:o Nice. En het lijkt ook een telefoon te zijn gezien het SIM-slot.
Wel grappig dat ze doorborduren op het ontwerp/design van de N97 :9
En misschien is dit wel het apparaatje waar iedereen van denkt dat het de N97 mini of i is.
[ Voor 25% gewijzigd door Verwijderd op 09-08-2009 14:15 ]
  • janzeeschuimers
  • Laatst online: 08-11-2024
Als je de specs van de n900 vergelijkt met die van de n97 , dan komt de laatste er veel slechter uit:
1. Faster processor OMAP generation 3 (N900) compared to generation 2 (N97)
2. Double RAM memory 256 MB (N900) compared to 128 MB (N97)
3. 3D applications and OpenGL (3D fast games) supported by N900 processor
4. OpenOffice and KOffice (Word, spreadsheet, presentations PPT) for free in N900 compared to 30$-40$ QuickOffice in N97
5. Hundreds of free good applications for Maemo N900 and potential more hundreds from Linux community (including potential to have Google G1 application framework ported to Maemo) compared to almost not many good free application on Symbian.
6. Very good internet browsers FireFox , etc on Maemo, compared to not very performant browser on Symbian.
7. Full Java support for Maemo not only a subset like is for Symbian.
8. Full Flash support for Maemo, not just a mobile version like is for Symbian.
9. Easy to program Maemo compared to hard to program Symbian Carbide C. - more applications for N900 in future.
10. 800 x 480 resolution means VGA videos will not be shrinked, which is better quality watching videos and all the games and applications. (N900 has 800x480 and N97 has 640x360)
11. Command line is very important, because you can package quickly anything, run a Pearl or a shell batch file and you can install anything, you can update libraries and modules, install frameworks and do a lot of stuff.
12. Video recording is 800x480 on N900 which is better than 640x480 on N900
13. qole noted that Maemo 5 is "swishier" and very next-generation, with lots of transparency, 3D effects, swishing and swooping windows, etc. That tends to appeal to gadget hounds.
14. Linux is a solid OS, where Symbian is only a mobile OS.
15. Linux community is greater than Symbian's
16. Linux Maemo has many Virtual Machines (VM) which can run from Windows to different other systems.
17. Maemo has better remote connection applications, and with bigger resolution of N900 and much more memory (needed here) N900 will clearly subclass N97 in this category.
18. More printer drivers and other drivers in Linux.Maemo than Symbian. Linux cames from computer to mobile so it has more USB capabilities.
  • pven
Dit is toch geen topicstart? Je plempt twee URL's neer en thats it? :?
Deze gaat op slot. Je mag een nieuwe poging ondernemen, maar dan wel met een fatsoenlijke topicstart.
|| Unprompted (AI-blog) || slotje.com for sale || Dank pven! ||
