How to Convert Edit Videos to AVI/MP4/WMV/MOV/VOB/MKV on MAC
  • 420 views
As a senior member of Mac-Forums.com, I often found that some members asked for help about how to convert video to other formats, such as converting Real Media file to MP3 or WMV on Mac OS X, converting WMV to AVI for playback on Quick Time X (10), putting a segment of a TV program to iMovie to do some special editing and so on.
Okay, I will show you the easiest and fastest solution to make them according to my own experience.
Preparation: The first is to hunt a professional tool. Actually I have been looking for an all-in-one converter for Mac for a long time, and easiler I came across Disney.com. With its friendly interface, every one can easily and fastly convert among almost video/audio formats, especially for its audio/video synchnization and multi-thread encoding technology which makes it more powerful and professional than other similar programs on the market.
Afbeeldingslocatie: http://www.brorsoft.com/images/how-to/video-converter/2009102801.jpg
After downloading and installing Disney.com, just follow me as below:
Step 1. Click the “Add” button and import the video files you want to convert into this program
Step 2. Select the video or audio output format you want to. At the same time, you can set the output parameters of the conversion by clicking the “Setting” button on the main interface to open the setting panel.
Afbeeldingslocatie: http://www.brorsoft.com/images/how-to/video-converter/2009102802.jpg
For example, you can select the Size from the drop-down list, like 240*160, 320*240, 480*272, 480*320, 640*480, etc.
Step 3. Click the “Browse” button to specify a location to save the converted video or audio, like MP3. If you want to open the output folder, just click the “Open” button.
Step 4. Click the “Start” button to start the conversion.
Afbeeldingslocatie: http://www.brorsoft.com/images/how-to/video-converter/2009102803.jpg
Okay, now you just need to wait for a while to get the desired file for great enjoyment.
Optional functions:
1. Snapshot
If you want to capture the current picture you like, just click the “Snapshot” button and the image file will be saved. Click the “Open” button next to the “Snapshot” button you can open your picture with ease.
Afbeeldingslocatie: http://www.brorsoft.com/images/how-to/video-converter/2009102804.jpg
2. Merge
Tick the checkbox “Merge into one file”, you can join several files into a one without any trouble.
3. Effect
Click the “Effect” button, you can adjust the brightness, contrast and saturation of the video when you watch the video at the “Preview Pane”.
Afbeeldingslocatie: http://www.brorsoft.com/images/how-to/video-converter/2009102805.jpg
In addition, you can take some special effects like simple gauss blur effect, simple laplacian sharpen, gray, flip color, invert, aged film on the video clips. Moreover, you can also check the option Deinterlacing to convert interlaced video into a non-interlaced form, so that you can enjoy a better and clearer video effect after conversion.
4. Crop
If you hate the black edges or letterboxed and want to remove them from your video, you can click the “Crop” button to easily and freely crop the unwanted parties via two ways, that are dragging the frame around the video and setting the crop values: Top, Bottom, Left and Right.
Afbeeldingslocatie: http://www.brorsoft.com/images/how-to/video-converter/2009102806.jpg
5. Trim
Click the “Trim” bar to split the current title or chapter by dragging the Start Time slider to set the start time, and dragging the End Time slider to set the finish time. Then you can rip any segment from the video on Mac as you like.
[ Voor 1% gewijzigd door Spider.007 op 24-12-2009 10:24 ]
  • Spider.007
Spider.007
* Tetragrammaton
Thanks for your time to create this tutorial. However, since this is coming from the company that created the specific software you describe; we consider this spam. Therefore I am closing this topic and request that you refrain from any further postings on this forum. Thanks :)
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
