Hey allen,
Ik heb een windows 2003 r2 ent SP2 server geinstalleerd, met daarom SQL Server 2005 met SP3.
De machine is vers en up-to-date.
Via de SQL studio management console probeert ik een database van een oude 2000 sql server naar de nieuwe SQL 2005 server te exporteren. Voor de meeste databases gaat dit goed, behalve voor onze intranet database. Bij het draaien van een export task krijg ik halverwege de migratie de volgende melding:
- Execute the transfer with the TransferProvider. (Error)
Messages
• ERROR : errorCode=-1071636471 description=SSIS Error Code DTS_E_OLEDBERROR. An OLE DB error has occurred. Error code: 0x80004005.
An OLE DB record is available. Source: "Microsoft SQL Native Client" Hresult: 0x80004005 Description: "Invalid length parameter passed to the substring function.".
helpFile=dtsmsg.rll helpContext=0 idofInterfaceWithError={8BDFE893-E9D8-4D23-9739-DA807BCDC2AC}
For help, click: http://go.microsoft.com/f...t+SQL+Server&LinkId=20476
• ERROR : errorCode=-1073450952 description=SSIS Error Code DTS_E_PRIMEOUTPUTFAILED. The PrimeOutput method on component "OLE DB Source" (1) returned error code 0xC0202009. The component returned a failure code when the pipeline engine called PrimeOutput(). The meaning of the failure code is defined by the component, but the error is fatal and the pipeline stopped executing. There may be error messages posted before this with more information about the failure.
• ERROR : errorCode=-1073450975 description=SSIS Error Code DTS_E_THREADFAILED. Thread "SourceThread0" has exited with error code 0xC0047038. There may be error messages posted before this with more information on why the thread has exited.
• ERROR : errorCode=-1073450951 description=SSIS Error Code DTS_E_THREADCANCELLED. Thread "WorkThread0" received a shutdown signal and is terminating. The user requested a shutdown, or an error in another thread is causing the pipeline to shutdown. There may be error messages posted before this with more information on why the thread was cancelled.
• ERROR : errorCode=-1073450975 description=SSIS Error Code DTS_E_THREADFAILED. Thread "WorkThread0" has exited with error code 0xC0047039. There may be error messages posted before this with more information on why the thread has exited.
helpFile=dtsmsg.rll helpContext=0 idofInterfaceWithError={8BDFE893-E9D8-4D23-9739-DA807BCDC2AC} (Microsoft.SqlServer.DtsTransferProvider)
Kan iemand me de juiste weg wijzen om dit probleem op te lossen?
Messages
