[ HarmanKardon MAS-100 ] info?
  • HerrJP
  • Laatst online: 03-10 01:09
Heeft iemand al meer info over dit mooie apparaat van hk? Ik zag hem staan op het HKdealer-event vorige week. Wat een geluid komt daar uit!
Gekke is alleen dat ik nog nergens info kan vinden, ook niet op de site van HK zelf.
Het gaat om dit setje:
Afbeeldingslocatie: http://img.bestsellers.eu/images/large/HKMAS100.jpg
enige webshop (bestsellers.eu) die hem aanbiedt heeft de volgende info:
2 x 65W Stereo music system
The Harman Kardon® MAS100 has it all. This advanced stereo music system integrates a built-in amplifi er, a radio tuner and an alarm clock, along with CD, MP3 and WMA playback, all on board, not to mention the included audiophile-quality bookshelf loudspeakers.
The MAS 100 system is also compatible with iPod when used with an optional Harman Kardon The Bridge II dock. USB inputs, phono input and auxiliary inputs for other audio products complete the package, making the MAS 100 the ultimate companion for 21st-century music lovers.
Highlights
• Integrated system that includes an amplifier, a CD player and loudspeakers
• Ready for iPod (iPod not included)
• USB 2.0 Host
• MP3 and WMA playback
• Digital inputs and outputs
• Alarm clock
• Phono input MM
• Digital Signal Processing
• Flat baffl e design
• Waveguide tweeter
• Heavy-duty binding posts
• Capacitive touch control
• 192kHz/24-Bit DACs
• Black-lacquer finish
Key Specifications
• Audio section – Continuous Average Power (FTC), (stereo mode): 65 watts per channel into 6 ohms @ 20Hz – 20kHz, <0.1% THD
• Frequency response – “A”-Weighted S/N Ratio: >98dB; THD: 0.0025%; Dynamic Range (CD): 100dB; Channel Separation: >90dB; Tuner – Usable Sensitivity: IHF 1.3μV/13.2dBf; THD at 1kHz with 100% modulation, (mono): 0.15%; (stereo): 0.3%; FM Adjacent Channel Selectivity: ±400kHz, 70dB; Ultimate (maximum) S/N Ratio (measured at 1mV RF input level), (mono): 70dB; (stereo): 68dB
• Dimensions (H x W x D) and weight – Source: 80mm x 240mm x 240mm, 2.0kg; Amplifier: 80mm x 240mm x 240mm, 2.6kg; Loudspeakers: 270mm x 180mm x 185mm, 5kg
Weet iemand hier al meer van?
-o-o-0-o-o-
