T400 high pitch noise "whine"
  • 305 views
hey guys, (hope engels is ok)
I got a T400 recently and have noticed a high-pitch noise coming from the left and right sides of the notebook. I have done quite a bit of reading and it seems to be caused by vibrations from low-quality components on the motherboard (capacitors, coil inductors).
I have tried using utilities like RMClock to adjust the power settings, and force the CPU to stay active- this does not help. It seems the more use it gets the more I hear it. If I have 30 tabs open in Firefox, for example, is a sure way to initiate it.
Someone suggested getting different adhesives or coatings to put on these coils or capacitors to insulate them better and stop the vibrating. Does anyone here have any experience with this? Where can I find these pastes or adhesives?
I'd send it back but it's a huge hassle now since I got it in the US and now have it here with me (Arnhem).
  • omgwtfbbq
  • Laatst online: 21:22
Just a dip of non-conductive glue on the coils/capicitors should do the trick, but beware, because you will loose your warranty
[ Voor 3% gewijzigd door omgwtfbbq op 20-02-2009 09:24 . Reden: guarantee =! garantie ]
  • _the_crow_
  • Laatst online: 30-03-2025
_the_crow_
Rare vogel
Voor de duidelijkheid? Je bedoelt een Lenovo Thinkpad? :)
Schrödingers cat: In this case there are three determinate states the cat could be in: these being Alive, Dead, and Bloody Furious.
  • jj71
  • Laatst online: 18-11 14:52
omgwtfbbq schreef op vrijdag 20 februari 2009 @ 08:26:
... you will loose your guarantee...
Garantie in het Engels is warranty.
  • omgwtfbbq
jj71 schreef op vrijdag 20 februari 2009 @ 09:18:
Ik zat nog te twijfelen, maar heb dus fout gegokt :$
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Omdat GoT een Nederlands forum is verwachten we dat je ook in het Nederlands post. Dit topic gaat daarom ook dicht.
