• FutureCow
  • Laatst online: 07:39
FutureCow
(C) FutureCow
Mijn PC:
ASUS M2N68-AM
AMD Athlon 5000+
2x 1 GB RAM
ATI 4550
Als ik mijn PC wil afsluiten dan hoor je dat hij nog even laad, maar op het moment dat normaal gesproken alles uit gaat blijft de fans draaien en de PC dus aan.
Maar de PC is dan helemaal vast gelopen, je kunt dan alleen nog maar de powerknop 3sec in gedurkt houden en hem daarna opnieuw opstarten.
als ik in de event vieuwer kijk dan zie ik dit staan:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Corrected Machine Check
Error Type: Bus/Interconnect Error
Processor ID: 1
The details view of this entry contains further information.
- System
  - Provider
   [ Name]  Microsoft-Windows-WHEA-Logger
   [ Guid]  {C26C4F3C-3F66-4E99-8F8A-39405CFED220}
   EventID 19
   Version 0
   Level 3
   Task 0
   Opcode 0
   Keywords 0x8000000000000000
  - TimeCreated
   [ SystemTime]  2009-04-01T05:49:30.624800000Z
   EventRecordID 710
  - Correlation
   [ ActivityID]  {D0E1857F-8380-44C8-AD36-212A56DF5A1B}
  - Execution
   [ ProcessID]  1140
   [ ThreadID]  2808
   Channel System
   Computer MediaCenter-PC
  - Security
   [ UserID]  S-1-5-19
- EventData
  ErrorSource 1
  ApicId 1
  MCABank 0
  MciStat 0xc64f010000010ffb
  MciAddr 0xffbc7cf0ffb
  MciMisc 0x0
  ErrorType 10
  TransactionType 256
  Participation 3
  RequestType 15
  MemorIO 2
  MemHierarchyLvl 3
  Timeout 1
  OperationType 256
  Channel 256
  Length 928
  RawData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
Kan hier op internet helemaal niets over vinden. Wat betekend deze error? Zou dit het probleem kunnen zijn?
  • Capacitor
  • Laatst online: 10:27
Heb hier ook last van gehad. Kreeg blauwe strepen in beeld en computer bleef maar aanstaan. Powerknop 3 seconden indrukken was het enige wat hielp.
Heb toen 1 keer een chkdsk /r gedraaid en dat heeft bij mij geholpen.
Hoe je een chkdsk runt kun je vinden via Google (of als het niet lukt mag je me ook PM'en).
Wat je ook kan proberen als dit niet helpt is om met zo min mogelijk hardware te booten (processor, geheugen, harde schijf, videokaart) en kijken of je dan wel normaal kunt afsluiten. Als dit lukt kun je steeds iets er bijzetten (geluidskaart, netwerkkaart etc.) Sluit hij dat nog niet af dan zou je eens Memtest moeten gaan draaien en cpu-test (hiren's bootcd heeft hier veel tools van).
Mvg,
Lars93
Probeer eens in de veilige modus op te starten en dan af te sluiten.
Als dat werkt, ligt het aan software en dan moet je kijken wat je recent hebt geinstalleerd en waaraan het kan liggen.
[ Voor 27% gewijzigd door Verwijderd op 01-04-2009 12:45 ]
