trackmania dedicated server runnen lukt niet
Ik probeer nu een server te runnen voor trackmania alles doet het goed en de server is in trackmania ook zichtbaar maar niemand kan inloggen. Ik heb alle poorten al goed open gezet
dit komt er te staan als ik de server run
[2009/04/28 15:53:08] Initializing...
[2009/04/28 15:53:09] Configuration file : dedicated_cfg.txt
[2009/04/28 15:53:09] Loading system configuration...
[2009/04/28 15:53:10] ...system configuration loaded
[2009/04/28 15:53:12] Loading cache...
[2009/04/28 15:53:12] ...OK
[2009/04/28 15:53:12] Listening for xml-rpc commands on port 5000.
[2009/04/28 15:53:12] Loading dedicated server configuration...
[2009/04/28 15:53:12] ...Dedicated server configuration loaded
[2009/04/28 15:53:12] Match settings file : MatchSettings\Nations\NationsGreen.txt
[2009/04/28 15:53:12] Loading match settings...
[2009/04/28 15:53:16] ...Match settings loaded
[2009/04/28 15:53:16] Autostart server on internet
[2009/04/28 15:53:17] Connecting to master server...
[2009/04/28 15:53:22] ...OK
[2009/04/28 15:53:22] Identifying on master server...
[2009/04/28 15:53:22] URL: tmtp://#join=jon0485
[2009/04/28 15:53:22] Please wait, loading...
[2009/04/28 15:53:22] Starting server...
[2009/04/28 15:53:22] - Warning! -
You seem to be on a private network.
Unless you've configured your NAT, the
other players on internet will not be
able to join in...
[2009/04/28 15:53:22] Loading challenge B01-Race.Challenge.Gbx (8oDWqaNMXpyFg6e_QUb07Wzpkk3)...
[2009/04/28 15:53:23] ...Load succeeds
[2009/04/28 15:53:24] Starting Match...
[2009/04/28 15:53:24] ...Synchronization
[2009/04/28 15:53:28] ...Play
Dit staat in het cedicated_cfg tekst bestand.
<?xml version="1.0" encoding="utf-8" ?>
<dedicated>
<authorization_levels>
<level>
<name>SuperAdmin</name>
<password>SuperAdmin</password>
</level>
<level>
<name>Admin</name>
<password>Admin</password>
</level>
<level>
<name>User</name>
<password>User</password>
</level>
</authorization_levels>
<masterserver_account>
<login>jon0485</login>
<password>0485384586</password>
<validation_key>NL</validation_key>
</masterserver_account>
<server_options>
<name>UTD</name>
<comment>UTD</comment>
<hide_server>0</hide_server> <!-- value is 0 (always shown), 1 (always hidden), 2 (hidden from nations) -->
<max_players>20</max_players>
<password></password>
<max_spectators>10</max_spectators>
<password_spectator></password_spectator>
<ladder_mode>forced</ladder_mode> <!-- value between 'inactive', 'forced' (or '0', '1') -->
<ladder_serverlimit_min>0</ladder_serverlimit_min> <!-- Those values will be clamped to the limits authorized on http://official.trackmania.com/tmf-ladderserver/ -->
<ladder_serverlimit_max>50000</ladder_serverlimit_max>
<enable_p2p_upload>True</enable_p2p_upload>
<enable_p2p_download>True</enable_p2p_download>
<callvote_timeout>60000</callvote_timeout>
<callvote_ratio>0.5</callvote_ratio> <!-- default ratio. value in [0..1], or -1 to forbid. -->
<callvote_ratios>
<voteratio command="Ban" ratio="0.65"/>
<!-- commands can be "Ban", "Kick", "ChallengeRestart", "NextChallenge", ... -->
</callvote_ratios>
<allow_challenge_download>True</allow_challenge_download>
<autosave_replays>False</autosave_replays>
<autosave_validation_replays>False</autosave_validation_replays>
<referee_password></referee_password>
<referee_validation_mode>0</referee_validation_mode> <!-- value is 0 (only validate top3 players), 1 (validate all players) -->
<use_changing_validation_seed>False</use_changing_validation_seed>
</server_options>
<system_config>
<connection_uploadrate>512</connection_uploadrate> <!-- Kbps (kilo bits per second) -->
<connection_downloadrate>8192</connection_downloadrate> <!-- Kbps -->
<force_ip_address></force_ip_address>
<server_port>2350</server_port>
<server_p2p_port>3450</server_p2p_port>
<client_port>0</client_port>
<bind_ip_address></bind_ip_address>
<use_nat_upnp></use_nat_upnp>
<p2p_cache_size>600</p2p_cache_size>
<xmlrpc_port>5000</xmlrpc_port>
<xmlrpc_allowremote>False</xmlrpc_allowremote> <!-- If you specify an ip adress here, it'll be the only accepted adress. this will improve security. -->
<blacklist_url></blacklist_url>
<guestlist_filename></guestlist_filename>
<blacklist_filename></blacklist_filename>
<packmask>stadium</packmask>
<allow_spectator_relays>False</allow_spectator_relays>
<use_proxy>False</use_proxy>
<proxy_login></proxy_login>
<proxy_password></proxy_password>
</system_config>
</dedicated>
ik hoop dat iemand mij hiermee kan helpen
