problemen met western digital nasbox
de laatste weken heb ik last dat mijn western digital nasbox spontaan niet meer bereikbaar is en dat ik hem dan opnieuw moet opstarten ,nu hebben we sinds kort een windows 7 pc met een ip 192.168.1.84 (zie log)
nu heb ik even in mijn log files zitten kijken maar snap er niks van kan iemand mij vertellen wat er fout kan gaat of fout is .
2009/11/14 11:41:48 write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
2009/11/14 11:41:48 getpeername failed. Error was Transport endpoint is not connected
2009/11/14 10:15:31 Error writing 4 bytes to client. -1. (Connection reset by peer)
2009/11/14 10:15:31 write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
2009/11/14 10:15:31 getpeername failed. Error was Transport endpoint is not connected
2009/11/14 09:53:54 Error writing 4 bytes to client. -1. (Connection reset by peer)
2009/11/14 09:53:54 write_data: write failure in writing to client 192.168.1.83. Error Connection reset by peer
2009/11/14 09:43:30 Error writing 4 bytes to client. -1. (Connection reset by peer)
2009/11/14 09:43:30 write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
2009/11/14 09:43:30 getpeername failed. Error was Transport endpoint is not connected
2009/11/14 08:03:51 Error writing 4 bytes to client. -1. (Connection reset by peer)
2009/11/14 08:03:51 write_data: write failure in writing to client 192.168.1.70. Error Connection reset by peer
2009/11/14 08:03:51 getpeername failed. Error was Transport endpoint is not connected
2009/11/13 22:55:03 martijn-pc (192.168.1.84) closed connection to service dvd
2009/11/13 22:51:17 read_data: read failure for 4 bytes to client 192.168.1.84. Error = Connection reset by peer
2009/11/13 22:51:05 martijn-pc (192.168.1.84) closed connection to service muziek
2009/11/13 22:50:24 martijn-pc (192.168.1.84) connect to service muziek initially as user martijn (uid=503, gid=1000) (pid 7056)
2009/11/13 22:24:41 martijn-pc (192.168.1.84) closed connection to service muziek
2009/11/13 22:24:28 martijn-pc (192.168.1.84) connect to service dvd initially as user martijn (uid=503, gid=1000) (pid 5916)
2009/11/13 22:24:23 martijn-pc (192.168.1.84) connect to service muziek initially as user martijn (uid=503, gid=1000) (pid 5916)
2009/11/13 22:23:30 martijn-pc (192.168.1.84) closed connection to service muziek
2009/11/13 22:22:23 martijn-pc (192.168.1.84) closed connection to service dvd
met vrg jeroen
  • Equator
  • Laatst online: 16-10 16:07
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Mja, er lijkt wel iets fout te gaan, maar dat is IMO niet direct met het netwerk.
Het is een thuis NAS neem ik aan? Heb je al eens contact opgenomen met de leverancier (WD) misschien is het een bekend probleem wat met een firmware upgrade op te lossen is.
Ik verplaats het topic in ieder geval even naar Netwerken want het betreft geen professioneel iets. :)
