• huijaa
  • Laatst online: 20-05-2024
Ik heb altijd foutmelding bij het videoconversie m.b.v. FFmpeg 0.5 onder OpenSuse 11.0 64bits.
TS (Transport Stream) -> MPEG2
# ffmpeg -i nev.ts -target pal-dvd -vcodec copy -acodec copy nev.mpeg
FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  configuration:
  libavutil     49.15. 0 / 49.15. 0
  libavcodec    52.20. 0 / 52.20. 0
  libavformat   52.31. 0 / 52.31. 0
  libavdevice   52. 1. 0 / 52. 1. 0
  built on Jul 21 2009 17:45:48, gcc: 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 25.00 (25/1)
Input #0, mpegts, from 'nev.ts':
  Duration: 00:00:37.34, start: 20888.765189, bitrate: 2319 kb/s
    Stream #0.0[0x1b6d]: Video: mpeg2video, yuv420p, 704x576 [PAR 16:11 DAR 16:9], 15000 kb/s, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x1b6e]: Audio: mp2, 48000 Hz, stereo, s16, 160 kb/s
    Stream #0.2[0x1b6f]: Audio: 0x0000, 0 channels, s16
File 'nev.mpeg' already exists. Overwrite ? [y/N] y
Output #0, dvd, to 'nev.mpeg':
    Stream #0.0: Video: mpeg2video, yuv420p, 704x576 [PAR 64:45 DAR 704:405], q=2-31, 15000 kb/s, 90k tbn, 25 tbc
    Stream #0.1: Audio: mp2, 48000 Hz, stereo, s16, 160 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Press [q] to stop encoding
[NULL @ 0xee5830]error, non monotone timestamps 45104 >= 45104
av_interleaved_write_frame(): Error while opening file
Als U dit probleem wel kent, graag zowel hier posten als PM-en. Voorbaat dank.
since 21aug'04: Asus K8VSE Deluxe, AMD Athlon 64 3400+, Twimos 1 GB PC3200, Maxtor U133/7200 160GB+120GB, Asus V9999GE and SunBeam Aryclic Case
  • lamko
  • Laatst online: 02:33
Zou iets anders pakken om de TS naar mpeg2 om te zetten. Ik heb veel meer goeie ervaringen over project-x gehoord.
And this !! Is to go even further beyond!!!
