[SBS2008] Netwerkconnectiviteit gaat volledig plat
Beste tweakers,
Ik heb een vreemd probleem met mijn SBS2008. Na het booten van het systeem is in eerste instantie niets verkeerd, echter na één à twee weken zonder enige problemen te werken gaat ongeveer elke service die netwerkconnectiviteit heeft op z'n gat. Dit gebeurde al twee keer 's nachts en gisteren overdag. Gisteren gebeurde het om 16:30. Ik post even de events in chronologische volgorde:
Log Name: Application
Source: MSExchange ADAccess
Event ID 2114
Level: Error
User: N/A
Logged 27/05/2009 16:30:10
Task Category: Topology
Keywords: Classic
Process STORE.EXE (PID=2568). Topology discovery failed, error 0x80040a02 (DSC_E_NO_SUITABLE_CDC). Look up the Lightweight Directory Access Protocol (LDAP) error code specified in the event description. To do this, use Microsoft Knowledge Base article 218185, "Microsoft LDAP Error Codes." Use the information in that article to learn more about the cause and resolution to this error. Use the Ping or PathPing command-line tools to test network connectivity to local domain controllers.
Log Name: System
Source: GroupPolicy
Event ID 1030
Level: Error
User: SYSTEM
Logged 27/05/2009 16:30:11
Task Category: None
Keywords:
The processing of Group Policy failed. Windows attempted to retrieve new Group Policy settings for this user or computer. Look in the details tab for error code and description. Windows will automatically retry this operation at the next refresh cycle. Computers joined to the domain must have proper name resolution and network connectivity to a domain controller for discovery of new Group Policy objects and settings. An event will be logged when Group Policy is successful.
Event ID 2102
Level: Error
User: N/A
Logged 27/05/2009 16:30:23
Keywords: Classic
Process MAD.EXE (PID=2692). All Domain Controller Servers in use are not responding:
SBS01.domain.local
de volgende staat er dan 7 keer in:
Log Name: System
Source: DistributedCOM
Event ID 10009
Level: Error
User: N/A
Logged 27/05/2009 16:34:58
Task Category: None
Keywords: Classic
DCOM was unable to communicate with the computer DGMRQG3J.domain.local using any of the configured protocols.
Log Name: System
Source: Grouppolicy
Event ID 1054
Level: Error
User: SYSTEM
Logged 27/05/2009 16:35:15
Task Category: None
Keywords:
The processing of Group Policy failed. Windows could not obtain the name of a domain controller. This could be caused by a name resolution failure. Verify your Domain Name Sysytem (DNS) is configured and working correctly.
Vervolgens deze twee maal:
Source: Windows SharePoint Services 3 Search
Event ID 2424
Level: Error
User: N/A
Logged 27/05/2009 16:35:23
Task Category: Gatherer
Keywords: Classic
The update cannot be started because the content sources cannot be accessed. Fix the errors and try the update again.
Context: Application 'Search', Catalog 'index file on the search server Search'
Verdere fouten zijn exchange die geen mails kan afleveren en de bovenstaande fouten die periodiek terugkeren.
Ik vermoed dat niemand mij verder zal kunnen helpen met de oorzaak, maar als iemand zoiets al ooit heeft gezien, misschien dat die mij kan zeggen in welke richting ik moet zoeken? Door de zondvloed aan events weet ik op den duur niet goed meer welke richting ik uit moet kijken, en waar de oorzaak te gaan zoeken.
Volgende acties heb ik ondernomen:
- Herstart van deze services: Active Directory Domain Services en DNS server. Deze brachten me niet verder.
- Volledige herstart van de server: Beestje werkt weer zonder problemen. Tot de volgende keer dat hij weer gaat gek doen...
  • bassie91
  • Laatst online: 22-01 22:27
Wat voor antivirus draai je op die server?
trend micro worry-free business security
  • MrDirect
  • Laatst online: 17-10 16:50
Nee nog niet, bedankt, ik neem deze even door!
Okay, het artikel in kwestie is niet van toepassing op mijn server (NIC is een HP NC373i). Om jullie niet nodeloos jullie tijd te laten verspillen heb ik even de specs van de server uit de offerte gepaste, na de levering heb ik nog 4 GB ram laten toevoegen:
HP ML350T05 Xeon 54101P 2GB 2x72GB
HP 2GB FBD PC2-5300 2x1GB Kit
HP HDD/146GB 15K SAS 3.5 ALL
HP Integrated Lights Out Adv Pk/EN CrPf
HP RPS 350/370/380 G5 Kit
HP TV Ultrium 448 SAS Bundle
HP Data Cart/400GB LTO Ultrium
SYMC BACKUP EXEC SBS STANDARD EDITION 12.5 - Lic + Maint
Worry-Free Business Security Advanced Bundle: English
UPS/Evolution 1550
GFI Mailessentials 1st year with support and anti-phishing module
OEM/WinSBS Std 2008/EN 5u
In ieder geval, de BITS klinkt wel als een mogelijke schuldige...
Alvast al bedankt aan zij die meedenken :)
[ Voor 7% gewijzigd door Verwijderd op 28-05-2009 11:58 ]
  • MrDirect
Hey Vatt, sorry voor m'n late antwoord, moest gisterenmiddag op verplaatsing.
Mijn server is momenteel live, en ik kan de server in kwestie niet offline halen. Ik ben er dus niet zo heel gerust op deze fix te installeren op dit systeem.
Hoeveel risico loop ik op net nog meer problemen te veroorzaken indien het toch niet de juiste fix is? :/
  • ralpje
  • Laatst online: 16-10 17:39
ralpje
Deugpopje
Schopje :)
Was dit uiteindelijk de fix? Ik heb een klant met een SBS2008 doos en Trend Micro, en die heeft dezelfde problemen.
Freelance (Microsoft) Cloud Consultant & Microsoft Certified Trainer
  • vinniel83
  • Laatst online: 18-01-2024
Heb deze problemen meerdere keren meegemaakt met Trend Micro Worry Free Business Security Advanced 5.x, versie 6.x lijkt deze problemen niet te hebben.
Gebruikers konden na een x aantal dagen / weken niet meer aanmelden, printen, mailen e.d., zie ook: http://blogs.technet.com/...r-which-utilizes-tdi.aspx .
Deze fix verhielp toen wel het probleem overigens: http://support.microsoft....aspx?scid=kb;EN-US;961775
[ Voor 13% gewijzigd door vinniel83 op 06-01-2010 19:50 ]
