Site to site IPSEC 2xCisco 877
Beste tweakers,
Ik ben nu al 3 avonden aanhet stoeien (shame) om bij mij thuis een site to site ipsec verbinding op te zetten tussen 2 Cisco 877 ADSL POTS routers. De tunnel komt netjes up en je ziet ook daadwerkelijk dat er verkeer overheen WIL, maar ik krijg geen reactie aan de andere kant.
Hierbij de 2 configs:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
Router1#sh run
Building configuration...
Current configuration : 2598 bytes
! Last configuration change at 21:45:31 gmt Thu Jan 8 2009 by admin
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname Router1
boot-start-marker
boot system flash c870-advipservicesk9-mz.124-22.T.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone gmt 1
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.0 192.168.10.10
ip dhcp pool Router1
   network 192.168.10.0 255.255.255.0
   dns-server 195.18.114.5
   default-router 192.168.10.1
   lease 3
ip cef
ip domain name dmn01.local
ip name-server 195.18.114.5
no ipv6 cef
multilink bundle-name authenticated
username admin privilege 15 password 7 xxxxxxxxxxx
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key cisco123 address xxxxxxxxxxx
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map mymap 1 ipsec-isakmp
 description ****** Link to Router2 ******
 set peer xxxxxxxxxxx
 set security-association lifetime seconds 86400
 set transform-set myset
 set pfs group2
 match address 100
archive
 log config
  hidekeys
interface ATM0
 no ip address
 no atm ilmi-keepalive
 pvc 0/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
 ip address 192.168.10.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface Dialer0
 ip address negotiated
 no ip unreachables
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username xxxxxxxxxxx password 7 xxxxxxxxxxx
 crypto map mymap
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxxxxxxxxxx
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface Dialer0 overload
access-list 100 remark ****** Link to Router2 ******
access-list 100 permit ip 192.168.10.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 101 remark ****** NAT ACL ******
access-list 101 deny   ip 192.168.10.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
route-map nonat permit 10
 match ip address 101
control-plane
line con 0
 logging synchronous
 login local
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 120 0
 logging synchronous
 login local
 transport input ssh
 transport output ssh
scheduler max-task-time 5000
ntp server 145.24.129.6
end
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
Router2#sh run
Current configuration : 2643 bytes
! Last configuration change at 21:21:56 gmt Thu Jan 8 2009 by admin
version 12.4
no service pad
hostname Router2
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.10.0 172.16.10.10
ip dhcp pool Router2
   network 172.16.10.0 255.255.255.0
   default-router 172.16.10.1
   lease 3
ip cef
no ipv6 cef
 encr 3des
 hash md5
 group 2
crypto map mymap 2 ipsec-isakmp
 description ****** Link to Router1 ******
 set pfs group2
 match address 100
archive
 log config
  hidekeys
interface ATM0
 no ip address
 pvc 0/35
interface Vlan1
 ip address 172.16.10.1 255.255.255.0
 ip nat inside
interface Dialer0
 no ip unreachables
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username user0@alice.nl password 7 xxxxxxxxxxx
 crypto map mymap
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
access-list 100 remark ****** Link to Router1 ******
access-list 100 permit ip 172.16.10.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 deny   ip 172.16.10.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 172.16.10.0 0.0.0.255 any
control-plane
line con 0
 logging synchronous
 login local
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 120 0
 logging synchronous
 login local
 transport input ssh
ntp server 85.17.201.68
end
Wie o wie kan mij uit m'n lijden verlossen :)?
  • Gillie
Als ik er goed naar kijk, lijkt het in de access-list 100 te zitten. Wat je doet is voor A naar B en B naar A. Alleen voor IPsec werkt dat niet zo.
Die moeten volgens mij voor beide routers exact hetzelfde zijn. Dus van A naar B.
  • Vicarious
  • Laatst online: 24-06-2024
Vicarious
☑Rekt | ☐ Not rekt
Mist hij niet gewoon een route naar de andere kant? Hoe weet de router nu dat hij verkeer voor het destination netwerk via de tunnel moet sturen?
Vicariously I live while the whole world dies
De route hoeft niet apart opgegeven te worden voor verkeer aan de andere kant van de tunnel. Deze is
bij de router bekend vanuit de IPSec definitie. Je doet tenslotte een match via de route-map.
Verder zien de ACL's er ook goed uit. Het klopt dat beide ACL's hetzelfde moeten zijn, maar dit heeft
betrekking op de netwerken die je toestaat. De richting is gewoon van A naar B en van B naar A. Anders
krijg je daar nooit een match op, aangezien de source adressen aan kant B niet bestaan wanneer je
een permit op "source (networkA mask) naar destination (networkB mask)" doet.
Zet achter de volgende regel:
crypto isakmp key cisco123 address xxxxxxxxxxx no-xauth
en probeer het nogmaals s.v.p. ;)
Verder wil je misschien overwegen om als hash SHA te gebruiken ipv MD5 op de ISAKMP policy en
transform set.
[ Voor 7% gewijzigd door Verwijderd op 12-01-2009 19:28 ]
