[SBS 2003] Backup failed - Requested media failed to mount*
Hallo .
We hebben een probleempje met mijjn server sbs 2003 .
Elke keer als ik een backup wil maken dan mislukt die |:(
4/7/2009 11:00 PM
Date: 4/7/2009
Time: 11:00 PM
User: SYSTEM
Backup Runner started.
NTMS session started successfully.
EnumerateNtmsObject(NTMS_LIBRARY) succeeded.
Will enumerate on 4 media libraries found.
GetNtmsObjectInformation(NtmsLibraryInfo) succeeded.
Found an enabled library.
InventoryNtmsLibrary(NtmsInventoryOmid) succeeded.
Identify Media completed
EnumerateNtmsObject(NTMS_PHYSICAL_MEDIA) succeeded.
Will enumerate on 0 media types found.
Will enumerate on 1 media types found.
GetNtmsObjectInformation(NtmsPhysicalMediaInfo) succeeded.
GetNtmsObjectInformation(NtmsMediaTypeInfo) succeeded.
Found a tape media type in the library (4mm DDS).
Launching NTBackup: ntbackup.exe backup "@C:\Program Files\Microsoft Windows Small Business Server\Backup\Small Business Backup Script.bks" /d "SBS Backup created on 4/7/2009 at 11:00 PM" /v:yes /r:no /rs:no /hc:on /m normal /j "Small Business Server Backup Job" /l:s /p "4mm DDS" /UM
NTBACKUP LOG FILE: C:\Documents and Settings\SBS Backup User\Local Settings\Application Data\Microsoft\Windows NT\NTBackup\data\backup07.log
=====================<BEGIN NTBACKUP LOG FILE>=====================
Backup Status
Operation: Backup
Active backup destination: 4mm DDS
Media name: "Media created 4/7/2009 at 11:00 PM"
Volume shadow copy creation: Attempt 1.
Backup (via shadow copy) of "C: "
Backup set #1 on media #1
Backup description: "SBS Backup created on 4/7/2009 at 11:00 PM"
Backup Type: Normal
Backup started on 4/7/2009 at 11:04 PM.
Backup completed on 4/8/2009 at 12:02 AM.
Directories: 4640
Files: 108356
Bytes: 11,901,760,306
Time: 57 minutes and 46 seconds
Backup (via shadow copy) of "E: Logg"
Backup set #2 on media #1
Backup Type: Normal
Backup started on 4/8/2009 at 12:02 AM.
Backup completed on 4/8/2009 at 12:03 AM.
Directories: 4
Files: 58
Bytes: 284,187,705
Time: 1 minute and 13 seconds
Backup (via shadow copy) of "F: Data"
Backup set #3 on media #1
Backup Type: Normal
Backup started on 4/8/2009 at 12:03 AM.
Backup completed on 4/8/2009 at 1:56 AM.
Directories: 1889
Files: 32294
Bytes: 22,271,234,742
Time: 1 hour, 52 minutes, and 44 seconds
Backup of "CSDC\Microsoft Information Store\First Storage Group"
Backup set #4 on media #1
Backup Type: Normal
Backup started on 4/8/2009 at 1:56 AM.
The requested media failed to mount. The operation was aborted.
The operation was ended.
Backup completed on 4/8/2009 at 2:41 AM.
Directories: 0
Files: 1
Bytes: 8,762,947,364
Time: 45 minutes and 17 seconds
The operation did not successfully complete.
=======================<END NTBACKUP LOG FILE>=====================
NTBackup finished the backup with errors.
For more information about failed backups, see the article on troubleshooting your backup at the following Web page: http://go.microsoft.com/fwlink/?LinkId=18414
Backup ended at Wednesday, April 08, 2009 2:41 AM
Backup Runner finished.
Kan iemand mij hier mee helpen ?
Heb al gezocht op het net daar had ik gevonden dat de backup misshien te groot was maar dat is niet zo .
Waar backup je naartoe, DVD / BD ? Tape ?
  • mhoogendam
  • Laatst online: 11:35
Als je alle Bytes optelt kom je op 43,220,130,117 Dit is toch wel wat veel voor een DDS4 tape.
Het is vroeg, 4mm DDS voor DDS4 aangezien.
wat voor tape word het naar toe geschreven?
DAT72 is namelijk ook 4mm tape
De 40GB waar ze het over hebben op die tapes is compressed, dit zal niet altijd gehaald worden omdat sommige bestanden nu eenmaal niet goed compressen.
[ Voor 23% gewijzigd door mhoogendam op 08-04-2009 08:03 ]
Sorry het is Tape , DAT 72 , dus het zou kunnen zijn dat het er gewoon weg niet op past ?
  • Aikon
Hij is niet eens begonnen, of het wel of niet pas doet er niet toe.
Andere tape geprobeerd, werkt de tapedrive uberhaupt wel? Ander programma geprobeerd ook? Fabrikant al gebeld, of is het een oudje?
  • Oogje
Aikon schreef op woensdag 08 april 2009 @ 08:25:
Dr staat al wel iets op tape als je de log bekijkt ;)
dat72...dat is toch 36/72 GB? Dus worst-case kun je er maar 36Gb op kwijt. Op mij komt het over dat de tape gewoon (bijna) vol zit na 43Gb backup en dat het volgende deel failt omdat hij dit niet meer kwijt kan.
Any errors in spelling, tact, or fact are transmission errors.
  • elevator
elevator
Officieel moto fan :)
Ik pas je topic titel even aan mvtb want enkel "Backup failed" bevat wel erg weinig info. Wat heb je trouwens zelf al geprobeerd om dit op te lossen? :)
  • Aikon
Deadeye878 schreef op woensdag 08 april 2009 @ 08:57:
Ah... nu zie ik het. Dat kan de TS toch zeer eenvoudig controleren, even een jobje van 100MB aanmaken oid.
Thx voor de reacties , zal es een job maken van een 100mb en es kijken of da werkt .
  • Xblast
  • Laatst online: 12-05-2025
Dit heb ik vaak genoeg gezien op mijn stage.
De tape is vol, en hij eject hem dan.
Blijkbaar kan hij niet alles zodanig compressen dat er 72GB op kan.
Die job van 100mb zal gewoon lukken.
Xblast schreef op woensdag 08 april 2009 @ 10:17:
En jij hebt gelijk , de job van 100mb werkt gewoon .
Dus het is gewoon teveel ..ik zal eens kijken wat ik kan weglaten.
Thx voor de hulp .
  • Aikon
Wellicht zelf al inpakken met 7zip op ultra settings?
nee joh , backup wordt elke avond gemaakt :)
  • FireDrunk
  • Laatst online: 18-10 15:48
Aikon schreef op woensdag 08 april 2009 @ 11:48:
Dat is wel een idiote belasting voor zo'n server... 8-)
Ze staan dan wel de helft van de tijd (na 6 uur 's middags en voor 7 uur 's ochtends) niks te doen...
Maar toch ;)
Even niets...
