MadDog MD-16XDVD9 could not perform end of disc-at-once
Hello All,
After I reinstalled my Dell computer (bought in 2004) I tried to burn a dvd with Nero and got error "Could not perform end of disc-at-once".
What did I do: I formatted c:, reinstalled Windows XP and installed Nero Version 7.9.6.0. When trying to burn DVD I get the error. I tried to find out what DVD burner I have, and seems to be a MadDog MD-16XDVD9.
I installed firmware 2.FC (the latest I could found), but still get the error.
Anyone know how to fix?
The report Nero gives:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
Recorder: Version: 2.FC - HA 1 TA 3 - 7.9.6.0
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: Version: F501 - HA 1 TA 0 - 7.9.6.0
=== Scsi-Device-Map ===
CdRomPeripheral : SAMSUNG DVD-ROM SD-616E atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MAD DOG MD-16XDVD9 atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3160023AS atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
SAMSUNG DVD-ROM SD-616E D: CdRom0
MAD DOG MD-16XDVD9 E: CdRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046624kB)
Free physical memory: 692MB (709096kB)
Memory in use : 32 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.10.2009
UDF/ISO-compilatie
14:32:50 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:32:50 #2 Phase 112 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation started
14:32:50 #3 Phase 114 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation completed (no file modified)
14:32:50 #4 Text 0 File Isodoc.cpp, Line 6663
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:32:50 #5 Phase 111 File dlgbrnst.cpp, Line 1762
DVD-Video files sorted
14:32:50 #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
14:32:50 #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
14:32:50 #8 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
14:32:50 #9 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2164383 (480:58.33, 4227MB)
14:32:50 #10 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
14:32:50 #11 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: MAD DOG MD-16XDVD9, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
14:32:50 #12 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
14:32:50 #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2164384 (2164384) = #2164384/480:58.34
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2164384 blocks [CdRom3 MAD DOG MD-16XDVD9]
14:32:50 #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [CdRom3 MAD DOG MD-16XDVD9] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4432658432, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2164384 | 0 | 0x00
2164384 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
14:32:50 #15 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
14:32:50 #16 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
14:32:50 #17 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
14:32:50 #18 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
14:32:50 #19 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
14:32:50 #20 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11.080 kB/sec)
14:32:50 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:32:50 #22 Text 0 File DVDR.cpp, Line 3225
Recording mode: Sequential Recording Mode
14:32:50 #23 Text 0 File DVDR.cpp, Line 3381
Start write address at LBA 0
DVD high compatibility mode: Yes
14:32:50 #24 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
14:32:50 #25 SPTI -1046 File SCSIPassThrough.cpp, Line 179
CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x53 00 00 00 00 00 21 06 A0 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
14:32:50 #26 CDR -1046 File ThreadedTransferInterface.cpp, Line 1752
Illegal disc
14:32:50 #27 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
Could not perform start of Disc-at-once
14:32:50 #28 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
14:32:50 #29 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 8x (11.080 kB/sec)
14:32:50 #30 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:32:53 #31 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
14:32:53 #32 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  • jan99999
  • Laatst online: 22:10
Andere merk dvd's proberen?
Oudere nero proberen?
Andere brand software?
what were you trying to burn? sometimes the data can be larger than will fit the dvd and you get that error because it's can't write it's begin/end sectors down
Ik heb meerdere bestanden geprobeerd, niet groter dan wat op een dvd kan.
Heb nu ook met ImgBurn geprobeerd, maar krijg ook fout:
I/O Error
Device: [0:1:0] MadDog MD-16XDVD9 2.FC (e:) (ATA)
ScsiStatus 0x02
Interpretation: Check Condition
CDB: 53 00 00 00 00 00 1E 3F 9B 00
Interpretation: Reserve Track - Sectors 1.982.363
Sense Area: 70 00 05 00 00 00 00 0A 00 00 00 00 30 05 00 00 00 00
Interpretation: Cannot Write Medium - Incompatible Format
