[debian] vmware-config : Unable to build the vmmon module.
  • Boudewijn
Boudewijn
omdat het kan
Hoihoi
Ik heb een schone debian installatie (stable) waar ik ivm mijn NICs een kernel van >2.6.26 op moet draaien (igb driver herkend de nics op mijn supermicro x8dtn+ anders niet).
Nu heb ik 2.6.30 geinstalleerd via backports:
apt-get install -t lenny-backports linux-image-2.6-amd64 linux-headers-2.6-amd64
Prima, symlinkje aangmaakt:
blackbox:/usr/src# ls -alh /usr/src/
total 32K
drwxrwsr-x  8 root src  4.0K 2009-11-18 16:31 .
drwxr-xr-x 11 root root 4.0K 2009-11-17 19:13 ..
lrwxrwxrwx  1 root src    33 2009-11-18 16:31 linux -> linux-headers-2.6.30-bpo.1-amd64/
drwxr-xr-x  4 root root 4.0K 2009-11-17 20:36 linux-headers-2.6.26-2-amd64
drwxr-xr-x 18 root root 4.0K 2009-11-17 20:36 linux-headers-2.6.26-2-common
drwxr-xr-x  4 root root 4.0K 2009-11-18 03:03 linux-headers-2.6.30-bpo.1-amd64
drwxr-xr-x  4 root root 4.0K 2009-11-18 03:03 linux-headers-2.6.30-bpo.1-common
drwxr-xr-x  3 root root 4.0K 2009-11-17 20:36 linux-kbuild-2.6.26
drwxr-xr-x  3 root root 4.0K 2009-11-18 03:03 linux-kbuild-2.6.30
Echter stopt de vmware installer er mee:
29
30
31
32
33
34
35
36
37
38
39
40
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.30-bpo.1-amd64/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config1/vmmon-only'
make -C /lib/modules/2.6.30-bpo.1-amd64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.30-bpo.1-amd64'
  CC [M]  /tmp/vmware-config1/vmmon-only/linux/driver.o
In file included from /tmp/vmware-config1/vmmon-only/linux/driver.c:31:
/tmp/vmware-config1/vmmon-only/./include/compat_wait.h:78: error: conflicting types for ‘poll_initwait’
/usr/src/linux-headers-2.6.30-bpo.1-common/include/linux/poll.h:67: error: previous declaration of ‘poll_initwait’ was here
/tmp/vmware-config1/vmmon-only/linux/driver.c: In function ‘LinuxDriverSyncCallOnEachCPU’:
/tmp/vmware-config1/vmmon-only/linux/driver.c:1423: error: too many arguments to function ‘smp_call_function’
/tmp/vmware-config1/vmmon-only/linux/driver.c: In function ‘LinuxDriver_Ioctl’:
/tmp/vmware-config1/vmmon-only/linux/driver.c:1987: error: ‘struct task_struct’ has no member named ‘euid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1987: error: ‘struct task_struct’ has no member named ‘uid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1988: error: ‘struct task_struct’ has no member named ‘fsuid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1988: error: ‘struct task_struct’ has no member named ‘uid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1989: error: ‘struct task_struct’ has no member named ‘egid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1989: error: ‘struct task_struct’ has no member named ‘gid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1990: error: ‘struct task_struct’ has no member named ‘fsgid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:1990: error: ‘struct task_struct’ has no member named ‘gid’
/tmp/vmware-config1/vmmon-only/linux/driver.c:2007: error: too many arguments to function ‘smp_call_function’
make[4]: *** [/tmp/vmware-config1/vmmon-only/linux/driver.o] Error 1
make[3]: *** [_module_/tmp/vmware-config1/vmmon-only] Error 2
make[2]: *** [sub-make] Error 2
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.30-bpo.1-amd64'
make: *** [vmmon.ko] Error 2
make: Leaving directory `/tmp/vmware-config1/vmmon-only'
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/go/unsup-linux-products" and
"http://www.vmware.com/go/unsup-linux-tools".
Uiteraard beide pages al bekeken.
Weet iemand wat ik hieraan kan doen?
[ Voor 3% gewijzigd door Boudewijn op 18-11-2009 16:43 ]
  • gertvdijk
  • Laatst online: 22:41
Boudewijn schreef op woensdag 18 november 2009 @ 16:26:
Misschien helpt het upgraden van de gcc versie naar de versie waarmee de kernel ook is gebouwd. Iets dergelijks moet je ook doen bij de installatie van de 'upstream' versie van de NVidia driver. Die miept dan ook over het verschil tussen bijv. gcc-4.1 en gcc-4.3.
Kia e-Niro 2021 64kWh DynamicPlusLine. 3x Victron MP-II op 15kWh US5000 3f thuisbatterij met 3x25A→3x40A PowerAssist, Victron EVCS, 3200Wp HoyMiles zp. my GitHub, my blog
  • Boudewijn
Boudewijn
omdat het kan
gcc is al up to date, net als g++.
Heb net dit gedaan:
apt-get install -t lenny-backports gcc g++ build-essential
Met als resultaat:
blackbox:~/vmware-server-distrib# gcc -v
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 4.3.2-1.1' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --enable-cld --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.3.2 (Debian 4.3.2-1.1)
Er is wel wat geupdate ivm build-essential, maar dat biedt ook geen soelaas.
Hmm fijn.
  • blaataaps
Al eens bij de diverse andere mensen met dit probleem gekeken? Voor ubuntu is er een patch-set, in elk geval voor vmware workstation en de modules.
http://communities.vmware.com/thread/241271
http://www.linuxpro.co.za...nstall-crashes-solutions-
http://ubuntuforums.org/showthread.php?t=1230548
  • Boudewijn
Boudewijn
omdat het kan
Nee, ik had dit nog niet gelezen.
Nu echter wel, en ik snap niet helemaal wat die patch doet. Ik ben bekend met patches etc, maar snap de opzet hier niet.
Hier wordt het goed uitgelegd.
http://communities.vmware.com/message/1296880#1296880
Maar wat is nou de bedoeling?
Zoals uitgelegd in de gelinkte post, op wat spullen in /usr uitvoeren:
blackbox:/usr/src/vmware-patches# pwd ;ls
vmci.tar   vmware-server.2.0.1_x64-modules-2.6.30-fix.patch
vmmon.tar  vmware-server.2.0.1_x64-modules-2.6.30-fix.sh
vmnet.tar  vsock.tar
Dat gaat prima....
Replacing original file vmnet.tar with patched file
Replacing original file vmmon.tar with patched file
Replacing original file vsock.tar with patched file
Replacing original file vmci.tar with patched file
Done!
I have changed the files in here:
/usr/lib/vmware/modules/source
I have placed a backup of the original files in here:
/usr/lib/vmware/modules/source-backup
The original VMware modules directory is still in the way.
Please move this directory somewhere else, because it confuses VMware:
/usr/lib/vmware/modules/binary
This command should work now, to install the modules:
vmware-config.pl -d
Daarna:
/usr/bin/vmware-config.pl
En dan werkt het :).
Woohoo!
Bedankt voor de tip.
