Samba configureren op Ubuntu
  • HomegrownBGP
Wij hebben in VMWare voor een project Ubuntu 8.04 geinstalleerd. Nu willen wij hiermee een gedeelde map aanmaken. Daarvoor hebben we Samba geinstalleerd, en deze geconfigureerd volgens http://ubuntuforums.org/showthread.php?t=202605 deze how to. Echter kunnen wij nu wél op het icoon van de server klikken in Windows Vista, hij wordt ook geopend, met alles wat daar binnen staat. Alleen nu pakt hij de gedeelde mappen die we hebben niet. Hij pakt de gedeelde printers wel.
Dit is onze configuratie van smb.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
[global]
     General server settings
    netbios name = StefanEyle
    server string =
    workgroup = BRINKHUIS
    announce version = 5.0
    socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE SO_RCVBUF=8192 SO_SNDBUF=8192
    passdb backend = tdbsam
    security = user
    null passwords = true
    username map = /etc/samba/smbusers
    name resolve order = hosts wins bcast
    wins support = yes
;   printing = CUPS
    printcap name = CUPS
    broseable = true
;   syslog = 1
    syslog only = yes
; NOTE: If you need access to the user home directories uncomment the
; lines below and adjust the settings to your hearts content.
[homes]
   ; valid users = %S
    create mode = 0600
    directory mode = 0755
    browseable = yes
    read only = no
   ; veto files = /*.{*}/.*/mail/bin/
; NOTE: Only needed if you run samba as a primary domain controller.
; Not needed as this config doesn't cover that matter.
;[netlogon]
    ;path = /var/lib/samba/netlogon
    ;admin users = Administrator
    ;valid users = %U
    ;read only = no
; NOTE: Again - only needed if you're running a primary domain controller.
;[Profiles]
    ;path = /var/lib/samba/profiles
    ;valid users = %U
    ;create mode = 0600
    ;directory mode = 0700
    ;writeable = yes
    ;browseable = no
; NOTE: Inside this place you may build a printer driver repository for
; Windows - I'll cover this topic in another HOWTO.
;[print$]
    ;path = /var/lib/samba/printers
    ;browseable = no
    ;guest ok = yes
;   ;read only = yes
    ;write list = root
    ;create mask = 0664
    ;directory mask = 0775
[printers]
;   path = /tmp
    printable = yes
    guest ok = yes
    browseable = no
; Uncomment if you need to share your CD-/DVD-ROM Drive
;[DVD-ROM Drive]
    ;path = /media/cdrom
    ;browseable = yes
    ;read only = yes
    ;guest ok = yes
[deelmap]
    path = /home/stefaneyle/deelmap
    browseable = yes
    writeable = yes
    create mask = 0644
    directory mask = 0755
    force user = Administrator
    force group = BRINKHUIS
    valid users = Administrator, nobody, stefaneyle
Wij krijgen in Vista de foutmelding
\\STEFANEYLE\Administrator is niet toegankelijk. U hebt mogelijk niet de juiste machtigingen voor deze netwerkbron. Neem contact met de beheerder van de server op als u wilt weten of u toegangsmachtigingen hebt.
Een apparaat dat op het systeem is aangesloten, werkt niet.
Wie kan ons helpen?
Stefan en Eyle
Ik heb op Vista ook veel moeite om netwerk shares te openen, ook eentje die onder Windows XP draait. Vista lijkt bijna altijd om een gebruikersnaam en wachtwoord te vragen. Misschien heb je een XP systeem tot je beschikking om te testen of het daar dan wel werkt?
Ik heb ook geen Vista bij de hand hier (ik zit op mijn werk), maar in het netwerkcentrum heb je volgens mij een aantal keuzes mbt tot je netwerk (dan doel ik op die lijst met bolletjes die je groen (aan) of grijs (uit) kan zetten. Daar staat ook een optie tussen om bestandsdeling met wachtwoord te beveiligen of niet. Ik weet alleen niet of dit ook geld als je Vista als client optreedt...
  • HomegrownBGP
We hebben het met wachtwoordbeveligd delen uitgeschakeld. Dit is dus niet van toepassing.
Ook onze eerst oplossing was: zoek een XP pc. Helaas heb ik bij mij thuis recent álles overgezet naar een keurige Vista installatie, die vlieger gaat helaas niet op. We zouden evt. nog wel een XP computer kunnen emuleren in VMware, 'ns proberen.
Edit-
Even geprobeerd met Windows Server 2003
Deze ziet ook een mogelijkheid om in de map te komen, maar geeft wel een andere foutmelding:
Het opgegeven netwerkpad is door geen enkele host geaccepteerd.
Edit 2-
Het is gelukt! Het kwam er op neer dat we de Force Group = BRINKHUIS uit moesten schakelen dmv ;. Dit was steeds het probleem
Toch bedankt! :)
[ Voor 36% gewijzigd door HomegrownBGP op 15-01-2009 15:04 . Reden: bijvoeging ]
Ah ok! Heb ik ook weer wat geleerd :)
Blij dat het gelukt is.
