current pending sector count
  • jb044
  • Laatst online: 13-08 13:45
Gister liep ik tegen een gevalletje dataloss aan op mijn raid0 array
bestaande uit 2 TB Samsung disks. Aangezien het puur om films gaat en dus
niet om echt belangrijke data, was het puur een kwestie van deleten en
opnieuw downloaden. Alleen nu heb ik volgens SMART 9 pending sectors:
# skdump /dev/sdd
Device: /dev/sdd
Type: 16 Byte SCSI ATA SAT Passthru
Model: [SAMSUNG HD103SI]
Serial: [S1Y5J90S412566]
Firmware: [1AG01113]
SMART Available: yes
Quirks:
Awake: yes
SMART Disk Health Good: yes
Off-line Data Collection Status: [Off-line data collection activity was
never started.]
Total Time To Complete Off-Line Data Collection: 12619
s
Self-Test Execution Status: [The previous self-test routine completed
without error or no self-test has ever been
run.]
Percent Self-Test Remaining:
0%
Conveyance Self-Test Available: yes
Short/Extended Self-Test Available: yes
Start Self-Test Available: yes
Abort Self-Test Available: yes
Short Self-Test Polling Time: 2 min
Extended Self-Test Polling Time: 211 min
Conveyance Self-Test Polling Time: 22 min
Bad Sectors: 9 sectors
Powered On: 4.3 months
Power Cycles: 87
Average Powered On Per Power Cycle: 1.5 days
Temperature: 27.0 C
Overall Status: BAD_SECTOR
ID# Name                        Value Worst Thres Pretty
Raw            Type    Updates Good
  1 raw-read-error-rate          99    99    51   282
0x1a0100000000 prefail online  yes
  3 spin-up-time                 83    83    11   6.1 s
0xac1700000000 prefail online  yes
  4 start-stop-count            100   100     0   90
0x5a0000000000 old-age online  n/a
  5 reallocated-sector-count    100   100    10   0 sectors
0x000000000000 prefail online  yes
  7 seek-error-rate             253   253    51   0
  8 seek-time-performance       100   100    15   n/a
0x000000000000 prefail offline yes
  9 power-on-hours               99    99     0   4.3 months
0x270c00000000 old-age online  n/a
 10 spin-retry-count            100   100    51   0
 11 calibration-retry-count     100   100     0   0
0x000000000000 old-age online  n/a
 12 power-cycle-count           100   100     0   87
0x570000000000 old-age online  n/a
 13 read-soft-error-rate         99    99     0   282
0x1a0100000000 old-age online  n/a
183 attribute-183               100   100     0   n/a
184 attribute-184               100   100     0   n/a
0x000000000000 prefail online  n/a
187 reported-uncorrect          100   100     0   282 sectors
188 attribute-188               100   100     0   n/a
190 airflow-temperature-celsius  81    70     0   19.0 C
0x13000d130000 old-age online  n/a
194 temperature-celsius-2        73    70     0   27.0 C
0x1b000d1b0000 old-age online  n/a
195 hardware-ecc-recovered      100   100     0   70087041
0x81712d040000 old-age online  n/a
196 reallocated-event-count     100   100     0   0
197 current-pending-sector      100   100     0   9 sectors
0x090000000000 old-age online  no
198 offline-uncorrectable       100   100     0   0 sectors
0x000000000000 old-age offline n/a
199 udma-crc-error-count        100   100     0   0
200 multi-zone-error-rate       100   100     0   0
201 soft-read-error-rate        100   100     0   0
Is dit iets wat ik kan oplossen of is het puur een kwestie van wachten
tot de schijf dit (eindelijk) zelf doet, want simpelweg een hele grote
file met dd aanmaken had geen effect. Wat ik in elk geval niet snap is
hoe het hoort te werken met deze SMART value. Eerder had ik begrepen dat
bad sectors tijdens een read worden gemarkeerd en vervolgens bij de eerst
volgende write worden geremapped, wat me vrij logisch lijkt. Alleen de
eerste de beste google hit op "smart current pending sectors" leert dat
het remappen juist zou plaats vinden op opeenvolgende reads, of beter
gezegd het falen daarvan.
Dus hoe werkt het nou met BAD sectors en SMART? En moet ik mij zorgen
maken of actie ondernemen?
  • jan99999
  • Laatst online: 07-10 17:04
Een sector bestaat uit meerdere stukjes, met extra kontrole of het stukje goed is.
Bijv 111111111111111111 is data en kontrole
Bijv 111011111111111111 is data en kontrole, na kontrole is hij hetzelfde als boven.
Dit is een hele kleine stukje van je hd, dus geen sector(dacht ik) 111111111111111111, nu weet de hd dat dit een 1 is. De meeste stukjes zijn 1 dus op dit stukje staat een 1. Iemand op het internet zij dat dit bijna analoog is, er word gelezen dan door een chip gehaald die zegt of het een 1 of 0 is.
Dit is heel eenvoudig uitgelegd, elke hd heeft heel veel fouten, net als cd en dvd, kontrole vangt dit op.
Pending sectors betekend dat er fout is gelezen en de gegevens zijn gecorrigeerd naar de pc toe, niet op de harddisk.
Bij volgende leesbeurt indien hij goed leest dan word de sector weer als goed gezien.
Hoe vaak je "slecht lezen" moet zodat hij reallocated word weet ik niet.
  • jb044
In dit geval was er van correctie geen sprake, maar echt dataloss: 2 files waren daadwerkelijk niet leesbaar en kernel logging toonde dit (na een een tijd van proberen en nog eens proberen) aan:
Nov 27 18:06:40 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3F sactive 0x3F
Nov 27 18:06:40 morphius kernel: ata6: SWNCQ:qc_active 0xC defer_bits 0x33 last_issue_tag 0x3
Nov 27 18:06:40 morphius kernel:  dhfis 0xC dmafis 0x4 sdbfis 0x2
Nov 27 18:06:40 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:06:40 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:06:40 morphius kernel: ata6: tag 0x2: 1 1 0 1
Nov 27 18:06:40 morphius kernel: ata6: tag 0x3: 1 0 0 1
Nov 27 18:06:40 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3f SErr 0x0 action 0x6 frozen
Nov 27 18:06:40 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:06:40 morphius kernel: ata6.00: cmd 60/80:00:bf:9b:68/00:00:54:00:00/40 tag 0 ncq 65536 in
Nov 27 18:06:40 morphius kernel:         res 41/40:1c:3f:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:06:40 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:06:40 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:06:40 morphius kernel: ata6.00: cmd 60/80:08:3f:9c:68/00:00:54:00:00/40 tag 1 ncq 65536 in
Nov 27 18:06:40 morphius kernel: ata6.00: cmd 60/80:10:bf:9a:68/00:00:54:00:00/40 tag 2 ncq 65536 in
Nov 27 18:06:40 morphius kernel: ata6.00: cmd 60/80:18:3f:9b:68/00:00:54:00:00/40 tag 3 ncq 65536 in
Nov 27 18:06:40 morphius kernel: ata6.00: cmd 60/80:20:bf:9c:68/00:00:54:00:00/40 tag 4 ncq 65536 in
Nov 27 18:06:40 morphius kernel: ata6.00: cmd 60/80:28:3f:9d:68/00:00:54:00:00/40 tag 5 ncq 65536 in
Nov 27 18:06:40 morphius kernel: ata6: hard resetting link
Nov 27 18:06:41 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:06:41 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:06:41 morphius kernel: ata6: EH complete
Nov 27 18:06:45 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x2C sactive 0x2C
Nov 27 18:06:45 morphius kernel: ata6: SWNCQ:qc_active 0x2C defer_bits 0x0 last_issue_tag 0x5
Nov 27 18:06:45 morphius kernel:  dhfis 0x2C dmafis 0x8 sdbfis 0x10
Nov 27 18:06:45 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:06:45 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:06:45 morphius kernel: ata6: tag 0x2: 1 0 0 1
Nov 27 18:06:45 morphius kernel: ata6: tag 0x3: 1 1 0 1
Nov 27 18:06:45 morphius kernel: ata6: tag 0x5: 1 0 0 1
Nov 27 18:06:45 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x2c SErr 0x0 action 0x6 frozen
Nov 27 18:06:45 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:06:45 morphius kernel: ata6.00: cmd 60/80:10:3f:9b:68/00:00:54:00:00/40 tag 2 ncq 65536 in
Nov 27 18:06:45 morphius kernel:         res 41/40:2c:bf:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:06:45 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:06:45 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:06:45 morphius kernel: ata6.00: cmd 60/80:18:bf:9a:68/00:00:54:00:00/40 tag 3 ncq 65536 in
Nov 27 18:06:45 morphius kernel: ata6.00: cmd 60/80:28:bf:9b:68/00:00:54:00:00/40 tag 5 ncq 65536 in
Nov 27 18:06:45 morphius kernel: ata6: hard resetting link
Nov 27 18:06:46 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:06:46 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:06:46 morphius kernel: ata6: EH complete
Nov 27 18:06:48 morphius ntpd[2309]: synchronized to 10.1.2.2, stratum 11
Nov 27 18:06:49 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x7 sactive 0x7
Nov 27 18:06:49 morphius kernel: ata6: SWNCQ:qc_active 0x7 defer_bits 0x0 last_issue_tag 0x2
Nov 27 18:06:49 morphius kernel:  dhfis 0x7 dmafis 0x2 sdbfis 0x0
Nov 27 18:06:49 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:06:49 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:06:49 morphius kernel: ata6: tag 0x0: 1 0 0 1
Nov 27 18:06:49 morphius kernel: ata6: tag 0x1: 1 1 0 1
Nov 27 18:06:49 morphius kernel: ata6: tag 0x2: 1 0 0 1
Nov 27 18:06:49 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x7 SErr 0x0 action 0x6 frozen
Nov 27 18:06:49 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:06:49 morphius kernel: ata6.00: cmd 60/80:00:bf:9b:68/00:00:54:00:00/40 tag 0 ncq 65536 in
Nov 27 18:06:49 morphius kernel:         res 41/40:14:3f:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:06:49 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:06:49 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:06:49 morphius kernel: ata6.00: cmd 60/80:08:bf:9a:68/00:00:54:00:00/40 tag 1 ncq 65536 in
Nov 27 18:06:49 morphius kernel: ata6.00: cmd 60/80:10:3f:9b:68/00:00:54:00:00/40 tag 2 ncq 65536 in
Nov 27 18:06:49 morphius kernel: ata6: hard resetting link
Nov 27 18:06:50 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:06:50 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:06:50 morphius kernel: ata6: EH complete
Nov 27 18:06:53 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x2 sactive 0x2
Nov 27 18:06:53 morphius kernel: ata6: SWNCQ:qc_active 0x2 defer_bits 0x0 last_issue_tag 0x2
Nov 27 18:06:53 morphius kernel:  dhfis 0x2 dmafis 0x2 sdbfis 0x4
Nov 27 18:06:53 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:06:53 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:06:53 morphius kernel: ata6: tag 0x1: 1 1 0 1
Nov 27 18:06:53 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x2 SErr 0x0 action 0x6 frozen
Nov 27 18:06:53 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:06:53 morphius kernel: ata6.00: cmd 60/80:08:bf:9a:68/00:00:54:00:00/40 tag 1 ncq 65536 in
Nov 27 18:06:53 morphius kernel:         res 41/40:14:bf:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:06:53 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:06:53 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:06:53 morphius kernel: ata6: hard resetting link
Nov 27 18:06:54 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:06:54 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:06:54 morphius kernel: ata6: EH complete
Nov 27 18:06:56 morphius ntpd[2309]: no servers reachable
Nov 27 18:06:57 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:06:57 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:06:57 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:06:57 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:06:57 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:06:57 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:06:57 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:06:57 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:06:57 morphius kernel: ata6.00: cmd 60/80:00:bf:9a:68/00:00:54:00:00/40 tag 0 ncq 65536 in
Nov 27 18:06:57 morphius kernel:         res 41/40:04:bf:9a:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:06:57 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:06:57 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:06:57 morphius kernel: ata6: hard resetting link
Nov 27 18:06:58 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:06:58 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:06:58 morphius kernel: ata6: EH complete
Nov 27 18:07:02 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:02 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:02 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:02 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:02 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:02 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:02 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:02 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:02 morphius kernel: ata6.00: cmd 60/80:00:bf:9a:68/00:00:54:00:00/40 tag 0 ncq 65536 in
Nov 27 18:07:02 morphius kernel:         res 41/40:04:bf:9a:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:02 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:02 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:02 morphius kernel: ata6: hard resetting link
Nov 27 18:07:03 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:03 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:03 morphius kernel: sd 5:0:0:0: [sde] Unhandled sense code
Nov 27 18:07:03 morphius kernel: sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 27 18:07:03 morphius kernel: sd 5:0:0:0: [sde] Sense Key : Medium Error [current] [descriptor]
Nov 27 18:07:03 morphius kernel: Descriptor sense data with sense descriptors (in hex):
Nov 27 18:07:03 morphius kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 27 18:07:03 morphius kernel:        54 68 9a bf
Nov 27 18:07:03 morphius kernel: sd 5:0:0:0: [sde] Add. Sense: Unrecovered read error - auto reallocate failed
Nov 27 18:07:03 morphius kernel: end_request: I/O error, dev sde, sector 1416141503
Nov 27 18:07:03 morphius kernel: ata6: EH complete
Nov 27 18:07:07 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:07 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:07 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:07 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:07 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:07 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:07 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:07 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:07 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:07 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:07 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:07 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:07 morphius kernel: ata6: hard resetting link
Nov 27 18:07:08 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:08 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:08 morphius kernel: ata6: EH complete
Nov 27 18:07:10 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:10 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:10 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:10 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:10 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:10 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:10 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:10 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:10 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:10 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:10 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:10 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:10 morphius kernel: ata6: hard resetting link
Nov 27 18:07:11 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:11 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:11 morphius kernel: ata6: EH complete
Nov 27 18:07:14 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:14 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:14 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:14 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:14 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:14 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:14 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:14 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:14 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:14 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:14 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:14 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:14 morphius kernel: ata6: hard resetting link
Nov 27 18:07:15 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:15 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:15 morphius kernel: ata6: EH complete
Nov 27 18:07:17 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:17 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:17 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:17 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:17 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:17 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:17 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:17 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:17 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:17 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:17 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:17 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:17 morphius kernel: ata6: hard resetting link
Nov 27 18:07:18 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:18 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:18 morphius kernel: ata6: EH complete
Nov 27 18:07:21 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:21 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:21 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:21 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:21 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:21 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:21 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:21 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:21 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:21 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:21 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:21 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:21 morphius kernel: ata6: hard resetting link
Nov 27 18:07:22 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:22 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:22 morphius kernel: ata6: EH complete
Nov 27 18:07:25 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x7 sactive 0x7
Nov 27 18:07:25 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x6 last_issue_tag 0x0
Nov 27 18:07:25 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:25 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:25 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:25 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:25 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x7 SErr 0x0 action 0x6 frozen
Nov 27 18:07:25 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:25 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:25 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:25 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:25 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:25 morphius kernel: ata6.00: cmd 60/08:08:1f:81:20/00:00:00:00:00/40 tag 1 ncq 4096 in
Nov 27 18:07:25 morphius kernel: ata6.00: cmd 61/08:10:0f:05:22/00:00:3a:00:00/40 tag 2 ncq 4096 out
Nov 27 18:07:25 morphius kernel: ata6: hard resetting link
Nov 27 18:07:26 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:26 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:26 morphius kernel: sd 5:0:0:0: [sde] Unhandled sense code
Nov 27 18:07:26 morphius kernel: sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 27 18:07:26 morphius kernel: sd 5:0:0:0: [sde] Sense Key : Medium Error [current] [descriptor]
Nov 27 18:07:26 morphius kernel: Descriptor sense data with sense descriptors (in hex):
Nov 27 18:07:26 morphius kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 27 18:07:26 morphius kernel:        54 68 9b 27
Nov 27 18:07:26 morphius kernel: sd 5:0:0:0: [sde] Add. Sense: Unrecovered read error - auto reallocate failed
Nov 27 18:07:26 morphius kernel: end_request: I/O error, dev sde, sector 1416141607
Nov 27 18:07:26 morphius kernel: ata6: EH complete
Nov 27 18:07:28 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:28 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:28 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:28 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:28 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:28 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:28 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:28 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:28 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:28 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:28 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:28 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:28 morphius kernel: ata6: hard resetting link
Nov 27 18:07:29 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:29 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:29 morphius kernel: ata6: EH complete
Nov 27 18:07:32 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:32 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:32 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:32 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:32 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:32 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:32 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:32 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:32 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:32 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:32 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:32 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:32 morphius kernel: ata6: hard resetting link
Nov 27 18:07:33 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:33 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:33 morphius kernel: ata6: EH complete
Nov 27 18:07:35 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:35 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:35 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:35 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:35 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:35 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:35 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:35 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:35 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:35 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:35 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:35 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:35 morphius kernel: ata6: hard resetting link
Nov 27 18:07:36 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:36 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:36 morphius kernel: ata6: EH complete
Nov 27 18:07:38 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:38 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:38 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:38 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:38 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:38 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:38 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:38 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:38 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:38 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:38 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:38 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:38 morphius kernel: ata6: hard resetting link
Nov 27 18:07:39 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:39 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:39 morphius kernel: ata6: EH complete
Nov 27 18:07:42 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:42 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:42 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:42 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:42 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:42 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:42 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:42 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:42 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:42 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:42 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:42 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:42 morphius kernel: ata6: hard resetting link
Nov 27 18:07:43 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:43 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:43 morphius kernel: ata6: EH complete
Nov 27 18:07:45 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:07:45 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:07:45 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:07:45 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:07:45 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:07:45 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:07:45 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:07:45 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:07:45 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:07:45 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:07:45 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:07:45 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:07:45 morphius kernel: ata6: hard resetting link
Nov 27 18:07:46 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:07:46 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:07:46 morphius kernel: sd 5:0:0:0: [sde] Unhandled sense code
Nov 27 18:07:46 morphius kernel: sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 27 18:07:46 morphius kernel: sd 5:0:0:0: [sde] Sense Key : Medium Error [current] [descriptor]
Nov 27 18:07:46 morphius kernel: Descriptor sense data with sense descriptors (in hex):
Nov 27 18:07:46 morphius kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 27 18:07:46 morphius kernel:        54 68 9b 27
Nov 27 18:07:46 morphius kernel: sd 5:0:0:0: [sde] Add. Sense: Unrecovered read error - auto reallocate failed
Nov 27 18:07:46 morphius kernel: end_request: I/O error, dev sde, sector 1416141607
Nov 27 18:07:46 morphius kernel: ata6: EH complete
Nov 27 18:08:46 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3 sactive 0x3
Nov 27 18:08:46 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x2 last_issue_tag 0x0
Nov 27 18:08:46 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:08:46 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:08:46 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:08:46 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:08:46 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3 SErr 0x0 action 0x6 frozen
Nov 27 18:08:46 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:08:46 morphius kernel: ata6.00: cmd 60/00:00:bf:99:68/02:00:54:00:00/40 tag 0 ncq 262144 in
Nov 27 18:08:46 morphius kernel:         res 41/40:04:bf:99:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:08:46 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:08:46 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:08:46 morphius kernel: ata6.00: cmd 60/00:08:bf:9b:68/02:00:54:00:00/40 tag 1 ncq 262144 in
Nov 27 18:08:46 morphius kernel: ata6: hard resetting link
Nov 27 18:08:47 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:08:47 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:08:47 morphius kernel: ata6: EH complete
Nov 27 18:08:50 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3 sactive 0x3
Nov 27 18:08:50 morphius kernel: ata6: SWNCQ:qc_active 0x3 defer_bits 0x0 last_issue_tag 0x1
Nov 27 18:08:50 morphius kernel:  dhfis 0x3 dmafis 0x2 sdbfis 0x0
Nov 27 18:08:50 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:08:50 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:08:50 morphius kernel: ata6: tag 0x0: 1 0 0 1
Nov 27 18:08:50 morphius kernel: ata6: tag 0x1: 1 1 0 1
Nov 27 18:08:50 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3 SErr 0x0 action 0x6 frozen
Nov 27 18:08:50 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:08:50 morphius kernel: ata6.00: cmd 60/00:00:bf:9b:68/02:00:54:00:00/40 tag 0 ncq 262144 in
Nov 27 18:08:50 morphius kernel:         res 41/40:0c:bf:99:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:08:50 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:08:50 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:08:50 morphius kernel: ata6.00: cmd 60/00:08:bf:99:68/02:00:54:00:00/40 tag 1 ncq 262144 in
Nov 27 18:08:50 morphius kernel: ata6: hard resetting link
Nov 27 18:08:50 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:08:50 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:08:50 morphius kernel: ata6: EH complete
Nov 27 18:08:53 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3 sactive 0x3
Nov 27 18:08:53 morphius kernel: ata6: SWNCQ:qc_active 0x3 defer_bits 0x0 last_issue_tag 0x1
Nov 27 18:08:53 morphius kernel:  dhfis 0x3 dmafis 0x1 sdbfis 0x0
Nov 27 18:08:53 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:08:53 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:08:53 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:08:53 morphius kernel: ata6: tag 0x1: 1 0 0 1
Nov 27 18:08:53 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3 SErr 0x0 action 0x6 frozen
Nov 27 18:08:53 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:08:53 morphius kernel: ata6.00: cmd 60/00:00:bf:99:68/02:00:54:00:00/40 tag 0 ncq 262144 in
Nov 27 18:08:53 morphius kernel:         res 41/40:0c:bf:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:08:53 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:08:53 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:08:53 morphius kernel: ata6.00: cmd 60/00:08:bf:9b:68/02:00:54:00:00/40 tag 1 ncq 262144 in
Nov 27 18:08:53 morphius kernel: ata6: hard resetting link
Nov 27 18:08:54 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:08:54 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:08:54 morphius kernel: ata6: EH complete
Nov 27 18:08:58 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3 sactive 0x3
Nov 27 18:08:58 morphius kernel: ata6: SWNCQ:qc_active 0x3 defer_bits 0x0 last_issue_tag 0x1
Nov 27 18:08:58 morphius kernel:  dhfis 0x3 dmafis 0x2 sdbfis 0x0
Nov 27 18:08:58 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:08:58 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:08:58 morphius kernel: ata6: tag 0x0: 1 0 0 1
Nov 27 18:08:58 morphius kernel: ata6: tag 0x1: 1 1 0 1
Nov 27 18:08:58 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3 SErr 0x0 action 0x6 frozen
Nov 27 18:08:58 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:08:58 morphius kernel: ata6.00: cmd 60/00:00:bf:9b:68/02:00:54:00:00/40 tag 0 ncq 262144 in
Nov 27 18:08:58 morphius kernel:         res 41/40:0c:bf:99:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:08:58 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:08:58 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:08:58 morphius kernel: ata6.00: cmd 60/00:08:bf:99:68/02:00:54:00:00/40 tag 1 ncq 262144 in
Nov 27 18:08:58 morphius kernel: ata6: hard resetting link
Nov 27 18:08:59 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:08:59 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:08:59 morphius kernel: ata6: EH complete
Nov 27 18:09:03 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3 sactive 0x3
Nov 27 18:09:03 morphius kernel: ata6: SWNCQ:qc_active 0x3 defer_bits 0x0 last_issue_tag 0x1
Nov 27 18:09:03 morphius kernel:  dhfis 0x3 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:03 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:03 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:03 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:03 morphius kernel: ata6: tag 0x1: 1 0 0 1
Nov 27 18:09:03 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3 SErr 0x0 action 0x6 frozen
Nov 27 18:09:03 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:03 morphius kernel: ata6.00: cmd 60/00:00:bf:99:68/02:00:54:00:00/40 tag 0 ncq 262144 in
Nov 27 18:09:03 morphius kernel:         res 41/40:0c:bf:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:03 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:03 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:03 morphius kernel: ata6.00: cmd 60/00:08:bf:9b:68/02:00:54:00:00/40 tag 1 ncq 262144 in
Nov 27 18:09:03 morphius kernel: ata6: hard resetting link
Nov 27 18:09:04 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:04 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:04 morphius kernel: ata6: EH complete
Nov 27 18:09:07 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x3 sactive 0x3
Nov 27 18:09:07 morphius kernel: ata6: SWNCQ:qc_active 0x3 defer_bits 0x0 last_issue_tag 0x1
Nov 27 18:09:07 morphius kernel:  dhfis 0x3 dmafis 0x2 sdbfis 0x0
Nov 27 18:09:07 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:07 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:07 morphius kernel: ata6: tag 0x0: 1 0 0 1
Nov 27 18:09:07 morphius kernel: ata6: tag 0x1: 1 1 0 1
Nov 27 18:09:07 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x3 SErr 0x0 action 0x6 frozen
Nov 27 18:09:07 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:07 morphius kernel: ata6.00: cmd 60/00:00:bf:9b:68/02:00:54:00:00/40 tag 0 ncq 262144 in
Nov 27 18:09:07 morphius kernel:         res 41/40:0c:bf:99:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:07 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:07 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:07 morphius kernel: ata6.00: cmd 60/00:08:bf:99:68/02:00:54:00:00/40 tag 1 ncq 262144 in
Nov 27 18:09:07 morphius kernel: ata6: hard resetting link
Nov 27 18:09:08 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:08 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:08 morphius kernel: sd 5:0:0:0: [sde] Unhandled sense code
Nov 27 18:09:08 morphius kernel: sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 27 18:09:08 morphius kernel: sd 5:0:0:0: [sde] Sense Key : Medium Error [current] [descriptor]
Nov 27 18:09:08 morphius kernel: Descriptor sense data with sense descriptors (in hex):
Nov 27 18:09:08 morphius kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 27 18:09:08 morphius kernel:        54 68 99 bf
Nov 27 18:09:08 morphius kernel: sd 5:0:0:0: [sde] Add. Sense: Unrecovered read error - auto reallocate failed
Nov 27 18:09:08 morphius kernel: end_request: I/O error, dev sde, sector 1416141759
Nov 27 18:09:08 morphius kernel: end_request: I/O error, dev sde, sector 1416141247
Nov 27 18:09:08 morphius kernel: ata6: EH complete
Nov 27 18:09:11 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:11 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:11 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:11 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:11 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:11 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:11 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:11 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:11 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:11 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:11 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:11 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:11 morphius kernel: ata6: hard resetting link
Nov 27 18:09:12 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:12 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:12 morphius kernel: ata6: EH complete
Nov 27 18:09:14 morphius kernel: ata1: EH in SWNCQ mode,QC:qc_active 0xFFFF sactive 0xFFFF
Nov 27 18:09:14 morphius kernel: ata1: SWNCQ:qc_active 0xC defer_bits 0xFFF3 last_issue_tag 0x3
Nov 27 18:09:14 morphius kernel:  dhfis 0xC dmafis 0x4 sdbfis 0x0
Nov 27 18:09:14 morphius kernel: ata1: ATA_REG 0x40 ERR_REG 0x0
Nov 27 18:09:14 morphius kernel: ata1: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:14 morphius kernel: ata1: tag 0x2: 1 1 0 1
Nov 27 18:09:14 morphius kernel: ata1: tag 0x3: 1 0 0 1
Nov 27 18:09:14 morphius kernel: ata1.00: exception Emask 0x0 SAct 0xffff SErr 0x0 action 0x6 frozen
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:00:e8:0f:38/04:00:14:00:00/40 tag 0 ncq 524288 out
Nov 27 18:09:14 morphius kernel:         res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Nov 27 18:09:14 morphius kernel: ata1.00: status: { DRDY }
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:08:e8:13:38/04:00:14:00:00/40 tag 1 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:10:e8:d7:37/04:00:14:00:00/40 tag 2 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:18:e8:db:37/04:00:14:00:00/40 tag 3 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:20:e8:df:37/04:00:14:00:00/40 tag 4 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:28:e8:e3:37/04:00:14:00:00/40 tag 5 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:30:e8:e7:37/04:00:14:00:00/40 tag 6 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:38:e8:eb:37/04:00:14:00:00/40 tag 7 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:40:e8:ef:37/04:00:14:00:00/40 tag 8 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:48:e8:f3:37/04:00:14:00:00/40 tag 9 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:50:e8:f7:37/04:00:14:00:00/40 tag 10 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:58:e8:fb:37/04:00:14:00:00/40 tag 11 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:60:e8:ff:37/04:00:14:00:00/40 tag 12 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:68:e8:03:38/04:00:14:00:00/40 tag 13 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:70:e8:07:38/04:00:14:00:00/40 tag 14 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1.00: cmd 61/00:78:e8:0b:38/04:00:14:00:00/40 tag 15 ncq 524288 out
Nov 27 18:09:14 morphius kernel: ata1: hard resetting link
Nov 27 18:09:15 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:15 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:15 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:15 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:15 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:15 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:15 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:15 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:15 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:15 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:15 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:15 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:15 morphius kernel: ata6: hard resetting link
Nov 27 18:09:15 morphius kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Nov 27 18:09:15 morphius kernel: ata1.00: configured for UDMA/133
Nov 27 18:09:15 morphius kernel: ata1.00: device reported invalid CHS sector 0
Nov 27 18:09:15 morphius kernel: ata1: EH complete
Nov 27 18:09:15 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:16 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:16 morphius kernel: ata6: EH complete
Nov 27 18:09:18 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:18 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:18 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:18 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:18 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:18 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:18 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:18 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:18 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:18 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:18 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:18 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:18 morphius kernel: ata6: hard resetting link
Nov 27 18:09:19 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:19 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:19 morphius kernel: ata6: EH complete
Nov 27 18:09:22 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:22 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:22 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:22 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:22 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:22 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:22 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:22 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:22 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:22 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:22 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:22 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:22 morphius kernel: ata6: hard resetting link
Nov 27 18:09:22 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:23 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:23 morphius kernel: ata6: EH complete
Nov 27 18:09:25 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:25 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:25 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:25 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:25 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:25 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:25 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:25 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:25 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:25 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:25 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:25 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:25 morphius kernel: ata6: hard resetting link
Nov 27 18:09:26 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:26 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:26 morphius kernel: ata6: EH complete
Nov 27 18:09:29 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:29 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:29 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:29 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:29 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:29 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:29 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:29 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:29 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:29 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:29 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:29 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:29 morphius kernel: ata6: hard resetting link
Nov 27 18:09:29 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:30 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:30 morphius kernel: sd 5:0:0:0: [sde] Unhandled sense code
Nov 27 18:09:30 morphius kernel: sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 27 18:09:30 morphius kernel: sd 5:0:0:0: [sde] Sense Key : Medium Error [current] [descriptor]
Nov 27 18:09:30 morphius kernel: Descriptor sense data with sense descriptors (in hex):
Nov 27 18:09:30 morphius kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 27 18:09:30 morphius kernel:        54 68 9b 27
Nov 27 18:09:30 morphius kernel: sd 5:0:0:0: [sde] Add. Sense: Unrecovered read error - auto reallocate failed
Nov 27 18:09:30 morphius kernel: end_request: I/O error, dev sde, sector 1416141607
Nov 27 18:09:30 morphius kernel: ata6: EH complete
Nov 27 18:09:32 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:32 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:32 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:32 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:32 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:32 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:32 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:32 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:32 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:32 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:32 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:32 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:32 morphius kernel: ata6: hard resetting link
Nov 27 18:09:33 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:33 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:33 morphius kernel: ata6: EH complete
Nov 27 18:09:35 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:35 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:35 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:35 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:35 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:35 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:35 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:35 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:35 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:35 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:35 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:35 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:35 morphius kernel: ata6: hard resetting link
Nov 27 18:09:36 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:36 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:36 morphius kernel: ata6: EH complete
Nov 27 18:09:39 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:39 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:39 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:39 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:39 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:39 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:39 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:39 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:39 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:39 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:39 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:39 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:39 morphius kernel: ata6: hard resetting link
Nov 27 18:09:40 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:40 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:40 morphius kernel: ata6: EH complete
Nov 27 18:09:42 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:42 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:42 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:42 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:42 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:42 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:42 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:42 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:42 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:42 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:42 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:42 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:42 morphius kernel: ata6: hard resetting link
Nov 27 18:09:43 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:43 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:43 morphius kernel: ata6: EH complete
Nov 27 18:09:46 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:46 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:46 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:46 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:46 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:46 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:46 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:46 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:46 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:46 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:46 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:46 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:46 morphius kernel: ata6: hard resetting link
Nov 27 18:09:47 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:47 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:47 morphius kernel: ata6: EH complete
Nov 27 18:09:49 morphius kernel: ata6: EH in SWNCQ mode,QC:qc_active 0x1 sactive 0x1
Nov 27 18:09:49 morphius kernel: ata6: SWNCQ:qc_active 0x1 defer_bits 0x0 last_issue_tag 0x0
Nov 27 18:09:49 morphius kernel:  dhfis 0x1 dmafis 0x1 sdbfis 0x0
Nov 27 18:09:49 morphius kernel: ata6: ATA_REG 0x41 ERR_REG 0x40
Nov 27 18:09:49 morphius kernel: ata6: tag : dhfis dmafis sdbfis sacitve
Nov 27 18:09:49 morphius kernel: ata6: tag 0x0: 1 1 0 1
Nov 27 18:09:49 morphius kernel: ata6.00: exception Emask 0x1 SAct 0x1 SErr 0x0 action 0x6 frozen
Nov 27 18:09:49 morphius kernel: ata6.00: Ata error. fis:0x21
Nov 27 18:09:49 morphius kernel: ata6.00: cmd 60/08:00:27:9b:68/00:00:54:00:00/40 tag 0 ncq 4096 in
Nov 27 18:09:49 morphius kernel:         res 41/40:04:27:9b:68/40:00:54:00:00/40 Emask 0x9 (media error)
Nov 27 18:09:49 morphius kernel: ata6.00: status: { DRDY ERR }
Nov 27 18:09:49 morphius kernel: ata6.00: error: { UNC }
Nov 27 18:09:49 morphius kernel: ata6: hard resetting link
Nov 27 18:09:50 morphius kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 27 18:09:50 morphius kernel: ata6.00: configured for UDMA/133
Nov 27 18:09:50 morphius kernel: sd 5:0:0:0: [sde] Unhandled sense code
Nov 27 18:09:50 morphius kernel: sd 5:0:0:0: [sde] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 27 18:09:50 morphius kernel: sd 5:0:0:0: [sde] Sense Key : Medium Error [current] [descriptor]
Nov 27 18:09:50 morphius kernel: Descriptor sense data with sense descriptors (in hex):
Nov 27 18:09:50 morphius kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 27 18:09:50 morphius kernel:        54 68 9b 27
Nov 27 18:09:50 morphius kernel: sd 5:0:0:0: [sde] Add. Sense: Unrecovered read error - auto reallocate failed
Nov 27 18:09:50 morphius kernel: end_request: I/O error, dev sde, sector 1416141607
Nov 27 18:09:50 morphius kernel: ata6: EH complete
  • jan99999
Met tool van hd fabrikant checken, zeker indien je garantie hebt.
Doe eens een tijdje files kopieren, dus hele hd vullen, leeg maken en weer vullen.
Dan de hd checken op fouten of gebruiken en zo fouten te zien.
  • u_nix_we_all
Misschien een stomme vraag, maar waarom gebruik je RAID 0 ? En ben je je hele FS kwijt, of alleen enkele bestanden ?
You don't need a parachute to go skydiving. You need a parachute to go skydiving twice.
  • AlterMann
  • Laatst online: 10:00
Auw. Jij hebt dezelfde meldingen als ik had op 2 van mijn Samsung F1's..
Draai eens een "smartctl -t short /dev/sde" en dan na een minuut of 2 "smartctl -l selftest /dev/sde"
Als je onderstaande grappen krijgt zou ik maar RMA gaan aanvragen. Mijn schijfjes zijn vandaag met de postbode meegegaan naar Samsung..
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 0
Warning: ATA Specification requires self-test log structure revision number = 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed: read failure       20%     12395         1002693570
  • jb044
u_nix_we_all schreef op maandag 30 november 2009 @ 17:57:
Voor de snelheid en bijkomend voordeel is dat ik nu 1 map heb met heel veel ruimte, het ging trouwens om 2 files en kennelijk om 9 bad sectors.
  • jb044
Ok toch maar Samsungs ESTool laten testen en dat was dus niet best: ruim 300 bad sectors! HDD is inmiddels vervangen.
Alleen weet ik nu nog niet van het hoe en wat van de current pending sector count setting van SMART :D
Een andere Samsung F1 schijf heeft namelijk 107 reallocated sectors en die doet het in tegenstelling tot de andere wel al ruim een jaar prima.
