[Tversity]netwerk share kan niet bereikt worden.
  • CrankyGamerOG
  • Laatst online: 22:28
CrankyGamerOG
Assumption is the mother.....
Laat ik eerst de situatie schetsen.....
Server :
Supermicro P4SCE
Pentium 4 3.0Ghz
2GB DDR400
Linux 2.6.18-92, met hierop VMware Server 2.0.
Linux heeft de volgende ip configuratie
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
eth0      Link encap:Ethernet  HWaddr 00:30:48:73:AF:D4
          inet addr:xx.xx.xx.xx  Bcast:255.255.255.255  Mask:255.255.254.0
          inet6 addr: fe80::230:48ff:fe73:afd4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:127377 errors:0 dropped:0 overruns:0 frame:0
          TX packets:58980 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:100
          RX bytes:104467501 (99.6 MiB)  TX bytes:7428163 (7.0 MiB)
          Base address:0x9c00 Memory:f2800000-f2820000
eth1      Link encap:Ethernet  HWaddr 00:30:48:73:AF:D5
          inet addr:10.0.0.1  Bcast:10.0.0.255  Mask:255.255.255.0
          inet6 addr: fe80::230:48ff:fe73:afd5/64 Scope:Link
          RX packets:869956 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4235117 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:73500886 (70.0 MiB)  TX bytes:1624183812 (1.5 GiB)
          Base address:0xa000 Memory:f2820000-f2840000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:71449 errors:0 dropped:0 overruns:0 frame:0
          TX packets:71449 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:69958773 (66.7 MiB)  TX bytes:69958773 (66.7 MiB)
vmnet1    Link encap:Ethernet  HWaddr 00:50:56:C0:00:01
          inet addr:192.168.97.1  Bcast:192.168.97.255  Mask:255.255.255.0
          inet6 addr: fe80::250:56ff:fec0:1/64 Scope:Link
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
vmnet8    Link encap:Ethernet  HWaddr 00:50:56:C0:00:08
          inet addr:192.168.45.1  Bcast:192.168.45.255  Mask:255.255.255.0
          inet6 addr: fe80::250:56ff:fec0:8/64 Scope:Link
          RX packets:32 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
In VMware Server draait WindowsXP
De Virtual Machine draait in Bridge Mode, met de volgende ip config
Ethernet-adapter LAN-verbinding:
        Verbindingsspec. DNS-achtervoegsel: medialan.nl
        IP-adres. . . . . . . . . . . . . : 10.0.0.9
        Subnetmasker. . . . . . . . . . . : 255.255.255.0
        Standaardgateway. . . . . . . . . : 10.0.0.1
Op WindowsXP draait TVersity.
Ik weet dat de Tversity service op een administrator account moet staan om een netwerkshare te benaderen, dit heb ik dan ook gedaan, hij staat op mijn administrator account.
Helaas blijft TVersity melden dat hij de share niet kan benaderen.
Als ik browse naar de share (Z:) dan maakt hij er automatisch \\10.0.0.1\media\media van (wat het ook is)
Echter hierna als ik op ok/apply druk dan meld hij dat hij het pad niet kan vinden en dat ik de service op een admin account moet draaien(wat ik dus doe).
In WindowsXP (in de vm) kan ik de share wel gewoon benaderen.
Wie weet wat ik over het hoofd zie?
Volgens het volgende topic zou het wel moeten werken als ik via my network ga,
helaas werkt dit bij mij ook niet ...
http://forums.tversity.com/viewtopic.php?f=2&t=12389
Als ik dat doe(dus via my networkplaces) dan komt hij met het pad :
\\Samba\media\media
[ Voor 6% gewijzigd door CrankyGamerOG op 29-01-2009 14:49 ]
KPN - Vodafone Ziggo Partner
  • CrankyGamerOG
CrankyGamerOG
OK
volgende poging.
nieuwe VM gemaakt met hierin WindowsXP MCE.
Ik kan de gesharde netwerkschijf zien in XPMCE.
Maar als ik op de xbox360 kijk zie ik alleen de bestanden van XPMCE maar niet van de share.
Is er nou echt geen manier om de sambashare op de linux host te zien op de xbox360 ?
(ik heb twonky draaien op de machine, dus an sich kan ik het wel al, maar ik zou het graag via MCE willen doen, of via tversity vanwege de grotere functionaliteit)
