[Ervaringen] Option GTM378 Mini PCIe Module
  • CLB
Naar aanleiding van: CLB in "Zepto Znote 6224W / 6324W / 6625WD - Deel 6"
lijkt het me leuk om dat slot op te vullen met iets wat handig, gaaf, trendy en relaxed is...
Zodoende kwam ik via DaMarcus bij de Option GTM378E:
Afbeeldingslocatie: http://www.zdnet.de/i/mb/tk/2008/02/edge_05-ig.jpg
The GTM378 is the second generation of PCI Express MiniCard module designed by Option
to be compatible with mobile operator infrastructure equipment capable of supporting HSDPA data rates of up to 7.2 Mbps.
The GTM378 is the right solution for embedding HSDPA, 3G and EDGE connectivity technology into laptops and PDA devices.
The GTM378 includes Advanced Receiver Technology (ART) bringing the benefit of Receive Diversity and Receive Equalization. Both are essential for maximizing the benefit of HSDPA 7.2. Initially supplied with HSDPA 3.6, the GTM378 is field upgradeable when the network is configured for HSDPA 7.2.
Backward compatibility ensures HSDPA connections at lower data rates of 3.6 Mbps and 1.8 Mbps. The GTM378 has inherent support for 3G operation at 384 Kbps in conjunction with quad-band EDGE and GPRS. Even more use cases become possible with the GPS and voice capabilities of this module.
Features:
  • Global connectivity with triple-band 3G and quad-band 2G
  • A-GPS / S-GPS Positioning
  • CS Voice support
  • Advanced Receiver Technology incorporating Receiver Diversity and Equalization
  • High-speed data with HSDPA and UMTS (up to 7.2 Mbps downlink and 384 Kbps uplink)
    and backward compatible with EDGE / GPRS / GSM data connectivity (up to 247 Kbps)
  • Transparent hand-over between UMTS and GSM / EDGE networks
  • Low power dissipation for easy embedding into devices
  • Benefits from large Option experience in PC datacards
  • Easy integration made possible thanks to:
    -Testing on infrastructures and networks worldwide
    -Flexible driver design providing both NDIS and modem modes for easy integration into dashboard applications
    -Future proofing through Flash Memory technology
    -Connectors for external antennas
    -GPS & Voice may require additional software from manufacturer, third party source or developer kit.
    -GT Connect Software Included as a Free Download for 3G HSDPA UMTS EDGE GPRS Internet Surfing.
Nu is mijn vraag.. Zijn er mensen die ervaringen hebben met deze module en zoja hoe bevalt het?
Ikzelf heb een Vodafone abbo dus ik zou 'n 2e simkaart aan kunnen vragen.. Zal die gelijk werken en m'n mobiel blijft dan ook 'online' of moet ik telkens switchen wat voor mij not done is. Anders een prepaid simkaartje kopen voor in de laptop, daar internetblox op activeren en gaan met die banaan? Ik hoor 't graag van jullie... :)
  • CLB
Iemand?
  • Schapie
  • Laatst online: 19-02-2025
Schapie
Bleh...
Ik heb geen ervaring met deze module, maar kan je wel vertellen dat indien je een duo simkaart gebruikt je er maar eentje tegelijk kan gebruiken. Je moet dus altijd je toestel offline/uit zetten en vice versa als je het andere apparaat gebruikt.
Deze module ziet er verder wel interessant uit, is deze voor zover bekend ook makkelijk in Nederland verkrijgbaar en is er een prijs van bekend?
No signature found
  • CLB
Hmm dat van 1 simkaart dacht ik al dus dat moet worden opgevangen met een prepaid simkaartje.. Module in Nederland heb ik nog niet gezien, maar ik koop zulke muk altijd op eBay en daar kost deze module slechts een kleine 50,-
  • CLB
Geen reacties / ervaringen meer?
  • CLB
Iemand?
  • alex3305
  • Laatst online: 09-11 14:09
Helaas geen ervaring mee, echter zag ik wel op de Option site dat er wel nieuwere modellen in omloop zijn. Misschien dat je daar reviews oid over kunt vinden.
Let trouwens wel even op dat je geen CDMA versie uitkiest heh :9
  • llevering
  • Laatst online: 12:34
Het kaartje zal ook nog een antenne nodig hebben vrees ik en die is achteraf wat moeilijk in te bouwen. Anders erg interessant!
  • Barbapapa852
  • Laatst online: 18:34
ziet er wel leuk uit en zijn op Ebay wel voor leuke prijsjes te vinden ben alleen wel benieuwd of deze werken in een dell XPS M1330 iemand hier ervaring mee ?
  • XanderDrake
  • Laatst online: 18:40
XanderDrake
Build the future!
Ik snap helemaal waarom deze wilt hebben CLB. Ik vind dat er maar weinig echte interne 3.5G oplossingen zijn voor laptops.
Ik zit alleen met het volgende, heb je hier niet een interne antenne nodig, zoals bij Wifi?
Hephaestus: Xeon 2680 v2 - 64GB ECC Quad - WD Blue 3D 1TB
Virtualis: Ryzen 3700X - 16GB DDR4 - Gigabyte 1080 Ti OC - Sandisk 2TB - Valve Index
Agon:Valve Steam Deck 64GB
Non scholae sed vitae discimus Seneca
  • CLB
Neem aan dat dat erin zit? Heb er niet bijster veel verstand van, zodoende dit topicje!
  • Barbapapa852
XanderDrake schreef op donderdag 03 september 2009 @ 21:33:
als je de aansluiting in je laptop heb zitten (Zoals ik heb met mijn M1330) daar liggen 3 draadjes los waarvan er waarschijnlijk 2 voor de wwan zijn. als je geen antennes heb worden er bij sommige aanbieders op E-bay antennes meegeleverd, deze zou je toch mogelijk wel weg kunnen/moeten werken in je laptop
  • Sabbi
  • Laatst online: 18:57
Sabbi
je denkt aan mij.
Ik heb net een option gtm380 besteld, (ook ebay) waar een interne antenne bij meegeleverd wordt. Voor 46 euro vond ik het leuk genoeg om te proberen of het iets is.
denk alleen wel dat het makkelijker is als je netbook/laptop er al op voorbereid is, deze kaartjes hebben namelijk geen sim-slot op de kaart. De interne antenne ergens kwijtraken zal niet zo moeilijk zijn maar een sim-houder wordt lastiger maken. (Gelukkig is de mijn toekomstige t1028x voorbereid)
Wel leuk is dat deze kaartjes ook agps/gps hebben, maar eens kijken of dat een beetje werkt. Voice mogelijkheiden lijken me helemaal geniaal ("ik heb een 10 inch touchscreen op mijn telefoon")
over hoe de gps aangaat
http://www.onlinekosten.de/forum/showthread.php?p=1796542
  • XanderDrake
XanderDrake
Build the future!
De HP DV2 zou klaar moeten zijn voor een kaartje zoals dit.
Ik vond op internet, dat die laptop helemaal klaar was voor 3G (inclusief SIMcard slot), behalve dat in bijna alle SKU's niet voorzien zijn van een 3G module.
Dat jullie het weten :)
  • XanderDrake
XanderDrake
Build the future!
Sabbi schreef op zondag 06 september 2009 @ 12:56:
En, heb je em al kunnen uitproberen?
  • Sabbi
Sabbi
je denkt aan mij.
De gtm380 is binnen, maar de netbook is er nog niet (wordt pas weer geleverd na 23 okt ivm windows 7).
  • DarkChylde
  • Laatst online: 14-11 10:36
Sabbi schreef op zaterdag 03 oktober 2009 @ 15:12:
En heb je de combi al uit kunnen proberen?
  • XanderDrake
XanderDrake
Build the future!
Ik heb ondertussen een 3G usb stick gehaald. Werkt ook prima ;)
En geen issues zoals garantie-voiding.
  • CLB
Helaas wel extern...
  • XanderDrake
XanderDrake
Build the future!
Het in en uit pluggen van een usb stick is nooit moeilijk geweest ;)
Maar je hebt gelijk, intern is eleganter.
  • CLB
En nog mensen met ervaringen... wel leuk zo'n GPS module en dergelijke natuurlijk.
Maar heden ten dage heb je ook SSD's voor in deze sloten, wat me ook wel leuk lijkt als bootschijf..
  • dion_b
  • Laatst online: 18:01
dion_b
say Baah
Op zich niet gek dat je weinig ervaringen krijgt in het verkeerde subforum :o
Jij loopt hier echt lang genoeg rond om te weten dat zaken mbt netwerken niet in OH thuishoort (zo niet: check OH beleid eens...)
Move OH -> NT
Oslik, blyat! Oslik!
  • CLB
Nou nou nou, een 3G / HSDPA / GPS module in netwerken plaatsen bedenk ik niet 1,2,3... tevens is dat 'n jaar geleden! Dank!
