[word 2007] Macrobeveiligingsmelding bij opstarten *
  • RaJitsu
  • Laatst online: 15-10 08:06
Ik krijg iedere keer als ik Word opstart een melding over een macroerror. Dit is gebeurd nadat ik van Blackboard een document had gedownload en opgeslagen. Voorheen kreeg ik deze melding niet. Ik heb net een schone installatie gedaan voor Windows 7. In Vista had ik dit probleem ook en was blij dat ik ervan af was.
De melding is als volgt:
This error usually occurs because of macro security settings. If you know that the macro comes from a source that you trust, you can change your macro security settings to allow you to enable the macro. The way that you change your macro security settings depends on the Microsoft Office System program that you are using.
Microsoft Office Access, Microsoft Office Excel, Microsoft Office PowerPoint, or Microsoft Office Word --
To check your macro security settings, click the Microsoft Office Button, click <program name> Options, click Trust Center, and then click Trust Center Settings.
If macro security is set to Disable all macros without notification, all macros are automatically disabled. Use the following procedure to enable the macro.
In the Trust Center dialog box, click Macro Settings, and then click Disable all macros with notification.
Click OK in the Trust Center dialog box to apply the new setting. Click OK to close the program options dialog box.
Close the file and the Microsoft Office program that you are using.
Open the file again. A Security Alert appears in the Document Information Bar just below the ribbon. Click Enable Content to allow the macro to run.
When you have enabled the macro, it is recommended that you return the macro security setting to Disable all macros without notification.
If macro security is set to Disable all macros with notification, but you selected Disable when prompted by the macro warning dialog when you opened the file, use the following procedure to enable the macro.
In the Trust Center dialog box, click Cancel. Click Cancel to close the program options dialog box.
If macro security is set to Disable all macros except digitally signed macros, the macro may not have been digitally signed. Verify that you can trust the macro before using the following procedure to allow it to run.
Microsoft Office Outlook, Microsoft Office Visio, or Microsoft Office Publisher --
To check your macro security settings, on the Tools menu, click Trust Center, and then click Macro Security.
If macro security is set to No warnings and disable all macros, all macros are automatically disabled. Use the following procedure to enable the macro.
In the Trust Center dialog box, click Warnings for signed macros; all unsigned macros are disabled, and then click OK.
Open the file again. When prompted, click Enable Content to allow the macro to run. If you are using Visio, the Enable Content button appears as part of a Security Alert in the Document Information Bar. If you are not prompted to enable the macro, or if you receive this error again, the macro may not be digitally signed. Verify that you can trust the macro. If you are certain that you can trust the macro, use the next procedure below to enable the macro.
When you have enabled the macro, it is recommended that you return the macro security setting to No warnings and disable all macros.
If macro security is set to Warnings for signed macros; all unsigned macros are disabled, the macro may not be digitally signed. If you are certain that you can trust the macro, use the following procedure to enable the macro.
In the Trust Center dialog box, click Warnings for all macros, and then click OK.
When you have enabled the macro, it is recommended that you return the macro security setting to Warnings for signed macros; all unsigned macros are disabled.
Microsoft Office Project --
To check your macro security settings, on the Tools menu, click Macro, and then click Security.
If macro security is set to Very High, use the following procedure to enable the macro.
In the Security dialog box, click High, and then click OK.
Close the file and Microsoft Office Project.
Open the file again. When prompted, click Enable Content to allow the macro to run. If you are not prompted to enable the macro, or if you receive this error message again, the macro may not be digitally signed. Verify that you can trust the macro. If you are certain that you can trust the macro, use the next procedure below to enable the macro.
When you have enabled the macro, it is recommended that you return the macro security setting to Very High.
If the macro security setting is set to High, the macro may not be digitally signed. If you are certain that you can trust the macro, use the following procedure to enable the macro.
In the Security dialog box, click Medium, and then click OK.
When you have enabled the macro, it is recommended that you return the macro security setting to High.
This error may also occur for the following reasons:
The certificate of trust that is attached to the macro is invalid. Unless you are certain that the macro is safe, it is recommended that you not trust or run the macro.
The certificate is no longer trusted, was revoked by the issuing authority, or is damaged. Unless you are certain that the macro is safe, it is recommended that you not trust or run the macro.
Visual Basic for Applications (VBA) is not installed on your computer. In this case, no VBA macro can be run, regardless of whether the macro has a valid certificate of trust. You or your administrator may have chosen not to install VBA, or the version of Microsoft Office that you are using may not install VBA by default. If your version of Microsoft Office does not provide VBA as an installable feature, you can upgrade to a version that provides VBA support.
If you are unable to change the security settings, it is possible that another program has locked the security settings. Close all Microsoft Office System programs, then restart your program and change the security settings.
More information about this error message online.
Ik heb geprobeerd om de instructies op te volgen, maar ik krijg in Word alleen maar de melding bij het opstarten van Word (leeg of middels een document). Dit:
kan ik dus niet doen. Ik kan me niet voorstellen dat ik de enige ben met dit probleem. Iemand een oplossing?
Ik krijg trouwens ook een andere melding, over het bestand 'normal.dotm. Na het klikken op help:
This message can appear if you made changes to items, such as macros, toolbars, or AutoText, that are stored in a global template that is attached to your document. The most commonly used global template is Normal.dotm, which comes with Word.
If you save the changes, they will be available to all documents to which this global template is attached. If you don't save the changes, the changes are discarded from the template.
If you see this message often, you may want to turn off the Prompt before saving Normal template option. To turn off this option, click the Microsoft Office Button, click Word Options, and then click Advanced. Under Save, clear the Prompt before saving Normal template check box. If this check box is already clear, or if clearing it does not resolve this issue, then there may be a problem with Word.
For more information, see the Microsoft Knowledge Base article 918064.
Instructies opgevolgd, maar niets verandert. :'(
Edit: Excuus voor de onduidelijk titel. Vergeten hem uit te breiden en te voorzien van een duidelijke titel die het probleem beter omschrijft..
[ Voor 7% gewijzigd door RaJitsu op 03-11-2009 08:48 ]
B.S.U.R.
  • Martin0
  • Laatst online: 14-10 16:20
heb je hem al vertaalt, zo niet hier krijg je de vertaalde versie:
Deze fout treedt meestal op als gevolg van macro beveiligingsinstellingen. Als u weet dat de macro afkomstig is van een bron die u vertrouwt, kunt u uw macro beveiligingsinstellingen zodat u de macro in te schakelen. De manier waarop u uw macro beveiligingsinstellingen hangt af van het Microsoft Office System-programma dat u gebruikt.
Microsoft Office Access, Microsoft Office Excel, Microsoft Office PowerPoint of Microsoft Office Word --
Om de macro beveiligingsinstellingen, klik op de Microsoft Office-knop, klik op <Programmanaam> Opties, klik op Vertrouwenscentrum en klik vervolgens op Vertrouwenscentrum Instellingen.
Als macro beveiliging is ingesteld op Alle macro's uitschakelen zonder melding, worden alle macro's automatisch uitgeschakeld. Gebruik de volgende procedure om de macro.
In het Vertrouwenscentrum dialoogvenster, klik op Instellingen voor macro's en klik vervolgens op Alle macro's uitschakelen met melding.
Klik op OK in het dialoogvenster Vertrouwenscentrum de toepassing van de nieuwe instelling. Klik op OK om het programma opties dialoogvenster te sluiten.
Sluit het bestand en de Microsoft Office-programma dat u gebruikt.
Open het bestand opnieuw. Een Security Alert verschijnt in het Document Information Bar net onder het lint. Klik op Inhoud inschakelen om de macro uit te voeren.
Wanneer u de macro hebt ingeschakeld, is het aanbevolen dat u terug de macro beveiligingsinstelling voor alle macro's uitschakelen, zonder melding.
Als macro beveiliging is ingesteld op Alle macro's uitschakelen met melding, maar u hebt geselecteerd uitschakelen wanneer daarom wordt gevraagd door de macro waarschuwing dialoogvenster wanneer u het bestand opende, gebruikt u de volgende procedure om de macro in te schakelen.
In het Vertrouwenscentrum dialoogvenster, klikt u op Annuleren. Klik op Annuleren om het programma afsluiten dialoogvenster Opties.
Als macro beveiliging is ingesteld op alle macro's uitschakelen, behalve digitaal ondertekende macro's, kan de macro niet digitaal zijn ondertekend. Controleer of u de macro kunt vertrouwen voordat u de volgende procedure om deze te lopen.
Microsoft Office Outlook, Microsoft Office Visio of Microsoft Office Publisher --
Als u de macro beveiligingsinstellingen controleren door in het menu Extra op Vertrouwenscentrum en klik vervolgens op Macrobeveiliging.
Als macro beveiliging is ingesteld op Nee waarschuwingen en alle macro's uitschakelen, worden alle macro's automatisch uitgeschakeld. Gebruik de volgende procedure om de macro.
In het Vertrouwenscentrum dialoogvenster, klikt u op Waarschuwingen voor macro's is ondertekend, alle niet-ondertekende macro's zijn uitgeschakeld, en klik op OK.
Open het bestand opnieuw. Wanneer u wordt gevraagd, klikt u op Inhoud inschakelen om de macro uit te voeren. Als u Visio gebruikt, de optie Inhoud knop verschijnt als onderdeel van een Security Alert in het Document Information Bar. Als u niet wordt gevraagd de macro inschakelen, of als u deze fout krijgt weer, kan de macro niet digitaal is ondertekend. Controleer of u de macro kunt vertrouwen. Als u zeker weet dat u de macro kan vertrouwen, gebruikt u de volgende procedure hieronder om de macro in te schakelen.
Wanneer u de macro hebt ingeschakeld, is het aanbevolen dat je terug de macro beveiligingsinstelling op Nee waarschuwingen en alle macro's uitschakelen.
Als macro beveiliging is ingesteld op Waarschuwingen voor macro's is ondertekend, alle niet-ondertekende macro's zijn uitgeschakeld, de macro kan niet worden digitaal ondertekend. Als u zeker weet dat u de macro kan vertrouwen, gebruikt u de volgende procedure om de macro in te schakelen.
In het Vertrouwenscentrum dialoogvenster, klikt u op Waarschuwingen voor alle macro's en klik op OK.
Wanneer u de macro hebt ingeschakeld, is het aanbevolen dat je terug de macro beveiligingsinstelling op Waarschuwingen voor macro's is ondertekend, alle niet-ondertekende macro's worden uitgeschakeld.
Als u de macro beveiligingsinstellingen controleren door in het menu Extra, klik op Macro en klik op Beveiliging.
Als macro beveiliging is ingesteld op Very High, gebruikt u de volgende procedure om de macro in te schakelen.
In het dialoogvenster Beveiliging, klik op Hoog, en klik op OK.
Sluit het bestand en Microsoft Office Project.
Open het bestand opnieuw. Wanneer u wordt gevraagd, klikt u op Inhoud inschakelen om de macro uit te voeren. Als u niet wordt gevraagd de macro inschakelen, of als u dit foutbericht weer, kan de macro niet digitaal is ondertekend. Controleer of u de macro kunt vertrouwen. Als u zeker weet dat u de macro kan vertrouwen, gebruikt u de volgende procedure hieronder om de macro in te schakelen.
Wanneer u de macro hebt ingeschakeld, is het aanbevolen dat je terug de macro beveiligingsinstelling tot zeer hoog.
Als de macro beveiliging is ingesteld op Hoog, kan de macro niet digitaal is ondertekend. Als u zeker weet dat u de macro kan vertrouwen, gebruikt u de volgende procedure om de macro in te schakelen.
In het dialoogvenster Beveiliging, klik op Medium, en klik op OK.
Wanneer u de macro hebt ingeschakeld, is het aanbevolen dat u terug de macro beveiligingsinstelling Hoog.
Deze fout kan ook optreden om de volgende redenen:
Het certificaat van vertrouwen dat is bevestigd aan de macro is ongeldig. Tenzij u zeker weet dat de macro veilig is, is het aanbevolen dat u niet vertrouwt of voer de macro.
Het certificaat is niet meer vertrouwde, werd ingetrokken door de uitvaardigende autoriteit, of is beschadigd. Tenzij u zeker weet dat de macro veilig is, is het aanbevolen dat u niet vertrouwt of voer de macro.
Visual Basic for Applications (VBA) is niet geïnstalleerd op uw computer. In dit geval kan geen VBA-macro wordt uitgevoerd, ongeacht of de macro heeft een geldig certificaat van vertrouwen. U of uw beheerder kan ervoor gekozen hebben niet te installeren VBA, of de versie van Microsoft Office die u gebruikt, kan niet VBA te installeren standaard. Als uw versie van Microsoft Office VBA niet bieden als een installeerbare functie kunt u upgraden naar een versie die voorziet VBA-ondersteuning.
Als u niet in staat zijn om de beveiligingsinstellingen te wijzigen, is het mogelijk dat een ander programma heeft vergrendeld de beveiligingsinstellingen. Sluit alle Microsoft Office System-programma's, start uw programma en wijzig de beveiligingsinstellingen.
Meer informatie over deze foutmelding online.
Twitch
  • RaJitsu
Tsja, de Engelse versie is al prima leesbaar. En de Nederlandse vertaling (die ik ook heb, aangezien Vista in het Nederlands was) helpt daar niet echt bij, aangezien de opties in mijn huidige Office Suite natuurlijk ook in het Engels zijn. Maar jij hebt het probleem ook merk ik? (anders had je het niet kunnen kopiëren lijkt me) Maar ook geen oplossing dus...
B.S.U.R.
kijk eens hier en hier.
voor add-ins die in de startupmap staan moet je deze via de windows verkenner verwijderen of verplaatsen.
  • Martin0
RaJitsu schreef op dinsdag 03 november 2009 @ 17:08:
ik heb een tool van google waarmee ik een hele pagina in het nederlands kan vertalen, en daarvan heb ik het gekopieerd :P.
Twitch
