[Joomla] Allemaal errors, file permissies niet goed?
  • 174 views
  • Autoreply
  • Laatst online: 13-10 20:43
Ubuntu (desktop), daar wil ik graag Joomla 1.5 op hebben.
Keurig volgens deze handleiding gedaan, geen problemen ondervonden, tot ik naar de directory met joomla surf:
Warning: session_start() [function.session-start]: open(/var/lib/php5/sess_0b788db650f4c832626f388704f40aa5, O_RDWR) failed: Permission denied (13) in /var/www/libraries/joomla/session/session.php on line 423
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /var/www/libraries/joomla/session/session.php:423) in /var/www/libraries/joomla/session/session.php on line 423
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /var/www/libraries/joomla/session/session.php:423) in /var/www/libraries/joomla/session/session.php on line 423
Warning: Cannot modify header information - headers already sent by (output started at /var/www/libraries/joomla/session/session.php:423) in /var/www/libraries/joomla/session/session.php on line 426
En onder het welkomstvenster:
Warning: session_write_close() [function.session-write-close]: open(/var/lib/php5/sess_0b788db650f4c832626f388704f40aa5, O_RDWR) failed: Permission denied (13) in /var/www/libraries/joomla/session/session.php on line 556
Warning: session_write_close() [function.session-write-close]: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in /var/www/libraries/joomla/session/session.php on line 556
Nou vermoed ik met mijn beperkte kennis dat er iets fout zit met file/folder permissies.
Ik heb echter:
sudo chown -R root:root /var/www/
cd /var/www/
PLACES='
administrator/backups
administrator/components
administrator/modules
administrator/templates
cache
components
images
images/banners
images/stories
language
plugins
media
modules
templates
for i in $PLACES; do
    sudo chown -R www-data:www-data $i
done
uitgevoerd, zonder errors. Het ontbreken van /joomla/ na de mappen is overal doorgevoerd.
Hellup :$
  • Creepy
  • Laatst online: 19-10 23:04
Creepy
Tactical Espionage Splatterer
Met software ontwikkeling heeft het niks te maken. Met installatie des te meer. Joomla heeft een prima supportforum waar je in eerste instantie terecht kan voor vragen en problemen. Mocht je er dan nog niet uitkomen dan kan je hier op het forum een topic openen. Doe dat dan wel op de juiste plek ;) Programming is het deel voor het zelf ontwikkelen van software. Als je Waar hoort mijn topic? eens doorkijkt dan zie je vanzelf hoe en wat.
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
