.NET Framework 3.5 SP1 installeerd niet (error code 1603)
Hallo allemaal
Ik probeer al een flinke tijd Framework 3.5 geinstalleerd te krijgen. Ik heb de oudere Frameworks eraf gehaald, zoals werd voorgesteld op andere fora, maar er gebeurd nog steeds niets. Ook de Framework-remover-tool heb ik al geprobeerd. Ik gebruik momenteel Windows XP SP3.
Heeft iemand enig idee hoe ik dit kan oplossen?
Dit is de melding die ik krijg:
[09/17/09,18:15:12] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[09/29/09,00:03:56] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[09/29/09,00:05:50] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[09/29/09,00:05:55] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 SP2 x86 is not installed.
[09/29/09,00:24:58] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[09/29/09,00:48:27] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[09/29/09,00:48:34] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[09/29/09,00:51:59] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[09/29/09,00:52:06] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[09/29/09,00:55:55] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[09/29/09,00:56:00] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[09/29/09,00:58:37] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[09/29/09,00:58:42] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[09/29/09,01:09:54] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[09/29/09,01:09:58] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[09/29/09,01:21:53] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[09/29/09,01:21:58] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 SP2 x86 is not installed.
[09/29/09,01:40:16] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[09/29/09,01:40:21] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 SP2 x86 is not installed.
  • Millie-ano
Ook last van gehad. Na gegoogled te hebben over deze code moest ik veranderingen gaan aanbrengen in het register. Niks hielp. Alleen een schone installatie. Alles geformatteerd en weer gedaan en daarna deed hij het weer. Was overigens op Vista x64
Die veranderingen in het register heb ik ook geprobeerd, niets hielp inderdaad.
Maar ik heb het nou ook weer niet zo erg nodig dat ik mijn hele PC ga leeggooien. Er zitten achterlijk genoeg namelijk geen partities op. :P
  • TaraWij
  • Laatst online: 08-02-2025
Kijk eens of dit artikel je een oplossing biedt?
Helaas, ook dat mocht niet baten, ik heb beide mogelijkheden uit het artikel een paar keer geprobeerd, helaas zonder resultaat. Ik zet nu Framework 2.0 er weer op, want die en de versies ervoor werken wel. :S
Mocht iemand nog een oplossing weten voor het probleem, dan hoor ik die graag.
Iig bedankt allemaal!
  • TaraWij
Wat loopt er dan mis met de installatie van de eerste versie die volgt op 2.0?
Je moet eens kijken of de logs daar een soort van foutmelding geven.
Deze zijn normaal gezien te vinden in de %temp% map, met een naam in de aard van dd_* of *fx*.
