Overclocken wil niet lukken
  • Axelj
  • Laatst online: 09-10 14:57
Wat doe ik fout...
Ik ben bezig mijn nieuwe pctje over te clocken. Wanneer ik in de bios alles in heb gesteld zoals ik denk dat het zou moeten herstart me pc en eenmaal in windows weer aangekomen staan alle waardes weer op normale stand. Ik probeer hem uiteindelijk op 3.6GHz te kijgen
Mijn pc setup is:
-Corsair TX750 750 Watt
-Intel Core 2 Duo E8400
-Scythe Mugen Infinity Koeler
-GigaByte GA-X48-DQ6
-Mushkin DDR2 XP2-8500 Dual Channel 4 GB, PC8500, 1066 MHz
-Club3D Radeon HD 4870X2
Wat ik in mijn bios zet is als volgt:
GIGABYTE GA X48T DQ6 Clock Settings
MB Intelligent Tweaker (MIT)
Robust Graphics Booster...........: Turbo
CPU Clock Ratio...................: 9.0
CPU Frequency.....................: 3,15Ghz(350x9)
CPU Host Clock Control............: Enable
CPU Host Frequency(Mhz)...........: 350
PCI Express Frequency (Mhz).......: 100
C.I.A.2...........................: Disabled
Performance Enhance...............: Turbo
System Memory Multiplier (SPD)....: Auto
Memory Frequency(Mhz).............: 1120Mhz
DRAM Timing Selectable ...........: Auto
Standard Timing Control
CAS Latency Time (tCL)............: Auto
DRAM RAS# to CAS# (tRCD).........: 5
DRAM RAS# Precharge (tRP).........: 5
Precharge Delay (tRAS)............: 15
Advanced Timing Control
ACT to ACT Delay(tRRD)............: Auto
Rank Write to READ Delay (tWTR)...: Auto
Write To Precharge Delay (tWR)....: Auto
Refresh to ACT Delay (tRFC).......: Auto
Read To Precharge Delay (tRTP)....: Auto
Static tREAD Value (tRD)..........: Auto
Static tREAD Phase Adj............: Auto
Command Rate (CMD)................: Auto
Clock Driving and Skew Control
CPU/PCIEX Clock Driving Control...: 780mv
CPU Clock Skew Control............: Normal
(G)MCH Clock Skew Control.........: Normal
System Voltage Control ()=Base Voltage): Manual
DDR3 OverVoltage Control..........: Manual
PCI-E OverVoltage Control.........: +0.30v
FSB OverVoltage Control...........: Normal
(G)MCH OverVoltage Control........: Normal
Loadline Calibration..............: Auto
CPU Voltage Control...............: Normal
Normal CPU Vcore..................: 1.25000v
Mijn vraag nu is wat ik fout doe.... :?
  • Ali_van_G
  • Laatst online: 10-10 09:04
misschien zit daar het probleem
hou je geheugen eens binnen spec en probeer het weer
edit
weet zelf niets van deze bios, maar probeer zelf eens het voltage van je cpu in te stellen zou dat het niet automatische gedaan wordt.
normal cpu vcore is dit VID of de vcore die je hebt ingesteld?
[ Voor 35% gewijzigd door Ali_van_G op 21-01-2009 20:08 ]
  • Goldman
  • Laatst online: 20:34
Robust Graphics Booster...........: Normal
CPU Frequency.....................: 3,0Ghz(333*9)
CPU Host Frequency(Mhz)...........: 400
Performance Enhance...............: normal
System Memory Multiplier (SPD)....: 2.0
Memory Frequency(Mhz).............: 800
PCI-E OverVoltage Control.........: +0.30v/te veel?
Normal CPU Vcore..................: 1.25000v experminenteren?
Tjaaaaa...c[_] <- een lege care cup! - D3 Profile
  • Axelj
zou idd eens kunnen ja.
nu zie ik bij System Memory Multiplier de volgende opties staan:
2.00B
2.40B
3.20B
4.00B
2.00D
2.66D
3.33D
2.66C
3.33C
4.00C
2.50A
3.00A
4.00A
Iemand enig idee wat dit allemaal betekend?
  • Ali_van_G
misschien heb je hier wat aan. ik betwijfel het want het is een work in progress maar je weet het maar nooit
http://www.hardforum.com/showthread.php?t=1373759
  • DjDuivert
  • Laatst online: 08-09 11:50
Staat Spread Spectrum aan? Zou ik sowieso uitzetten, verder kun je wat experimenteren met CPU Voltage inderdaad, 1,3V moet meer dan genoeg zijn (1,25 zou ie eigenlijk ook wel moeten doen...) PCI-E overvoltage heb je niet nodig, lekker auto laten staan. Verder staat er dat je DDR3 overvoltage control hebt en DDR2 als geheugen, beetje vaag, neem aan dat het een typo is. Dan zou je toch iets verder moeten komen. Het is trouwens waard om even uit te zoeken wat de FSB strap is. Standaard FSB van het bordje (niet zomaar aannemen dat dit 333MHz is vanwege je CPU). Lage FSB strap zet timings binnen de NB strakker en maakt overklokken dus moeilijker. Ook kun je even de CPU multiplier omlaag gooien om te kijken of het bordje 400FSB doet, dan wil je CPU op dat voltage gewoon niet verder namelijk. NB voltage iets omhoog gooien wil ook nog wel eens een verschil maken op 400FSB
2600K - 4.6G|8GB 1333|P8P67 EVO|Club3D 4870 1G OC|2x 2493HM|DasKeyboard Ultimate|Logitech G5|Lian-Li PC-A71b + demping|Intel 510 120G|WD Black 1TB + Green 2TB|Be-Quiet P7-Pro 850W|Xonar D2x|Phonar Ethos R 100G EdMa|Music Hall DAC25.3 + A15.2|AKG K701
  • FreezeXJ
FreezeXJ
DPC-Crew
Mooooh!
Weet je wat ze allemaal bedoelen met die afkortingen?
Om te beginnen
De eerste 2 spreken voor zich. Echter... daarna gaat ie fout. Dingen op auto laten staan is op zich prima, maar in dit geval pakt hij automagisch je beste RAM-timing voor normale FSB. In jouw geval dus 333. (waar je CPU voor gemaakt is dus). Daar past hij de boel aan aan, zodat je RAM dan 1066 draait. Een 3.2 multiplier dus. Ga je dan overklokken, dan gaat je RAM mee. Voila een probleem
Komen we bij deel 2.
Wederom een Auto. Nou heb ik zo'n donkerbruin vermoeden dat daar ook een 'Manual' switch onder zit, en da's altijd een goed idee.
DRAM Timing Selectable. Wat zou dat nou toch eens doen... Hmm... Auto... Weet je het niet?
Dan ga je spelen :P Pak de laagste waarde in dit geval, en kijk eens wat er gebeurt. Ik moet me al heel erg vergissen als je RAM dan niet 2:1 gaat draaien, dus bij 333 FSB (of CPU Host Clock Control, of hoe ze het ook willen noemen) heb je dan 667 te pakken. Vanaf daar kun je verder...
Meeste staat overigens ook in onze schitterende FAQ, een soort van must-read voor iedere overklokker in de dop...
Laatste hint : voltages alleen veranderen als je anders niet verder komt. Daar kun je namelijk wel aardig wat mee mollen, dus voorzichtigheid is geen slecht plan. Klok ze!
"It needs but one foe to breed a war, not two, master Warden. And those who have not swords can still die upon them" - Eowyn
