LOGOUT User logged out on TELNET
  • Mathieuh
  • Laatst online: 18-01 10:26
Hallo allemaal,
Ik keek net in de gebeurtenis logboeken van mijn experiabox (thomson 780, de grijs/blauwe experiabox dus) en daar staat:
Info Jun 13 17:56:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:55:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:55:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:54:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:54:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:53:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:53:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:52:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:52:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:51:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:51:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:50:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:50:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:49:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:49:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:48:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:48:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:47:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:47:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:46:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:46:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:45:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:45:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:44:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:44:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:43:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:43:18 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:42:48 LOGOUT User logged out on TELNET (192.168.1.80)
Info Jun 13 17:42:18 LOGOUT User logged out on TELNET (192.168.1.80)
192.168.1.80 is de computer die het vaakste aan staat, het probleem is dat ik dus helemaal niets aan het doen ben met TELNET, het gaat al de hele tijd door en ik denk dat het dus al veel langer bezig is, ik heb namelijk voor het laatst ongeveer 3 maanden geleden gekeken in de gebeurtenislogboeken.
Op de computer (192.168.1.80 staat wel het programma The Dude, maar dat krijg ik niet verwijderd, de uninstall ding blijft gewoon uren en uren hangen zonder dat er maar enige vooruitgang is)
Ik denk niet dat het goed is voor de router dat er iedere 30 seconden iets gebeurd. Weet iemand wat ik hieraan kan doen?? Googlen heeft ook niets opgeleverd, alleen maar resultaten voor andere speedtouches en forum posts zonder antwoorden.
alvast bedankt,
Mathieu
  • Chillosophy
  • Laatst online: 16-10 07:20
Ik denk niet dat het zin heeft om te zoeken naar router-specifieke problemen, je kan beter uitzoeken waarom je "The Dude" niet kan verwijderen. Als ik de beschrijving van dat programma lees zorgt dat inderdaad voor de problemen.
  • Mathieuh
zo een vermoeden had ik al, het programma zorgt denk ik ook voor meerdere problemen op de computer. zo kan ik pas 10 minuten na het opstarten van de computer iets met het netwerk doen, wel internetten. heel raar.
Ik ga daar eventjes naar zoeken ;) bedankt voor de hulp alvast
  • Mathieuh
de afgelopen 3 minuten geen enkele keer meer gehad. ik heb even uitgezocht hoe ik the dude moest verwijderen, ik moest eerst de lokale server stoppen, daar had ik eerder overheen gelezen. Ik kijk zometeen weer in de logboeken maar denk niet dat het nog zal voorkomen. het enige wat er nu nog gebeurd zijn de upnp acties van mijn NAS (Lacie 1TB home edition nas)
