ik krijg deze melding van de madonion-site
We've finished analyzing your PC and have determined that you are running a system that contains: Intel Celeron 525MHz processor, ATI RADEON DDR based graphics card and 256 MB of memory.
Your current PC is an EXCELLENT system that will allow you to run even the most demanding of today's applications.
Unfortunately, we are unable to provide you with recommendations at this time.
The PC you are currently using is either too old or too new to have sufficient statistical representation in our performance database.
If the PC you are using is too old to be identified, then we are not be able to recommend cost effective component upgrades for you.
If your PC is too new to be analyzed with absolute accuracy…Congratulations! We suggest that you check back with us periodically to see if your upgrade options have changed. New products are constantly being introduced, products that may be just what you are looking for to keep you at the top of the performance scale.
zo oud/nieuw is mijn systeem tog niet of loop ik toch zo ver achter
