Ga-kn8-sli
  • 211 views
Wie kan me helpen met het overclokken van dit bordje.
Alles draait op standaard.
Processor(s)
Number of processors 1
Number of cores 1 per processor
Number of threads 1 per processor
Name AMD Athlon 64 4000+
Code Name San Diego
Specification AMD Athlon(tm) 64 Processor 4000+
Package Socket 939
Family/Model/Stepping F.7.2
Extended Family/Model F.37
Brand ID 4
Core Stepping DH-E6
Technology 90 nm
Core Speed 2412.5 MHz
Multiplier x Bus speed 12.0 x 201.0 MHz
HT Link speed 1005.2 MHz
Stock frequency 2400 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache (per processor) 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache (per processor) 64 KBytes, 2-way set associative, 64-byte line size
L2 cache (per processor) 1024 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA nForce4 rev. A3
Southbridge NVIDIA nForce4 MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 201.0 MHz (CPU/12)
CAS# Latency (tCL) 3.0 clocks
RAS# to CAS# (tRCD) 3 clocks
RAS# Precharge (tRP) 3 clocks
Cycle Time (tRAS) 8 clocks
Bank Cycle Time (tRC) 11 clocks
DRAM Idle Timer 16 clocks
Command Rate (CR) 2T
System
System Manufacturer
System Name
System S/N
Mainboard Vendor Gigabyte Technology Co., Ltd.
Mainboard Model GA-K8N-SLi
BIOS Vendor Award Software International, Inc.
BIOS Version F10d
BIOS Date 10/22/2008
Memory SPD
Module 1 DDR, PC3200 (200 MHz), 1024 MBytes, Samsung
Module 2 DDR, PC3200 (200 MHz), 1024 MBytes, Samsung
Software
Windows Version Microsoft Windows XP x64 Professional Service Pack 2 (Build 3790)
DirectX Version 9.0c
  • DeeJee
  • Laatst online: 23-12-2024
DeeJee
Dus...
Money for nothin' and your chicks for free
Niemand die my kan vertellen welke setting ik omhoog moet gooien?
Ik ga je vertellen dat je de handleiding van je moederbord eens moet lezen. En dat je via onze search en via google heel veel informatie kunt vinden. Op dit forum verwachten we dat je zelf moeite doet en inzet toont. We zijn geen afhaalbalie.
  • Krentenbol
  • Laatst online: 02-10 15:11
Krentenbol
Prutz0r
Hij draait sowieso niet stock. De bus is 1MHz omhoog gedaan. Je HT multiplier moet omlaag.
How to autobeun: Like, comment en subscribe!
  • Twynn
  • Laatst online: 08-10 13:40
Lees gewoon even wat HlpDsK zegt. Dit soort dingen zijn met wat eigen inzet prima uit te vinden.
