:/var/log# ls -l /home
total 24
drwxrwxr-x  8 arnout    users 4096 2010-01-20 14:25 arnout/
drwxrwxr-x  3 eline     users 4096 2010-01-20 14:05 eline/
drwxr-xr-x  2 root      root  4096 2009-06-06 22:37 ftp/
drwxrwxr-x 31 jeannette users 4096 2010-01-16 23:24 jeannette/
drwxrwxr-x 49 marcel    users 4096 2009-12-29 15:20 marcel/
drwxrwxrwx  5 root      root  4096 2009-11-30 10:52 partimag/
total 24
tail /var/log/messages
Jan 20 14:06:44 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:939 for /home/jeannette (/home/jeannette)
Jan 20 14:06:56 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:938 for /home/jeannette (/home/jeannette)
Jan 20 14:06:57 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:937 for /home/jeannette (/home/jeannette)
Jan 20 14:06:57 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:936 for /home/jeannette (/home/jeannette)
Jan 20 14:06:57 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:935 for /home/jeannette (/home/jeannette)
Jan 20 14:20:06 vlinder -- MARK --
Jan 20 14:26:24 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:934 for /home/jeannette (/home/jeannette)
Jan 20 14:26:24 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:933 for /home/jeannette (/home/jeannette)
Jan 20 14:26:25 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:932 for /home/jeannette (/home/jeannette)
Jan 20 14:26:25 vlinder mountd[27630]: authenticated mount request from 192.168.0.68:931 for /home/jeannette (/home/jeannette)
Computer 2: iMac version 10.6.2
Vanuit het menu Go > Connect to server:
nfs://192.168.0.12/home/arnout geeft keurig de inhoud van de gedeelde map.
nfs://192.168.0.12/home/marcel ook geen probleem
nfs://192.168.0.12/home/eline alleen als de home dir op 775 staat.
nfs://192.168.0.12/home/jeannette geeft geen enkele reactie. Als ik op verbinden klik komt er heel kort een venstertje dat onmiddellijk verdwijnt en daarna niet meer. Lukt absoluut niet.
Hoe kom ik verbonden met alle accounts terwijl de homedirs op 755 staan?
[ Voor 0% gewijzigd door Kees op 20-01-2010 14:59 ]
  • Kees
  • Laatst online: 24-10 10:46
Kees
Serveradmin / BOFH / DoC
Ik neem voor het gemak maar aan dat je niet als root mount; dus:
secure This option requires that requests originate on an Internet port less than IPPORT_RESERVED (1024). This
option is on by default. To turn it off, specify insecure.
Die optie heb je wel bij de andere homedirs, en niet bij jeanette.
Verder, zou ik het logisch vinden dat je er alleen bij kan als het op 775 staat, en jij zelf in de users group zit. Stel dat jij als user 'arnout' met als groep 'users' de boel wil zien, dan heb jij met die permissies toegang tot de homedirs, als de homedir dan op 755 staat voor user 'eline' dan heb jij die '5' als access (r-x) en kun je dus alleen lezen. Als hij op 775 staat heb je rwx access.
Als je verbonden wil worden met alle accounts, met de homedirs op 755, dan zul je dus alle homedirs van dezelfde user moeten maken, of ze met no_root_squash mounten, en dan kun je er met root inkomen.
Verder heb ik je post nog een beetje aangepast om het leesbaar te maken ;)
  • MacLinux
Maar waar zie je dan die optie bij jeannette niet en bij de anderen wel?
  • The-Hi_End
  • Laatst online: 21-10 16:20
MacLinux schreef op woensdag 20 januari 2010 @ 15:36:
in je /etc/exports
/home/jeannette 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
stukje in bold is wat ontbreekt :)
  • MacLinux
wat een suffert ben ik. Mijn dank is groot. Probleem opgelost.
