NZBIndex: Nieuwe Policy.
  • ApexAlpha
  • Laatst online: 23-10 14:47
Hey,
blijkbaar maakt brein waar wat ze zeggen, want ik kwam net op NZBIndex en moest Akkoord gaan met hetvolgende:
All information within our database is indexed by an automated process, without any human intervention. It is obtained from global Usenet newsgroups over which NZBIndex has no control. We cannot prevent that you might find obscene or objectionable material by using this service. If you do come across obscene, incorrect or objectionable results, let us know by following these steps and these results will be removed.
Do note that we merely index the information found on Usenet and are unable to manually screen all information. NOTE: When a search result contains a "collection" it means that a group of files with similar names was posted by the same poster in the same newsgroup. We do not group or filter files manually. Therefore it may occur that the system mistakenly combines files with different content.
You may use this site only for your own personal use. Commercial use, in any shape or form, is strictly prohibited.
Verder werd dit naar voren gebracht:
http://www.nzbindex.nl/forum/viewtopic.php?f=18&t=161
Een 'Notice & Take Down' knop voor NZB's. Om illegale content te raporteren dus :O
Heb ik gewoon het nieuws gemist of is dit nieuw?
Blijkbaar dekt nzbindex zich ook in, net als FTd...
