USB cardreaderAlcor Micro Corp word niet herkend in Ubuntu?
  • rob12424
  • Laatst online: 29-09 08:57
Hallo allemaal,
Ik heb een usb cardreader en deze word niet herkend in ubuntu in zovere hij zegt geen schijf in lade bij het mounten
Met het commando fdisk -l pakt hij hem ook niet:
lsusb geeft dit aan in ubuntu 9.04
pam_mount(pam_mount.c:100): unknown pam_mount option "use_first_pass"
Bus 001 Device 003: ID 058f:6331 Alcor Micro Corp.
Bus 001 Device 002: ID 04b8:0838 Seiko Epson Corp. CX7300/CX7400/DX7400
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
en dit is wat lspci zegt:
00:00.0 Host bridge: VIA Technologies, Inc. PT880 Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. PT880 Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. PT880 Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. PT880 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. PT880 Host Bridge
00:00.7 Host bridge: VIA Technologies, Inc. PT880 Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
00:0b.0 Multimedia controller: Philips Semiconductors SAA7134/SAA7135HL Video Broadcast Decoder (rev 01)
00:0d.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306 Fire II IEEE 1394 OHCI Link Layer Controller (rev 46)
00:0f.0 RAID bus controller: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 78)
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]
01:00.1 Display controller: ATI Technologies Inc Radeon R350 [Radeon 9800 Pro] (Secondary)
Ik heb de scsi pakketten al geinstaleerd maar zonder suc6!
Omdat er vaak gezegd word dat je zelf moet zoeken heb ik dit ook al gedaan maar ik kom er echt niet uit en ben al meer als 8 weken aan het zoeken naar een oplossing (niet 24 uur lang hoor!)
Heeft iemand een oplossing zodat ik heb kan mounten en partitioneren??
Alvast bedankt!
  • gertvdijk
  • Laatst online: 21:26
Nja het kan zijn dat deze kaartlezer gewoon niet wordt ondersteund, maar misschien kan je eerst even wat antwoord geven op de volgende vragen, omdat wij geen glazen bol hebben:
  • Waarop heb je gegoogled? Het beste kan je googlen met vendor/device id's. '058f:6331' in jouw geval. Dan kom je op dit soort topics uit, waar ik van denk dat jouw probleem er ook wel wat van weg heeft.
  • Werkt het apparaat wel als je Windows gebruikt?
  • Wat geeft syslog voor info als je het apparaat inplugt en een kaartje erin steekt?
  • Heb je ook andere USB poorten gebruikt? Dus front-USB en achterop de PC. En indien via hub: ook direct in de PC. Ik heb laatst een kaartlezer gehad die weigert via de USB bus te werken waarop de front-USB poorten van mijn pc zitten. Syslog geeft heel scary kernel hickups als ik hem daarop aansluit...
  • Heb je ook andere kaartjes geprobeerd in de kaartlezer?
  • Heb je ook een andere USB kabel geprobeerd?
  • Werkt hij misschien wel in USB Full Speed of USB1 mode? (dus High speed uit 'sudo modprobe -r <usb2module-weet-even-de-naam-niet-meer>')
  • Hoe probeer je te mounten? Via de GUI als user (FUSE) of op de command line met 'mount'?
[ Voor 10% gewijzigd door gertvdijk op 11-07-2009 02:27 ]
Kia e-Niro 2021 64kWh DynamicPlusLine. 3x Victron MP-II op 15kWh US5000 3f thuisbatterij met 3x25A→3x40A PowerAssist, Victron EVCS, 3200Wp HoyMiles zp. my GitHub, my blog
  • rob12424
Ik heb idd op vendor id enz. gegoogled en kwam er daar ook niet bepaald uit. (vaak komen dingen overeen en is het toch wat later anders) Uhm of het in windows werkt?
Mijn ouders werken met windows maar daar zit ook een fout in waardoor geen 1 usb apparaat meer werkt (in linux werkt alles gewoon)
Ik heb geen usb-kabel kan ook niet bij dat ding (het is echt een stick)
Ik probeer via de gui te mounten, fuse ging bij mij op mijn andere laptop fout waardoor hij alle partities van externe hd in raid gooide en de dbus-error elke keer bezig was waardoor een partitie niet kon openen maar dat lag deels ook aan lvm waarschijnlijk)
Maar heb andere kaartjes geprobeerd en die pakt hij dus wel (al kies ik wel generic in grub en niet server nu)
2gb inplaats van een 8gb micro sd in een microsd adapter (hij zegt nu lade is leeg) En bij 2 gig liet hij hem wel zien dus ik denk dat hij die micro sd adapter niet ziet.
Ik ga bij mij buren even op windows proberen om te kijken of het aan de adapter ligt.
Ik denk in iedergeval dat dit topic dicht kan? Of is dat iets te enthousiast? En als hij dicht kan hoe doe je dat?
