BIOS?! BTO15V125+ or VESTEL DJR154SP
Hi
I have a notebook
BTO 15V125+ Performance or VESTEL DJR154SP.....
Intel® Core 2 Duo T7250 2,0GHz - 2 Mb (FSB-800MHz)....
I changed IDE configuration in BIOS to set the option "HDC configured as" (in IDE Config) to "AHCI"
And since this setting, my laptop not boot at all and get stuck on a black screen at the beginning of the boot ( until to make test equipment).
I remember cose I had changed something like
DEEP C4 Enable
I wish to return to the default configuration of the BIOS, but I do not know how.
Someone know the solution to my problem? and if so, could he be so kind to send me?
Thanks
  • Outerspace
  • Laatst online: 23:27
Outerspace
Admin General Chat
Is the BIOS available to enter or is the laptop crashing before you can enter the BIOS?
Can you reset the bios with the battery wich is in the laptop self?
Wauw, een sig!
the notebook does not make any beep and every time when I try to BOOT ON he try reading from... CD
Outerspace schreef op vrijdag 06 februari 2009 @ 14:00:
I have to say that VISTA was before, then I put XP. After a while I started to have problems and I entered the BIOS ...
The BIOS is not available to enter... I CAN'T SEE ANYTHING ON THE WINDOW... just a black screen
I can't reset BIOS with the battery... I had try it...
:( WHAT IT CAN BE? The screen light on ( I can see a line in the left bottom for 2 seconds... then nothing...)
[ Voor 28% gewijzigd door Verwijderd op 06-02-2009 14:27 ]
Hello..
No one can help me??
I wish to install BIOS again!! Any idea?? how to do this?? :(
  • Outerspace
Outerspace
Admin General Chat
Verwijderd schreef op zaterdag 07 februari 2009 @ 11:33:
Hello..
Did you remove the battery or did you try? Big difference between those actions ;)
Wauw, een sig!
Outerspace schreef op zaterdag 07 februari 2009 @ 11:48:
I removed the battery for 1 day... but nothing was.. the same problem...
I think the best way is to flash BIOS again... I need help for this.... I don't think the MB was crashed!!!
I removed the HDD, memory one by one, keyboard....
[ Voor 6% gewijzigd door Verwijderd op 09-02-2009 08:37 ]
