[Win 7] Klok Format veranderen
  • Gnermo
  • Laatst online: 03-09 18:40
Gnermo
All about that bass!
Hey allemaal.
Ben gewend geraakt aan de engelse Windows 7, maar de klok onderin in AM stoort.
Weet iemand hoe ik dit snel verander naar normale digitale tijd?
  • BtM909
BtM909
Watch out Guys...
Je kan in je regional settings toch bepalen hoe je datum en tijd formaat moet worden weergegeven? ;)
  • Wiethoofd
  • Laatst online: 30-09 23:41
Wiethoofd
Broadcast TOM
Land en taalinstellingen aanpassen? Hier kun je de tijd en datum weergave ook aanpassen.
  • Yippie
  • Laatst online: 23-10 23:30
Er zit ook al een tijdje een uitstekende help functie in MS producten.
Jammer dat het zo weinig wordt gebruikt, probeer het eens wat vaker zou ik zeggen.
Start>Help and Support> Tik in "change time" geeft:
Change the display of dates, times, currency, and measurements
[This content is preliminary and subject to change.]
You can change the format Windows uses to display dates, times, currency, and measurements. You can also change the sorting order of text to match sorting rules used in a specific country or region.
Click to open Region and Language.
Click the Formats tab, and then, in the Format list, select the locale to use for the display of the date, time, currency, and measurements.
Note
With this version of Windows, administrators can set custom locales. There are two types of custom locales: supplemental locales and replacement locales. Supplemental locales contain locale data that isn't available with any of the current locales and have unique names. For example, an enterprise might create a supplemental locale to meet the specific needs of all of its employees. Replacement locales are a customization of the locales that are included with this version of Windows. For example, if an enterprise wants to make a small change to an existing locale, such as making sure that its employees use the 24-hour clock, the enterprise could make this change using a replacement locale. If you're using either a supplemental or replacement locale, the name of the locale will have an asterisk next to it in the format list.
Select the date and time formats that you want to use. To further customize how the date, time, currency, and measurements are displayed, click Additional settings, and then do one of the following:
To change the way your computer displays numbers, click the Numbers tab. Items you might want to change based on the format language you chose include the decimal symbol and list separator, the format used for negative numbers and leading zeros, and the measurement system used (U.S. or metric).
To change the way your computer displays currency values, click the Currency tab. Items you might want to change based on the format language you chose include the currency symbol, the formats used for positive or negative amounts, and the punctuation used to separate numbers.
To change the way your computer displays the time, click the Time tab. For more information about setting the clock, see Set the clock.
To change the way your computer displays the date, click the Date tab.
Note
If you choose a locale that uses eras to represent dates, then "gg" will be used as the notation to indicate an era in the short and long date settings.
