Waarmee het beste te upgraden
Heb een oud moederboard in een vrij moderne systeemkast (Antec) maar de pc is wel tergend traag. Nu wil ik deze pc gaan upgraden en zat hierbij te denken om het moederboard te vervangen. Hiermee wil ik bereiken dat alles (internet, tekstverwerken, programmeren) een beetje sneller gaat. Elke tip is welkom !!
Mijn moederboard is P4i65G met 2 Gb geheugen en hieronder een uitgebreidere overzicht:
[Current Computer]
Computer Brand Name: P4i65G
[Operating System]
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processors Cores: 1
Number Of Logical Processors: 1
Intel Pentium 4-2533 ------------------------------------------------------
[General Information]
Processor Name: Intel Pentium 4-2533
Original Processor Freqency: 2533.3 MHz
Original Processor Freqency [MHz]: 2533
CPU ID: 00000F24
CPU Brand Name: Intel(R) Pentium(R) 4 CPU 2.53GHz
CPU Vendor: GenuineIntel
CPU Stepping: B0
CPU Code Name: Northwood
CPU QDF/S-Spec: QLB2, SL685, SL682, SL6EV, SL6D8
CPU Thermal Design Power (TDP): 59.3 W
CPU Max. Case Temperature (Tcase_max): 71 °C
CPU Type: Production Unit
CPU Platform: Socket 478 FC-PGA2 (mPGA478B)
Microcode Update Revision: 1E
Number of CPU Cores: 1
Number of Logical CPUs: 1
[Operating Points]
CPU LFM (Minimum): 2533.3 MHz = 19.00 x 133.3 MHz
CPU HFM (Maximum): 2533.3 MHz = 19.00 x 133.3 MHz [Locked]
CPU Current: 2530.0 MHz = 19.00 x 133.2 MHz
CPU Bus Type: FSB (QDR)
[Cache and TLB]
L1 Cache: Instruction Trace: 12K uOps, Data: 8 KBytes
L2 Cache: Integrated: 512 KBytes
Instruction TLB: 4KB/2MB/4MB Pages, Fully associative, 64 entries
Data TLB: 4KB/4MB Pages, Fully associative, 64 entries
[Standard Feature Flags]
FPU on Chip Present
Enhanced Virtual-86 Mode Present
I/O Breakpoints Present
Page Size Extensions Present
Time Stamp Counter Present
Pentium-style Model Specific Registers Present
Physical Address Extension Present
Machine Check Exception Present
CMPXCHG8B Instruction Present
APIC On Chip / PGE (AMD) Present
Fast System Call Present
Memory Type Range Registers Present
Page Global Feature Present
Machine Check Architecture Present
CMOV Instruction Present
Page Attribute Table Present
36-bit Page Size Extensions Present
Processor Number Not Present
CLFLUSH Instruction Present
Debug Trace and EMON Store Present
Internal ACPI Support Present
MMX Technology Present
Fast FP Save/Restore (IA MMX-2) Present
Streaming SIMD Extensions Present
Streaming SIMD Extensions 2 Present
Self-Snoop Present
Multi-Threading Capable Present
Automatic Clock Control Present
IA-64 Processor Not Present
Signal Break on FERR Not Present
Streaming SIMD Extensions 3 Not Present
Carryless Multiplication (PCLMULQDQ) Not Present
64-Bit Debug Store Not Present
MONITOR/MWAIT Support Not Present
CPL Qualified Debug Store Not Present
Virtual Machine Extensions Not Present
Safer Mode Extensions (Intel TXT) Not Present
Thermal Monitor 2 Not Present
Supplemental Streaming SIMD Extensions 3 Not Present
Enhanced SpeedStep Technology Not Present
L1 Context ID Not Present
CMPXCHG16B Support Not Present
Send Task Priority Messages Disabling Not Present
Performance/Debug Capability MSR Not Present
Direct Cache Access Not Present
Streaming SIMD Extensions 4.1 Not Present
Streaming SIMD Extensions 4.2 Not Present
Extended xAPIC Not Present
MOVBE Instruction Not Present
POPCNT Instruction Not Present
AES Cryptography Support Not Present
XSAVE/XRSTOR/XSETBV/XGETBV Instructions Not Present
XGETBV/XSETBV OS Enabled Not Present
AVX Support Not Present
[Extended Feature Flags]
64-bit Extensions Not Present
No Execute Not Present
SYSCALL/SYSRET Support Not Present
[Enhanced Features]
Thermal Monitor 1: Supported, Enabled
Thermal Monitor 2: Not Supported
Enhanced Intel SpeedStep (GV3): Not Supported
Bi-directional PROCHOT#: N/A
Extended Auto-HALT State C1E: N/A
Extended Stop Grant State C2E: N/A
Enhanced Halt State C3E: N/A
Enhanced Halt State C4E: N/A
Enhanced Halt State Hard C4E: N/A
Hardware Prefetcher: Supported, Enabled
DCU Prefetcher: Not Supported
IP Prefetcher: Not Supported
Adjacent Cache Line Prefetch: Supported, Enabled
Intel Dynamic Acceleration (IDA) Technology: Not Supported
Intel Dynamic FSB Switching: Not Supported
Enhanced Multi Threaded Thermal Management: N/A
Intel Turbo Boost Technology: Not Supported
Programmabe Ratio Limits: Not Supported
Programmabe TDC/TDP Limits: Not Supported
[Memory Ranges]
Maximum Pysical Address Size: 36-bit (64 GBytes)
Maximum Virtual Address Size: 32-bit (4 GBytes)
[MTRRs]
Range 0-80000000 (0MB-2048MB) Type: Write Back (WB)
Range 7F800000-80000000 (2040MB-2048MB) Type: Uncacheable (UC)
[P.I.ROM]
P.I.ROM Status: Not Present
  • DM.Aram
  • Laatst online: 10-12-2021
DM.Aram
DMTZ.i
Uiteraard moet je zelf eerst op zoek gaan naar oplossingen. Welk OS draait op deze computer? Een Windows XP Pro SP3 zou het nog aardig moeten doen.
Een globale upgrade, van Pentium 4 naar Core 2 Duo E7400 oid. is natuurlijk een stuk beter. Maar dan moet je je moederbord en het liefst je geheugen ook upgraden. Heb je een budget?
See you in another life, brother.
  • asfaloth_arwen
  • Laatst online: 20:09
Budget? Waarom upgraden en geen nieuw systeem? Investeren in een oud systeem loont zich niet echt met de huidige prijzen. Bekijk even CSL FAQ en CSL Beleid :)
[ Voor 20% gewijzigd door asfaloth_arwen op 19-02-2009 14:50 ]
Specs
  • alex3305
  • Laatst online: 23-10 20:28
Persoonlijk kun je beter een nieuwe computer kopen waarschijnlijk ;) Eventueel losse onderdelen. Een Pentium 4 is namelijk al redelijk oud.
  • DM.Aram
DM.Aram
DMTZ.i
Met een budget van, laten we zeggen, 600 euro kun je al aardig wat. Je hebt geen case nodig dus die 60 euro kan je weer besteden aan geheugen of iets dergelijks.
