Ik ben bezig met een test opstelling en had het werken. (ssl1.example.com en localhost) draaide al goed via https. Nu wil ik alleen een extra virtualhost toevoegen namelijk ssl2.example.com.
Alleen als ik nu https://ssl2.example.com opvraag krijg ik de inhoud van https://ssl1.example.com te zien. https://ssl1.example.com en https://localhost werken wel gewoon.
dit is mijn virtual host config.
In de log files zie ik geen errors of rare dingen voorbij komen. Wat doe ik verkeerd.
29
30
31
32
33
34
35
| <VirtualHost _default_:443> DocumentRoot "/htdocs" ServerName localhost:443 ServerAdmin you@example.com ErrorLog /Applications/MAMP/logs/ssl_error_log TransferLog /Applications/MAMP/logs/ssl_access_log SSLEngine on SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL SSLCertificateFile /Applications/MAMP/conf/apache/ssl_crt/server.crt SSLCertificateKeyFile /Applications/MAMP/conf/apache/ssl_key/server.key </VirtualHost> <VirtualHost ssl1.example.com:443> DocumentRoot "/htdocs/ssl1" ServerName ssl1.example.com:443 ServerAdmin you@example.com ErrorLog /Applications/MAMP/logs/ssl_error_log TransferLog /Applications/MAMP/logs/ssl_access_log SSLEngine on SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL SSLCertificateFile /Applications/MAMP/conf/apache/ssl_crt/server.crt SSLCertificateKeyFile /Applications/MAMP/conf/apache/ssl_key/server.key </VirtualHost> <VirtualHost ssl2.example.com:443> DocumentRoot "/htdocs/ssl2" ServerName ssl2.example.com:443 ServerAdmin you@example.com ErrorLog /Applications/MAMP/logs/ssl_error_log TransferLog /Applications/MAMP/logs/ssl_access_log SSLEngine on SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL SSLCertificateFile /Applications/MAMP/conf/apache/ssl_crt/server.crt SSLCertificateKeyFile /Applications/MAMP/conf/apache/ssl_key/server.key </VirtualHost> |
Inside The Matrix, they are everyone, and they are no one.
