Routing probleem?
  • dôh
  • Laatst online: 02-10 16:18
Ik zit met de volgende setup;
Één PC (Windows Server 2003) met 2 NIC's, elke NIC zit op een apart LAN.
Dit is de routing tabel;
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
IPv4 Route Table
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 50 56 c0 00 08 ...... VMware Virtual Ethernet Adapter for VMnet8
0x3 ...00 50 56 c0 00 01 ...... VMware Virtual Ethernet Adapter for VMnet1
0x10006 ...00 1d 7d 0b 1f ac ...... Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit E
thernet NIC #2 - Virtual Machine Network Services Driver
0x30005 ...00 1d 7d 0b 1f ae ...... Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit E
thernet NIC - Virtual Machine Network Services Driver
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.0.1      192.168.0.2     20
          0.0.0.0          0.0.0.0     192.168.11.1    192.168.11.23      1
        127.0.0.0        255.0.0.0        127.0.0.1        127.0.0.1      1
      192.168.0.0    255.255.255.0      192.168.0.2      192.168.0.2     20
      192.168.0.2  255.255.255.255        127.0.0.1        127.0.0.1     20
    192.168.0.255  255.255.255.255      192.168.0.2      192.168.0.2     20
     192.168.11.0    255.255.255.0    192.168.11.23    192.168.11.23      1
    192.168.11.23  255.255.255.255        127.0.0.1        127.0.0.1      1
   192.168.11.125  255.255.255.255     192.168.11.1    192.168.11.23      1
   192.168.11.255  255.255.255.255    192.168.11.23    192.168.11.23      1
    192.168.164.0    255.255.255.0    192.168.164.1    192.168.164.1     20
    192.168.164.1  255.255.255.255        127.0.0.1        127.0.0.1     20
  192.168.164.255  255.255.255.255    192.168.164.1    192.168.164.1     20
    192.168.212.0    255.255.255.0    192.168.212.1    192.168.212.1     20
    192.168.212.1  255.255.255.255        127.0.0.1        127.0.0.1     20
  192.168.212.255  255.255.255.255    192.168.212.1    192.168.212.1     20
        224.0.0.0        240.0.0.0      192.168.0.2      192.168.0.2     20
        224.0.0.0        240.0.0.0    192.168.11.23    192.168.11.23      1
        224.0.0.0        240.0.0.0    192.168.164.1    192.168.164.1     20
        224.0.0.0        240.0.0.0    192.168.212.1    192.168.212.1     20
  255.255.255.255  255.255.255.255      192.168.0.2      192.168.0.2      1
  255.255.255.255  255.255.255.255    192.168.11.23    192.168.11.23      1
  255.255.255.255  255.255.255.255    192.168.164.1    192.168.164.1      1
  255.255.255.255  255.255.255.255    192.168.212.1    192.168.212.1      1
Default Gateway:      192.168.11.1
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
Het idee is dus dat de NIC met het IP adres 192.168.11.23 de primaire NIC is en dat ik daar het internet mee op ga e.d. Dat heb ik opgelost door de metric op 1 te zetten en die van de tweede NIC op 20. De tweede NIC is namelijk voor VMWare, deze heeft op deze manier zijn eigen internet verbinding.
Het probleem wat ik nu heb is het volgende;
In het 192.168.11.x netwerk heb ik een NAS, deze kon ik in het begin wel pingen, maar niet goed via SMB benaderen. Ik heb daarom de volgende route toegevoegd (zie ook de routing tabel);
route add -p 192.168.11.125 MASK 255.255
.255.255 192.168.11.1 METRIC 1 IF 0x10006
Nu kan ik de NAS via SMB, FTP e.d. bereiken, ik kan er van downloaden, maar ik kan er niet naar uploaden! Als ik via SMB een bestand naar de NAS sleep geeft windows mij de volgende foutmelding;
Cannot copy x: The specified network name is no longer available.
Mijn vraag is daarom de volgende; Wat doe ik fout? Kijk ik ergens overheen of vergeet ik wellicht iets, of kan hetgeen wat ik wil gewoon niet (lijkt me sterk). Kan iemand mij helpen met het oplossen van het probleem? :)
  • Master_duck
  • Laatst online: 16-10 07:59
probeer deze eens
.255.255 192.168.11.1 192.168.11.23 METRIC 1 IF 0x10006
je heb de interface ip vergeten mee te geven
  • Brahiewahiewa
  • Laatst online: 30-09-2022
Brahiewahiewa
boelkloedig
mr-duck, jou oplossing geeft gewoon: "bad argument"
Maar ook de oplossing van TS klopt niet: je stuurt namelijk pakketjes voor het 192.168.11.125 adres naar 192.168.11.1. Daar hoeft die router helemaal niks mee te doen, want je kunt 'm ook rechtstreeks bereiken.
Je moet denk ik proberen de oorspronkelijke SMB problemen op te lossen. Begin eens te vertellen wat die zijn.
QnJhaGlld2FoaWV3YQ==
  • ik222
Kun je de NAS wel pingen.
De NAS ligt namelijk gewoon in hetzelfde subnet, dus geen routeringsregel nodig.
  • Fish
Fish
How much is the fish
Wanneer het downloaden goed werkt lijkt me dat de je routing goed werkt,
persoonlijk, zou ik die nas eens nader bekijken of die niet loopt te bokken
Iperf
  • dôh
ik222 schreef op woensdag 15 april 2009 @ 21:53:
Pingen werkt gewoon naar behoren... Was dit vergeten te melden.
  • dôh
fish schreef op woensdag 15 april 2009 @ 22:06:
Vanaf een andere PC die in hetzelfde netwerk hangt als de NAS, maar niet in het tweede netwerkt, werkt alles prima!
  • Glashelder
Glashelder
Anti Android
Ervaar je misschien nog andere netwerkproblemen? Klinkt alsof er ergens pakketjes gedropped worden of corrupt raken. Probeer eens een andere kabel, update de drivers van je NIC of probeer een andere.
Het kan eventueel ook de moeite waard zijn om 'Large Send Offload' in de geavanceerde eigenschappen van je NIC uit te schakelen.
  • ik222
dôh schreef op donderdag 16 april 2009 @ 00:10:
Dus er is geen routing probleem, kan ook bijna niet aangezien je slechts 1 subnet gebruikt. Je hebt helemaal geen 2 verschillende subnetten.
Dus dan zal je het in ieder geval in andere dingen moeten zoeken.
  • dôh
Glashelder schreef op donderdag 16 april 2009 @ 00:55:
Andere problemen in het netwerk heb ik niet. Jouw suggestie heb ik geprobeerd, deze haalde helaas niks uit. Het uitzetten van Jumbo frames op de NAS heeft het probleem doen verhelpen. Ik snap dan nog niet waarom ik wel kon downloaden van de NAS maar niet kon uploaden. :?
  • Glashelder
Glashelder
Anti Android
Jumbo frames worden niet in hun orginele vorm gerouteerd. En aangezien de route naar je NAS via je router liep..
[ Voor 32% gewijzigd door Glashelder op 16-04-2009 21:43 ]
