[Ubuntu] Ati Radeon 9250 geen juiste resoluties.
  • battler
  • Laatst online: 30-06-2025
Probleem: Mijn Ubuntu geeft alleen maar lage resoluties weer. (800x600) en lager.
Ik wil uiteindelijk gewoon 1920x1200 draaien, het scherm en de graka moeten dit aankunnen.
Ook kan ik niet in CLI mode (Init 1,2 e.d) als ik CTRL-ALT-F1 druk, gebeurd er niets.
Ook het inlog scherm is in een veel te lage resolutie.
Er zijn veel problemen bekend, maar ik krijg door geen enkele oplossing mijn resolutie hoger.
Xorg.Conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by failsafeDexconf, using
# values from the debconf database and some overrides to use vesa mode.
# You should use dexconf or another such tool for creating a "real" xorg.conf
# For example:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
    Identifier  "Generic Keyboard"
    Driver      "kbd"
    Option      "XkbRules"  "xorg"
    Option      "XkbModel"  "pc105"
    Option      "XkbLayout" "nl"
    Option      "XkbVariant"    "intl"
    Option      "XkbOptions"    "lv3:ralt_switch"
EndSection
    Identifier  "Configured Mouse"
    Driver      "mouse"
EndSection
Section "Device"
    Identifier  "Radeon 9250"
    Boardname   "ati"
    Busid       "PCI:1:0:0"
    Driver      "ati"
EndSection
Section "Monitor"
    Identifier  "Configured Monitor"
    Vendorname  "Dell"
    Modelname   "Dell 2407WFP (Analog)"
    Horizsync   30.0-83.0
    Vertrefresh 56.0-76.0
  modeline  "1024x768@60" 193.16 1920 2048 2256 2592 1200 1201 1204 1242 -hsync +vsync
    Gamma   1.0
EndSection
Section "Screen"
    Identifier  "Default Screen"
    Device      "Radeon 9250"
    Monitor     "Configured Monitor"
    Defaultdepth    24
    SubSection "Display"
        Depth   24
        Modes "1024x768"
    EndSubSection
EndSection
Section "ServerLayout"
    Identifier  "Default Layout"
  screen 0 "Default Screen" 0 0
EndSection
Section "Module"
    Load        "glx"
    Load        "GLcore"
    Load        "dri"
    Load        "v4l"
    Load        "radeon"
EndSection
Section "DRI"
    Mode 0666
EndeSection
Specs:
Os: Ubuntu Hardy 8.04
Graka: Ati Radeon 9250 pro (PCI Card).
Scherm: Dell 2407 (via DVI).
Links:
https://help.ubuntu.com/c...9200/9250_(RV280)_and_DVI
https://wiki.ubuntu.com/Bugs/AtiDriver
Werkende Xorg conf voor Dell 2407
Ik heb al verschillende Xorg confs geprobeerd, maar de resolutie veranderd nooit.
Driver verwijderd, opnieuw geistalleerd. Opensource driver gepakt (dit zou moeten werken.)
Maar niets helpt. :(
Lux.Architectuur | Van Dromen tot Wonen | www.Lux-a.nl
  • jan99999
  • Laatst online: 30-10 01:24
Probee dit eens.
Envy installeren(is in ubuntu).
Envy starten(grafisch), drivers verwijderen,
reboot,
opstarten recovery mode,
kies fix x,
ga naar textmode,
start envy met "envyng -t"
nu heb je een menu, installeer driver,
reboot,
klaar.
  • battler
Vergeten te melden. Heb ik al geprobeerd (maar voor de zekerheid nog ene keer).
De melding die ik krijg:
Your graphic card has been detected als ATI Radeon 9250
Your graphic card is supported by the legacy driver.
EnvyNG ERROR: ATI'S legacy driver does not support your operating System.
Jammer genoeg werkt dit dus niet.
  • jan99999
Zoek eens naar "blacklisted" videocard dit kun je uitzetten, of beter gezegd je kan zeggen dat er niet gekontroleerd wordt of de videcard voldoet. Of je de kaart aan het lopen krijgt weet ik niet.
Je kan nog de vesa driver proberen, hiervoor zul je een xorg voorbeeld moeten zoeken en deze bij jezelf erin moeten kopieren, je hebt dan wel geen 3d, maar wel alle scherm grootte die er zijn.
  • gertvdijk
  • Laatst online: 18:19
gertvdijk
De legacy drivers worden niet meer ondersteund inderdaad (blame ATI). De opensource drivers voor de 92xx serie zijn echt heel goed, hoor. Ik heb een 9200 eens op 8.04 gedraaid out-of-the box voortreffelijke ondersteuning, ook 3D. Vesa drivers zijn geen optie m.i. Dat is echt slechte 2D performance.
Kia e-Niro 2021 64kWh DynamicPlusLine. 3x Victron MP-II op 15kWh US5000 3f thuisbatterij met 3x25A→3x40A PowerAssist, Victron EVCS, 3200Wp HoyMiles zp. my GitHub, my blog
  • battler
Ik heb als het goed is nu de opensource drivers (deze tut. gevolgd).
Is er een manier om zeker te weten dat ik die opensource drivers draai?
Op die website staat het volgende:
Testing The Driver
To see if you are using the driver you can test your 3D settings. To test your OpenGL acceleration you can run:
$ glxinfo | grep vendor
This has to be SGI <-- dit klopt ook bij mij.
  • gertvdijk
gertvdijk
Voor de 9250 zit er al heeeeel lang deze bug in de driver i.c.m. DVI aansturing. Dat staat notabene op de link (tutorial) die je zelf geeft. ;)
  • battler
Jammer genoeg zijn de stappen aangegeven in die tut een beetje oud.
To recompile the driver we need some packages installed on our system.
$ sudo apt-get install build-essential fakeroot
$ sudo apt-get build-dep xserver-xorg-driver-ati
Dit laatste gaat niet, dan krijg ik de melding: Kan geen bronpakket vinden voor xserver-xorg-driver-ati.
xserver-xorg-video-ati - X.Org X server -- ATI display driver <-- deze kan ik downloaden en installeren.
This downloads three files and unpacks the sources into the directory xserver-xorg-driver-ati-version. In this directory is the file src/radeon_bios.c, that we need to edit. Towards the end of this file is a comment saying:
Dit klopt nog alleen kan ik het volgende niet vinden:
/* revision 4 has some problem as it appears in RV280,
comment it off for now, use default instead */
And after this comment follows a code block that has been commented out. We need to re-enable this code by removing the commenting-out. In my case deleting lines 574 and 561 did the job.
Deze tekst kan ik dus helemaal niet vinden, ik heb gezocht op RV280 en row numbers, maar ik kan niets soortgelijks vinden. Iemand tips/hints/ideeen
