[Exchange 2007] automatisch forwarden naar een extern adres
  • wicked1980
  • Laatst online: 06-05 14:23
Ik wil 1 van mijn gebruikers accounts automatisch laten forwarden naar een Gmail adres.
Heb na het nodige Google werk behoorlijk wat hits gekregen, die allemaal hetzelfde vertellen, hieronder de kortste methode:
I had this situation the other day where a client needed to have their email forwarded from their Exchagne 2007 Mailbox to their newly created GMAIL Account. They will be using the GMAIL account as their primary email account for easier collaboration because they work in 2 different enterprises. In the Exchange 2007 environment POP3 or IMAP are not enabled therefore he couldn’t set up GMAIL to fetch his mail that way.
So to make this work I created a New Mail Contact on the Exchange 2007 Mailstore:
Open up the Exchange Management Console > Click on the Recipient Configuration Node. Then from the Actions Pane on the Right click on “New Mail Contact”. Select New Contact and click next, Choose the Organizational Unit for the contact and fill out the appropriate fields. Then in the External Email Address box click Edit and enter in the SMTP Address of the external email address, click Next and then Finish.
Now you have a new mail contact set up we can then forward the mail from the Exchange 2007 Mailbox to that mail contact.
From the Exchange Management Console go to the Recipient Configuration > Malbox Node and find the mail box for which you would like the mail forwarded from, right click and select properties. Under the Mail Flow Settings Tab select Delivery Options and then Properties.
Place a tick in the “Forward To” Box and then click Browse. Find the Mail Contact that you just created and click OK. There is anopther option that you can enable and that is to Deliver message to both forwarding address and mailbox. Put a tick in there if you would like to enable that.
Ongelooflijk simpel dus eigenlijk, zou je denken.
Ik heb de instellingen exact overgenomen (nog legio andere google hits die exact dezelfde wijze hanteren), en toch werkt het niet. De mail komt nog wel in de originele mailbox terecht (zoals ingesteld) maar de forward komt niet aan op de Gmail account.
Enig idee of ik iets over het hoofd zie?
  • MADG0BLIN
  • Laatst online: 21:04
Hij komt niet toevallig in een spamfilter terecht ofzo of een bounce? Hier werkt bovenstaande optie ook perfect namelijk.
  • Question Mark
  • Laatst online: 15:46
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Een nieuw handmatig verstuurd mailbericht wat je naar de aangemaakte contact stuurt komt wel binnen?
  • Willy-Jan Prijs
  • Laatst online: 27-02 20:46
ga naar active directory users and computers.
open de user container of maak een eigen container aan.
rechtermuis, kies nieuw, kies contact.
Vul de gegevens in kik op next.
Laat een exchange mailbox aanmaken en klik modify bij mailbox en kies voor smtp address.
vul het extern email adres in.
vervolgens rechtermuis op de gebruiker welke zijn/haar mail wil laten forwarden en kies eigenschappen.
tabblad exchange general en kies delivery options.
klik aan forward to en kies je net aangemaakte contact.
vink aan deliver messages to both forwarding address and mailbox.
Zo doe ik het op een win2k3 SBS server met exchange 2003 SP2 en werkt erg goed moet ik zeggen.
zowel interne email als externe mail wordt netjes doorgestuurd.
  • FireDrunk
  • Laatst online: 15:48
Willy-Jan Prijs schreef op vrijdag 26 juni 2009 @ 13:59:
Agrees dat het zo moet werken
Even niets...
  • wicked1980
Dit is in principe hetzelfde als beschreven, via een iets andere route.
ik zal het nog eens met een ander adres proberen
  • wicked1980
Question Mark schreef op vrijdag 26 juni 2009 @ 13:58:
Das een goeie! Dat had ik nog niet geprobeerd, maar dat werkt dus wel!
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Mooi, dan weet je in ieder geval al dat het contact goed is aangemaakt :)
Open je Exchange Management Console eens en start het "message tracking center" eens (te vinden in de toolbox) en probeer de mails die verzonden zijn naar je contact eens terug te vinden. Vindt je ze hierin terug, en blijkt uit deze logging dat deze mails verzonden zijn, dan zit het probleem niet aan jouw kant. Jouw mailserver verstuurd de mailtjes dan keurig naar GMail.
  • wicked1980
Anders adres geprobeerd en nu werkt het....
