[debian] OpenAFS + kerberos: possible communication failure
  • Boudewijn
Boudewijn
omdat het kan
Ik heb kerberos opgezet op mijn debian etch vm, en wil daar openafs op gaan draaien (ivm betere rechtensysteem dan nfs).
Ik heb deze guide gebruikt voor kerberos:
http://www.debian-administration.org/articles/570
Voor openafs gebruik ik deze guide:
http://www.debian-administration.org/articles/610
Mijn domein is boudewijnector.nl, de kerberos en afs doos zijn hetzelfde ip adres (10.13.37.130, met als A record krb.boudewijnector.nl en afs.boudewijnector.nl).
Nu kan ik netjes de key importeren enzo:
boudewijn@kerberos:~$ sudo bos listkeys afs1 -localauth
key 3 has cksum 3183730113
Keys last changed on Sun Mar 29 04:18:08 2009.
All done.
Echter als ik een share aan wil maken:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
kerberos:/# afs-newcell
                            Prerequisites
In order to set up a new AFS cell, you must meet the following:
1) You need a working Kerberos realm with Kerberos4 support.  You
   should install Heimdal with KTH Kerberos compatibility or MIT
   Kerberos 5.
2) You need to create the single-DES AFS key and load it into
   /etc/openafs/server/KeyFile.  If your cell's name is the same as
   your Kerberos realm then create a principal called afs.  Otherwise,
   create a principal called afs/cellname in your realm.  The cell
   name should be all lower case, unlike Kerberos realms which are all
   upper case.  You can use asetkey from the openafs-krb5 package, or
   if you used AFS3 salt to create the key, the bos addkey command.
3) This machine should have a filesystem mounted on /vicepa.  If you
   do not have a free partition, then create a large file by using dd
   to extract bytes from /dev/zero.  Create a filesystem on this file
   and mount it using -oloop.
4) You will need an administrative principal created in a Kerberos
   realm.  This principal will be added to susers and
   system:administrators and thus will be able to run administrative
   commands.  Generally the user is a root or admin instance of some
   administrative user.  For example if jruser is an administrator then
   it would be reasonable to create jruser/admin (or jruser/root) and
   specify that as the user to be added in this script.
5) The AFS client must not be running on this workstation.  It will be
   at the end of this script.
Do you meet these requirements? [y/n] y
If the fileserver is not running, this may hang for 30 seconds.
/etc/init.d/openafs-fileserver stop
What administrative principal should be used? root/admin
/etc/openafs/server/CellServDB already exists, renaming to .old
/etc/init.d/openafs-fileserver start
bos adduser kerberos.boudewijnector.nl root.admin -localauth
Creating initial protection database.  This will print some errors
about an id already existing and a bad ubik magic.  These errors can
be safely ignored.
pt_util: /var/lib/openafs/db/prdb.DB0: Bad UBIK_MAGIC. Is 0 should be 354545
Ubik Version is: 2.0
Error while creating system:administrators: Entry for id already exists
bos create kerberos.boudewijnector.nl ptserver simple /usr/lib/openafs/ptserver -localauth
bos create kerberos.boudewijnector.nl vlserver simple /usr/lib/openafs/vlserver -localauth
bos create kerberos.boudewijnector.nl fs fs -cmd '/usr/lib/openafs/fileserver -p 23 -busyat 6c 1200' -cmd /usr/lib/openafs/volserver -cmd /usr/lib/openafs/salvager -localauth
bos setrestart kerberos.boudewijnector.nl -time never -general -localauth
Waiting for database elections: done.
vos create kerberos.boudewijnector.nl a root.afs -localauth
Could not get an Id for volume root.afs
   Possible communication failure
Error in vos create command.
Failed: 65280
Cell setup failed, ABORTING
bos shutdown kerberos.boudewijnector.nl -localauth -wait
bos delete kerberos.boudewijnector.nl fs -localauth
bos delete kerberos.boudewijnector.nl vlserver -localauth
bos delete kerberos.boudewijnector.nl ptserver -localauth
rm /var/lib/openafs/db/prdb*
bos removeuser kerberos.boudewijnector.nl root.admin -localauth
kerberos:/#
De disk is gemount ,kerberos werkt etc.
En toch werkt het niet.
Kan iemand me een tipje geven van wat er fout gaat?
Possibel communication failure :?
  • filenox
  • Laatst online: 23-08 12:18
Looks like your vlserver isn't running (port 7003)
bron
Hopelijk heb je er iets aan :)
[ Voor 4% gewijzigd door filenox op 29-03-2009 18:34 ]
  • Boudewijn
Boudewijn
omdat het kan
Er draait inderdaad niets op 7003, echter zeggen de logjes ook niets:
Mar 29 18:42:50 kerberos kadmind[2353](debug): Got signal to request exit
Mar 29 18:42:50 kerberos kadmind[2353](info): finished, exiting
Mar 29 18:42:50 kerberos kadmind[4190](info): No dictionary file specified, continuing without one.
Mar 29 18:42:50 kerberos kadmind[4191](info): Seeding random number generator
Mar 29 18:42:50 kerberos kadmind[4191](info): starting
krb5kdc: Interrupted system call - while selecting for network input(1)
Mar 29 18:42:46 kerberos krb5kdc[2357](info): shutting down
Mar 29 18:42:46 kerberos krb5kdc[4180](info): setting up network...
Mar 29 18:42:46 kerberos krb5kdc[4180](info): skipping unrecognized local address family 17
Mar 29 18:42:46 kerberos krb5kdc[4180](info): listening on fd 7: udp 10.13.37.130.88
Mar 29 18:42:46 kerberos krb5kdc[4180](info): listening on fd 8: udp 10.13.37.130.750
Mar 29 18:42:46 kerberos krb5kdc[4180](info): listening on fd 9: udp fe80::20c:29ff:fefb:bf33%eth0.88
Mar 29 18:42:46 kerberos krb5kdc[4180](info): listening on fd 10: udp fe80::20c:29ff:fefb:bf33%eth0.750
Mar 29 18:42:46 kerberos krb5kdc[4180](info): set up 4 sockets
Mar 29 18:42:46 kerberos krb5kdc[4181](info): commencing operation
Ziet er prima uit.
Ik zie ook niets gebeuren rond die vlserver op de tutorial :).
  • _JGC_
  • Laatst online: 22:58
Ik zie overigens dat je MIT kerberos gebruikt. Waarschijnlijk werkt dat ook goed, maar Heimdal is over het algemeen een stuk makkelijker, vooral omdat die AFS integratie heeft.
  • Boudewijn
Boudewijn
omdat het kan
Okay, maar de howto op debian-administration gebruikt MIT kerberos.
Zal eens naar Heimdal gaan kijken ,maar op zich is het ook wel leuk om dit probleem op te lossen.
