[Ubuntu] BCM4318
  • encryped
  • Laatst online: 23:56
Ik heb een Acer Aspire 3005 WLMI waar ubuntu 8.10 I386 op draait
En ik krijg mijn draadloos internet niet aan de gang
sudo lshw -c network
peter@ubuntu:~$ sudo lshw -c network
*-network:0
description: Ethernet interface
product: SiS900 PCI Fast Ethernet
vendor: Silicon Integrated Systems [SiS]
physical id: 4
bus info: pci@0000:00:04.0
logical name: eth0
version: 91
serial: 00:16:36:35:27:f3
capacity: 100MB/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sis900 driverversion=v1.08.10 Apr. 2 2006 duplex=full ip=192.168.0.95 latency=173 link=yes maxlatency=11 mingnt=52 module=sis900 multicast=yes port=MII speed=100MB/s
*-network:1
description: Network controller
product: BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller
vendor: Broadcom Corporation
physical id: b
bus info: pci@0000:00:0b.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: bus_master
configuration: driver=b43-pci-bridge latency=64 module=ssb
*-network:0 DISABLED
description: Wireless interface
physical id: 1
logical name: wlan0
serial: 00:11:ac:24:43:4e
capabilities: ethernet physical wireless
configuration: broadcast=yes multicast=yes wireless=IEEE 802.11bg
*-network:1 DISABLED
physical id: 2
logical name: pan0
serial: 96:76:57:8c:3f:2f
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A link=yes multicast=yes
peter@ubuntu:~$
iwconfig
peter@ubuntu:~$ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0
IEEE 802.11bg ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=0 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
pan0 no wireless extensions
peter@ubuntu:~$
  • backupdevice
  • Laatst online: 18:26
backupdevice
No Risk , Full Push
Heb je ubuntuforums.org al bekeken?
http://ubuntuforums.org/showthread.php?t=197102
2 minuten zoekwerk. Suc6
  • blaataaps
En wil je code-tags om je pastes heenzetten, dan is het leesbaar :)
  • 0xDEADBEEF
[q]configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A link=yes multicast=yes[/]
Voer het volgende eens uit in een terminal/console, en plak de uitvoer in een (nieuwe) post:
[code]ls /lib/firmware/[/]
Wat voor beveiliging heeft het netwerk waarmee je probeert te verbinden; niets/WEP/WPA(2) ?
Je bent vergeten in te stellen met welk netwerk je wil verbinden :P
wlan0
Dat kan met NetworkManager, of met wpa_supplicant.
"Religion is an insult to human dignity. With or without it you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg
  • encryped
heel erg bedankt voor je hulp ik heb hem nu aan de gang
