[Keynote '08] Theme met image saved niet
  • Jo-re-mi
  • Laatst online: 06-09-2024
Jo-re-mi
_ _ _d(□_□)b
Ik was zojuist in Keynote '08 een mooie theme aan het maken voor eventuele presentaties.
Ik had hiervoor een afbeelding voor background gekozen. Gewoon Jpeg. Werkte prima.
Toen heb ik 'm gesaved als Theme. Ging allemaal goed.
Toen wilde ik checken offie er goed uitkwam bij openen. Dat kwam die dus niet. In de Theme chooser stond die zoals ik 'm had gemaakt, maar hij opende de theme waar vanuit ik dit thema met afbeelding had gemaakt (in dit geval Zwart met witte letters).
Oftewel: thema's met afbeelding als background saved 'ie niet.
Doe ik iets fout? Zie ik iets over het hoofd?
  • Jo-re-mi
Jo-re-mi
_ _ _d(□_□)b
Kan niemand me hierbij helpen?
  • Exphy
  • Laatst online: 27-08 16:15
heb je gegoogled?
One day, I decided that I was sick and tired of having to change the background and manually lay out all the elements in my keynote presentation. So, rather than not making any more, I decided that I would make my own theme. So, I went into keynote, designed a good looking theme, and went to File>Save Theme... After saving my beautiful theme I closed my document and opened up a new one. However, when I chose my theme from the theme chooser dialog box, nothing happened. It just showed me the "white" theme I had built off of. Well, I went onto the internet and found no help. None. Since I'm not one to pay for something I can probably figure out myself, I started looking. And here's how you do it.
How to create themes in keynote '08.
Creating themes in keynote really isn't that hard. There's just one secret step. Rather than building your theme from a slide, you have to build your theme from a master slide. To do this, merely drag the divider that's underneath the "Themes" button. This will reveal all the masters. Now, go about editing them as you please. Changing backgrounds. Adding in pictures. Setting fonts. You name it. Once you've done all this, go to File>Save Theme... and save your theme to the Themes folder. (Automatically selected.) That's it! It will now show up inside the theme dialog box.
Now that you know this information, go out and design some cool theme. Then, submit it to be posted on the blog!
bron
maar ik hoop dat dit is wat je zoekt
"If I drive fast enough at the red light, it'll appear green."
