EXT3-fs: #blocks per group too big:
  • GoVegan
  • Laatst online: 15-10 20:37
Ik heb hier een debian server met custum kernel (2.6.32)
heb hier pci sata kaartje in zitten (VIA VT6421A PCI) en hier aan een SAMSUNG HD154UI.
deze word herkend, kan hem formatteren als ext3 maar daarna kan ik hem niet mounten.
ik heb met fdisk een primaire partitie aangemaakt. (verder standaard instellingen van fdisk)
en daarna ext3 filesystem gemaakt (mkfs.ext3 -b 4096 /dev/sda1)
maar mounten ho maar.
iemand enig idee wat ik fout doe?
borre:# mount -v -t ext3 /dev/sda1 /mnt/data3
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
       missing cmdpage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
dmesg
borre:# dmesg | tail
 sda: sda1
 sda: sda1
EXT3-fs: #blocks per group too big: 366313472
EXT3-fs error (device sda1): ext3_check_descriptors: Inode table for group 5 not in group (block 131074)!
EXT3-fs: group descriptors corrupted!
EXT3-fs error (device sda1): ext3_check_descriptors: Inode table for group 6 not in group (block 164867)!
EXT3-fs warning: feature flags set on rev 0 fs, running e2fsck is recommended
fsck & e2fsck -b 8193
borre:# fsck /dev/sda1
fsck 1.41.3 (12-Oct-2008)
e2fsck 1.41.3 (12-Oct-2008)
fsck.ext2: Group descriptors look bad... trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/sda1
The superblock could not be read or does not describe a correct ext2
filesystem.  If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
fdisk -l
borre:/home/peter# fdisk -l /dev/sda
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x1e40c776
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1               1      182401  1465136001   83  Linux
[update]
hmmm nu lees ik dus de fdisk een melding geeft over een GTP tabel.
dat is nieuw voor mij, wat ik zo snel lees is dat dit nodig is voor partities boven de 2000GB.
mijn schijf is 1500GB dus nog niet nodig.
hoe krijg ik de GPT tabel eraf en kan ik gewoon mbr weer gebruiken.
(of is het verstandiger om toch een GPT te gebruiken?)
[ Voor 11% gewijzigd door GoVegan op 18-12-2009 00:34 ]
  • Snow_King
  • Laatst online: 22:43
Snow_King
Konijn is stoer!
Je kan met "parted" er een ander label op zetten.
En wat als je bij mkfs geen opties mee geeft zoals de blocksize?
  • GoVegan
Snow_King schreef op vrijdag 18 december 2009 @ 11:39:
geen blocksize geven bij mkfs leverde het zelfde op.
zal vanavond eens een label gaan zetten met parted.
  • GoVegan
hmm, heb hem nu een gpt partition tabel gegeven en geformateerd als ext3 met parted magic (live linux disk met gparted),
en na een format kan ik hem beschrijven en mounten, en ook naar een reboot in mijn eigen linux omgeving kan ik hem ook mounten en beschrijven, maar reboot ik daarna nog dan krijg ik weer de melding:
       missing codepage or helper program, or other error
       dmesg | tail  or so
ik zal debian een opnieuw installeren en kijk wat dat oplevert.
[update]
nieuwe (test)debian install gedaan, debian op een ide 40 gig. tijdens de install de SAMSUNG HD154UI ook als ext3 geformateerd.
na de install kon de schijf gewoon mounten en beschrijven ook naar reboot alles goed.
de kernel config naar mij huidige installatie gekopieerd, de zelfde kernel gedownload en gecompileerd. na reboot kon ik de schijf mounten en beschrijven.
maar reboot ik opnieuw krijg ik weer dezelde error:
dmesg | tail or so
[ Voor 34% gewijzigd door GoVegan op 09-01-2010 16:46 ]
  • GoVegan
Ik denk dat ik hem nu heb, het was best wel stomme fout. maar het mobo stond nog lichtjes overgeclocked :)
dit weer op standaard gezet, en hd opnieuw geformateerd. En hij word nu gewoon herkend en laat zich netjes mounten :)
