[PHP] Uploaden met Safe Mode aan
Ik werk aan een klein maar simpel upload script. het ziet er zo uit:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
require_once('ini_config.php');
function uploadfile($file, $name='', $path='', $maxsize='', $extensions='', $mimetypes='') {
    global $upload_defaultpath, $upload_defaultmaxsize, $upload_defaultextensions, $upload_defaultmimetypes;
    if($name=='')
    $name=$_FILES[$file]['name'];
    if($path=='')
    $path=$upload_defaultpath;
    if($maxsize=='')
    $maxsize=$upload_defaultmaxsize;
    if($extensions=='')
    $extensions=$upload_defaultextensions;
    if($mimetypes=='')
    $mimetypes=$upload_defaultmimetypes;
    if(!is_array($extensions))
    $extensions=array($extensions);
    if(!is_array($mimetypes))
    $mimetypes=array($mimetypes);
    if(is_uploaded_file($_FILES[$file]['tmp_name'])) {
        $pathinfo=pathinfo($_FILES[$file]['name']);
        $fileext=strtoupper($pathinfo['extension']);
        $filesize=$_FILES[$file]['size'];
        if(in_array($fileext, $extensions) AND in_array($_FILES[$file]['type'], $mimetypes) AND $filesize<$maxsize) {
            $target="$path/$name";
            if(move_uploaded_file($_FILES[$file]['tmp_name'], $target))
            return $target;
            else
            return false;
        else
        return false;
    else
    return false;
Alleen nu krijg ik de hele tijd de melding
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to access http://cybercat.thomasberends.nl/user_files/uploads/Green Apple.gif in /home/s08043/domains/thomasberends.nl/public_html/cybercat/func_uploadfile.php on line 37
De functie wordt aangeroepen door het volgende:
<?php
require_once('func_uploadfile.php');
$upload=uploadfile('file');
var_dump($upload);
<form method="POST" enctype="multipart/form-data" action="?page=portfolio">
    <input type="file" name="file" /> <input type="submit" />
</form>
ini_config bevat het volgende:
PHP:
//Upload configuration
$upload_defaultpath="$site_root/user_files/uploads";
//$upload_defaultmaxsize=2097152;
$upload_defaultmaxsize=500000;
$upload_defaultextensions=array('GIF','JPEG','JPG','PNG');
$upload_defaultmimetypes=array('image/gif','image/jpeg','image/png','image/x-png');
(upload heeft chmod 777)
Nu heb ik het idee dat dit komt doordat SAFE MODE aanstaat op mijn test host. Maar het lijkt mij niet onwaarschijnlijk dat dit script (wat vaker gebruikt gaat worden) ook op een SAFE MODE host neerkomt. Dus is er een manier om, om safe mode heen te werken en toch te kunnen uploaden met SAFE MODE aan?
  • Manuel
  • Laatst online: 30-10 15:37
Als ik de foutmelding zie heeft het niet veel met de safe-mode te maken heeft maar eerder met het pad dat jij opgeeft. Probeer eens dit:
PHP:
$upload_defaultpath="/home/s08043/domains/thomasberends.nl/public_html/user_files/uploads";
Volgens mij heeft <input type="submit" /> nog altijd een value attribuut nodig om het volgens HTML4 / XHTML compatible te maken :")
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Manueltje22 schreef op maandag 25 mei 2009 @ 17:54:
Misschien is 't wel gewoon test-code die hij post en beperkt hij zich, zoals gewenst hier, tot relevante code ;)
Je eigen tweaker.me redirect
Over mij
  • Patriot
  • Laatst online: 30-10 16:37
Patriot
Fulltime #whatpulsert
Nee hoor
value = cdata [CA]
This attribute specifies the initial value of the control. It is optional except when the type attribute has the value "radio" or "checkbox".
  • Manuel
RobIII schreef op maandag 25 mei 2009 @ 17:57:
Daarom gebruikte ik ook offtopic tags ;)
Maar even @Tuxedo-Devito, probeer eens een absolute pad, kijken of die dan werkt.
@Manueltje22
Dank je, dat werkt wel:)
