[AS3.0 & PHP] Probleem met FileReference (upload)
  • F e r o x
  • Laatst online: 18-11-2024
Ik heb een simpel stukje code in Flex die een bestand zou moeten uploaden naar de server:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
            private var _refAddFiles:FileReferenceList;
            private var _arrUploadFiles:Array = new Array();
            private const _strUploadScript:String = "./upload.php";
            private var _refUploadFile:FileReference;
            private function initApp():void {
                Security.allowDomain("./");
            private function addFiles():void
                _refAddFiles = new FileReferenceList();
                _refAddFiles.addEventListener(Event.SELECT, onSelectFile);
                _refAddFiles.browse();
            private function onSelectFile(event:Event):void
                _arrUploadFiles.push({label:_refAddFiles.fileList[0].name, data:_refAddFiles.fileList[0]});
            private function startUpload(booIsFirst:Boolean):void
                var sendVars:URLVariables = new URLVariables();
                sendVars.action = "upload";
                var request:URLRequest = new URLRequest();
                request.data = sendVars;
                request.url = _strUploadScript;
                request.method = URLRequestMethod.POST;
                _refUploadFile = new FileReference();
                _refUploadFile = _arrUploadFiles[0].data;
                _refUploadFile.addEventListener(IOErrorEvent.IO_ERROR, onUploadIoError);
                _refUploadFile.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onUploadSecurityError);
                _refUploadFile.upload(request, "file");
            private function onUploadIoError(event:IOErrorEvent):void
                mx.controls.Alert.show("IO Error in uploadbestand.", "Error");
                _refUploadFile.cancel();
            private function onUploadSecurityError(event:SecurityErrorEvent):void
                mx.controls.Alert.show("Security Error in uploadbestand.", "Error");
Voor de verwerking gebruik ik php:
PHP:
<?php
if($_REQUEST['action'] == "upload") {
    $uploaddir = "./";
    if(is_uploaded_file($_FILES['file']['tmp_name'])) {
         move_uploaded_file($_FILES['file']['tmp_name'],$uploaddir.'/'.$_FILES['file']['name']);
Dit programma'tje werkt perfect op mijn lokale webserver ( MAMP ). Maar wanneer ik het op mijn webserver plaats, dan krijg ik altijd een IOErrerEvent. Zelfs wanneer ik mijn php-script niets laat uitvoeren. Het probleem moet dus waarschijnelijk ergens bij mijn flex-code liggen.
De server-map is ingesteld dat er kan worden geschreven.
  • Megamind
  • Laatst online: 16-09 16:54
Weet je zeker dat je geen securityerror krijgt?
  • F e r o x
Neen, het is altijd een IOError.
Maar het probleem lijkt niet echt het schrijven naar de server te zijn. Wanneer ik mijn php-bestand niets laat uitvoeren (enkel php-sluittags), dan krijg ik al de IOError. Flex lijkt geen verbinding met het php-bestand te kunnen maken.
  • Megamind
Je kan ook trace(event) doen om te zien wat deze error precies vertelt.
  • F e r o x
Megamind schreef op zaterdag 10 oktober 2009 @ 12:04:
[IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2038: Bestands-I/O-fout. URL: http://www.url.com/test/upload.php"]
De link is zeker correct. Maar toch kan hij geen verbinding maken met het php-bestand.
php.ini is identiek op de lokale server als op de webserver.
  • Megamind
Heb je die flex app op hetzelfde domein staan?
Ik heb vaak ook problemen als ik een flash app vanaf bv localhost draai en deze probeer te laten verbinden met een externe server
  • F e r o x
Opgelost!
Probleem zat hem op de webserver. Hij was simpelweg te streng, en blokkeerde alles.
Ongelooflijk hoeveel probleempjes er altijd opduiken (maar zolang ze opgelost geraken valt het natuurlijk wel mee).
Bedankt voor de hulp alvast!
