Hacking attempts?
Ik keek voor de gein even in mijn routerlogs, eens kijken wat er daar allemaal in stond;
29
30
31
32
33
34
35
              System Logs
Tue Feb 03 15:56:01 2009 Unrecognized attempt blocked from 75.117.214.155:60880 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:03 2009 Unrecognized attempt blocked from 91.155.221.36:4045 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:03 2009 Unrecognized attempt blocked from 86.26.92.36:51945 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:03 2009 Unrecognized attempt blocked from 86.26.92.36:51946 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:04 2009 Unrecognized attempt blocked from 75.117.214.155:60879 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:04 2009 Unrecognized attempt blocked from 75.117.214.155:60880 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:06 2009 Unrecognized attempt blocked from 91.155.221.36:4045 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:09 2009 Unrecognized attempt blocked from 86.26.92.36:51946 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:10 2009 Unrecognized attempt blocked from 75.117.214.155:60880 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:12 2009 Unrecognized attempt blocked from 91.155.221.36:4045 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:12 2009 Unrecognized attempt blocked from 78.176.204.154:3691 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:15 2009 Unrecognized attempt blocked from 78.176.204.154:3691 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:22 2009 Unrecognized attempt blocked from 75.23.249.224:4877 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:29 2009 Unrecognized attempt blocked from 99.235.137.99:1204 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:32 2009 Unrecognized attempt blocked from 99.235.137.99:1204 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:33 2009 Unrecognized attempt blocked from 81.27.13.224:62720 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:33 2009 Unrecognized attempt blocked from 90.23.152.112:1024 to 213.93.245.62 UDP:48153
Tue Feb 03 15:56:35 2009 Unrecognized attempt blocked from 99.235.137.99:1205 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:36 2009 Unrecognized attempt blocked from 81.27.13.224:62720 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:38 2009 Unrecognized attempt blocked from 99.235.137.99:1205 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:42 2009 Unrecognized attempt blocked from 81.27.13.224:62720 to 213.93.245.62 TCP:55947
Tue Feb 03 15:56:43 2009 Unrecognized attempt blocked from 78.96.237.250:3376 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:44 2009 Unrecognized attempt blocked from 72.209.131.229:30727 to 213.93.245.62 UDP:48153
Tue Feb 03 15:56:44 2009 Unrecognized attempt blocked from 24.224.189.158:6992 to 213.93.245.62 UDP:48153
Tue Feb 03 15:56:44 2009 Unrecognized attempt blocked from 68.34.188.221:49859 to 213.93.245.62 UDP:48153
Tue Feb 03 15:56:44 2009 Unrecognized attempt blocked from 71.185.193.99:32364 to 213.93.245.62 UDP:48153
Tue Feb 03 15:56:44 2009 Unrecognized attempt blocked from 24.45.189.60:55032 to 213.93.245.62 UDP:48153
Tue Feb 03 15:56:44 2009 Unrecognized attempt blocked from 99.235.137.99:1205 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:46 2009 Unrecognized attempt blocked from 78.96.237.250:3376 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:49 2009 Unrecognized attempt blocked from 78.96.237.250:3377 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:52 2009 Unrecognized attempt blocked from 78.96.237.250:3377 to 213.93.245.62 TCP:48153
Tue Feb 03 15:56:54 2009 Unrecognized attempt blocked from 91.138.23.159:2058 to 213.93.245.62 TCP:55947
Zo heb ik een nog véél grotere logfile met IP-adressen die op poort 48153 en 55947 willen binnenkomen. Na wat zoeken op Google kwam ik tot de conclusie dat beide poorten nergens naar 'assigned' zijn, erg vreemd dus.
Wat moet ik hier nu mee? Ik merk namelijk dat mijn internetverbinding de laatste tijd behoorlijk onstabiel is.
  • Brahiewahiewa
  • Laatst online: 30-09-2022
Brahiewahiewa
boelkloedig
Verwijderd schreef op dinsdag 03 februari 2009 @ 16:04:
...Wat moet ik hier nu mee? Ik merk namelijk dat mijn internetverbinding de laatste tijd behoorlijk onstabiel is.
Hier moet je helemaal niks mee; gewoon negeren. Van één portscan per seconde gaat je internetverbinding niet instabiel worden.
QnJhaGlld2FoaWV3YQ==
  • pouyann
  • Laatst online: 21-09 10:42
je computer heel goed scannen voor Trojaans (als je meerdere computers hebt allemaal scanne dus)!! verder de poort in de firewall van je router handmatig dicht gooien.
en de reden waarom je internet traag is geworden laatste tijd zou kunne komen doordat er heel veel verzoeken worden gedaan en die worden tegen gehouden door je router want als ik die log file bekijk dan is er om de 2/3 sec een "attack" dus dat zorgt ervoor dat je router trager gaat functioneren "net of je de hele tijd zwaar wordt geping'd".
Dit is de gegevens van de ip's, mischien kan je het aankaarten bij de ISP(zijn er bij vermeld):
Your IP Address: 91.138.23.159
IP Address Hostname: dyn-cable-customer.159.23.138.91.yetnet.ch
IP Country: Switzerland
IP Country Code: CHE
IP Continent: Europe
IP Region: Aargau
Guessed City: Villnachern
IP Latitude: 47.4667
IP Longitude: 8.1667
ISP Provider: yetnet.ch, CableTV and Internet provider
Your IP Address: 78.96.237.250
IP Address Hostname: 78.96.237.250
IP Country: Romania
IP Country Code: ROU
IP Region: Alba
Guessed City: Aiud
IP Latitude: 46.3
IP Longitude: 23.7167
ISP Provider: ASTRAL Aiud
  • Exorcist
Exorcist
Uitdrijvûrrrr!
Gebruik je een P2P programma, uTorrent ofzo?
  • ToasterxD
  • Laatst online: 16-10 16:45
P2p programma's zorgen soms voor een UDP flood (utorrent enzo)
[img]http://cache.www.gametracker.com/server_info/173.199.108.129:3084/b_560_95_1.png[/img]
  • Mr.Qips
  • Laatst online: 18-10 14:02
Dit is overduidelijk het gevolg van torrenten. Uiteraard wordt je internet hier langzamer van. Dat hoort er gewoon bij. Na een uurtje (na het afsluiten van je torrent) is 't weer over.
