• philotra
  • Laatst online: 03-01-2022
philotra
Hier had uw tekst kunnen staan
Hallo mede tweakers,
Ik wil op het Wifi-netwerk van mijn universiteit kunnen internetten met mijn telefoon, maar dat lukt maar niet :(. Ik krijg steeds weer een inlogscherm terug. Ik heb zo'n beetje alles gedaan wat er in de (trouwens XP-) handleiding stond. Iemand suggesties of soortgelijke ervaringen?
How to connect to the WUR wireless network with your WUR user account.
This document describes a XP SP2 PC with a standard Microsoft supplicant.
Enable the Wireless Adapter with the proper button.
Select: Start, Control Panel, Network Connections and double click Wireless Network
Connection and select Properties
Select the tab Wireless Networks and select Add
Type the SSID: wur-user
Network Authentication: WPA or WPA2
Data encryption: TKIP (for WPA) or AES (for WPA2)
Tick the Box next to: Connect even if this network is not broadcasting
Select the Authentication tab
Select EAP type: Protected EAP (PEAP)
Do NOT select: Authenticate as comouter when computer information is available
Do NOT select: Authenticate as guest when user or computer information is unavailable
Select Properties
Do NOT select any certificate
Select Authentication Method: Secured password (EAP-MSCHAP V2)
Select Configure
Do NOT select Automatically use my Windows logon name and password (and domain
if any)
Press OK
Select the Connection tab and select Connect when this network is in range
Select OK
The wur-user SSID will now be connected
A balloon will appear at the bottom of the screen:
Select this balloon and supply your WUR username, password and domain name
Select OK
The balloon will only appear the first time you connect to the wur-user SSID. After a
successful authentication the credentials will be cashed on the PC.
The wur-user SSID will now be Connected
An “ipconfig” DOS box will show an IP address in the 172.18.*.* range.
De dikgedrukte stukken zijn de dingen die ik zeker weten heb kunnen doen op mijn telefoon, de rest neem ik aan dat het standaard zo is.
Ik heb trouwens een HTC Touch Pro met windows 6.5
  • philotra
philotra
Kan niemand mij helpen met inloggen? Weet er iemand een handig programmatje of instellingkje die dit wel mogelijk maakt?
Alvast bedankt,
  • DefLite
  • Laatst online: 08-07 23:28
DefLite
Why so serious?
Ga langs de helpdesk van de uni oid? Of bel de technische dienst en vraag of het uberhaupt kan?
  • thaan
  • Laatst online: 12:41
Ik kan me zo voorstellen dat je voor eduroam eerst een certificaat nodig hebt.
Vervolgens is dit het eerste wat google bij mij eruit gooit, wat eruit ziet alsof het zou moeten werken (met de gegevens van jouw universiteit, natuurlijk).
  • mantamiep
  • Laatst online: 04-07-2025
verkeerd topic, sorry
[ Voor 93% gewijzigd door mantamiep op 27-11-2009 16:17 ]
  • Thijsg
  • Laatst online: 11-04 20:29
het lukt mij ook niet om in te loggen op het netwerk van de wur.
Ik krijg ook telkens een popup scherm voor mij username en wachtwoord, maar die blijft terugkomen. Na meerdere keren op ok klikken wordt het vinkje bij verborgen netwerk automatisch weggehaald en wordt er in plaats van peap, smartcard/certificate gebruikt.
Het standaard certificaat heb ik ook al een aantal maal vernieuwd(GTE CyberTrust Global Root) wat geen resultaat geeft. Ik denk dat het toch te maken heeft met de inloggegevens, terwijl ik dezelfde gegevens (voor.achternaam@wur.nl + wachtwoord) invul met domein WUR als een studiegenoot met een iphone.
Heeft iemand een oplossing of dit al werkend gekregen onder windows mobile???
  • ronh
  • Laatst online: 26-11-2025
Heeft de WUR geen helpdesk?
Ik doe dit dagelijks op het ROC waar ik werk.
  • DukeBox
Thijsg schreef op dinsdag 01 december 2009 @ 18:05:
Vult die studiegenoot dan ook een domein in ? Het komt niet vaak voor om @... te gebruiken naast een domein.
  • Thijsg
ja die vult ook en domein in. Maar ook zonder een domein in te vullen wil het niet lukken.
De helpdesk is er wel, maar mijn ervaring ermee is dat ze alleen willen helpen als er in een zaal de beamer kapot is ofzo. Ze zijn er ook niet echt blij mee dat er mensen zijn die met hun windows phone op het internet willen, terwijl ze zelf wel een handleiding hebben geschreven voor de iphone...
Ik zal deze week nog wel eens een keer langs gaan kijken of ze goede zin hebben vandaag.
  • DukeBox
Het helpt natuurlijk om op vrijdag middag even langs te gaan met een sixpack (koud!) bier.. ;)
  • philotra
philotra
Bedankt allemaal jongens voor de reacties! Volgende week ga ik even kijken of het lukt! :)
  • Leader98
  • Laatst online: 09-07 21:37
Op http://www.wireless.wur.nl staan de instellingen die nodig zijn om op het WUR wireless netwerk te kunnen komen.
Probeer als inlognaam: WUR\Name001 oid te gebruiken.
